Question about Siemens Gigaset 2420 Cordless Phone
Gigaset A165 phone not working base flashing on handset
My phone has stopped working and base is flashing on both handsets
3 Suggested Answers
CORDLESSGURU
  • 106 Answers
SOURCE: Problem Siemens Gigaset 4000 and 4200
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Posted on Jun 16, 2008
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
How do i fix my landline phone?
hmm im not sure if there's an issue with the base for your wireless phones but it maybe that the phones arent able to determine if the base is active (EG the right base for the phones) some may need to be paired up to the base or the base maybe malfunctioning due to the lightning storm (Phone lines are prone to being struck at times which could send a surge to some types of phone bases and ruin them)
Aug 22, 2017 | Siemens Gigaset Digital Cordless Phone...
Base is flashing and cannot dial out
HERE'S THE LINK TO THE MANUAL.
The handset is either too far from the base or it needs to be registered. The instructions are in the manual.
http://m.gigaset.com/medias/sys_master/A31008-M2050-L101-1-7619_30-10-2008_en_GBR.pdf
Dec 25, 2012 | Siemens Gigaset 4010 Cordless Phone
I had switched off my Gigaset C200 for one week and when I switched it on again so still flashes "base 1" on the phone's display. I tried manually connect to the base with PIN 0000 but still...
YOU SHOULD HARD RESET THE UNIT
When restoring factory settings:
u Handsets are de-registered
- When resetting via the menu:
all Gigaset handsets
- When resetting using the key on the
base station: also all handsets of
other GAP capable devices
u Individual settings are reset
u All lists are deleted
u The system PIN is reset to the original
code 0000
u Eco Mode+ is deactivated
Only the date and time are retained.
Resetting the base station via the
menu
₪ Settings ₪ Base ₪ Base Reset
§Menu§
§OK§
Press the display key to confirm
SIEMENS Gigaset C380 User Giude Restoring The Base Station To The Factory...
Dec 27, 2017 | Siemens Gigaset C200 Cordless Phone
My Siemens gigaset A 490 cordless phone is showing Register HS what i have to do pl advise
To register the Gigaset handset, you need to have the handset near the base. Press and hold the Register/Paging button on the base for 3+ seconds (it's hidden by the handset when on the base). A shorter press of the button will activate the Paging feature. Then within 60 seconds of pressing the Register button on the base, press Menu and select Settings. Press OK and go to Handset. Press OK and then select Register HS. Enter the base PIN (default is 0000) and then press OK. (Use the up/down arrows to navigate the menus.) You will see Registering flash on the display of the handset for approximately 1 minute while the registration is processed.
The manual for the Gigaset A490 is available here: http://gigaset.com/medias/sys_master/A31008-M2200-R301-2-3S19_en-fr-es_USA_CAN.pdf . If you need it in another language (or country), start here: http://gigaset.com/hq/en/product/GIGASETA490.html?tab=manuals .
I hope this helps.
May 26, 2011 | Siemens Gigaset A490 Twin Cordless Phone
Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
You did get spiked from the power company, and your system needs repair. Go to www.cordlessrepair.com for help.
Jun 23, 2008 | Siemens Gigaset 4000 Phone
Jun 15, 2008 | Lands Phones
My siemens gigaset 4215 and 4000 don't work and need some kind of code whats the code?
Hello, Almost never is it the handset that is bad when those symptoms occur. It sounds as if your base has gotten hit by a power surge and won't boot (the handset now can't "talk to" the base and its always searching for it). Most people report this after a storm has passed through their area. You can try re-registering the handset to the base, but unfortunately it probably won't work, sorry. You can order the base only and register your handset to the replacement base when you get it. To order a replacement base using google, search for Siemens Cordless Repair and click the first non sponsored link. Good Luck
Dec 08, 2007 | Siemens Gigaset 4000 Phone
Handset flashes "searching" and has stopped working
Did you already try cleaning the connections on the phone and the base with alcohol on a Q-tip? Make sure the connections on the phone are touching the base propely.
Jul 19, 2007 | Siemens Gigaset 4210 Cordless Phone
Siemens Gigaset 2420 Cordless Phone Logo
320 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
