Question about Code-Alarm Code Alarm Transponder
Ford fiesta ghia 1998 model central locking key
I changed the batteries in my remote central locking key for a ford fiesta ghia 1.25 ztec 1998 model and the central locking will no longer work by the key. unlocking the doors itself only way to get in car please help
  • Ford Master
  • 4,979 Answers
This is a common problem after changing the Key Fob battery.
The solution is to remove the fuse feeding the Cental Locking for 10 minute...Replace then all should work fine
Posted on Sep 12, 2009
Where is the fuse for the central locking?
Posted on Sep 03, 2010
Remote central locking unlocking but not locking
You need the body control module scanned for fault codes by the dealer.
Apr 30, 2013 | 2008 Ford Fiesta 1.3
00 ford fiesta,, heaters,electric windows and indicators not workin, fuses and relays seem good??
have exact same problem myself checked all fuses they are fine & my car is a ford fiesta yr 2000 model Ghia gonna have a look at the 50amp fuses
Any1 else out there have a possible solution. If this 1 dont work
Dec 22, 2009 | 2000 Ford Focus
Central locking not working
Assuming that the battery mentioned above is the Key Fob battery?
The usual solution to the key fob not working the Central Locking after battery replacent  is to remove the car battery feed fuse   to the Central Locking (or disconnect the car battery )  for 10 minutes...replace it..... then it should work OK
note: If you disconnect the Car Battery then make sure you have the radio security code.
If not then POST A NEW QUESTION quoting your radio Serial Number (usually begins with M * * * *  * * )
Sep 25, 2009 | Code-Alarm Code Alarm Transponder
Ford fiesta ghia 1998 central locking fault
If you have the owners manual, look to see if it has the programming for the door locks. Some vehicles allow what you are talking about. Some allow all the doors to lock after you start moving your car. If you don't have a manual then contact your dealer or look on the internet
Jul 01, 2017 | Vehicle Parts & Accessories
My ford fiesta central locking doe es not work
first is it remote or key operated
if its remote operated try changing the battier in the key
if its key opperated try useing the other front door if it works from that side its the pick up sensor on the lock at fault
Jan 06, 2009 | Ford F Cars & Trucks
Ford Focus Central Locking Has Own Mind!
the key fob sounds like it might be sending a signal sometimes so take the battery out and see if there is any change.joe
Nov 18, 2008 | 2001 Ford Focus
Ford fiesta transponder problem
I have a 2002 fiesta and recently it has been stopping on eac failure and then the imobiliser light keeps flashing and the car wont start not even turn over ha any one got a solution for this?
Thanks llinos
Nov 01, 2008 | Code-Alarm Code Alarm Transponder
My car wont lock
If you can remove the door panel, check to make sure none of the lock linkage is bent. If it is bent try bending it back. If its not bent pick up a can of white grease and spray all the moving parts inside your door that connect to the lock mechanism.
Jul 20, 2008 | 2005 Ford F-150
Ford fiesta 1994
is it a foctory alarm? or an aftermarket alamr? if it is factoty
just lock and unlock the door with the key, but if not let me know.
Jun 22, 2008 | 2000 Ford Focus
Code-Alarm Code Alarm  Transponder Logo
1,743 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
