Question about Canon PIXMA iP1600 Printer
I am dumb, don't know how to install ink cartriges
I have no idea how to install these or how they click into place. I have read the manual like 5 times and I still have no idea how they fit. I know I have the right cartriges, they are the ones that came with the printer. Help, anyone?
I'll try to be as clear as I can. Slide the cartridge into the correct location. B for Black and C for Colour. Push forward slowly (it should be on a slant going in) until you feel resistance. Then push IN and UP until you hear a click. The ink should now be seated.
Posted on Apr 14, 2007
The problem is that the cartridges have to snap into a special carrier that moves around and is sometimes not positioned next to the B and C markings. Pull the carrier all the way to the left and then the cartridges should snap in easily.
Posted on Jul 29, 2007
How do I REPLACE SHIFT CABLE
rtm? no symptoms so i must guess, ill say , cant shift. and is not park lock out causing that.
want to read the manual or me to you.'?
ill guess you.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
click 1996 to 2001
it replaces like all cables do
detach both ends and remove it. if clamps seen those too.
what matters is adjustment is needed.
some have 2 cables, one to gear box and one to ignition switch.
Chapter 21, page 150 states
REMOVAL
(1) Shift transmission into Park.
(2) Remove shift lever bezel and necessary console
parts for access to shift lever assembly.
(3) Disconnect cable at shift lever and feed cable
through dash panel opening to underside of vehicle.
(4) Raise vehicle.
(5) Disengage cable eyelet at transmission shift
lever and pull cable adjuster out of mounting
bracket. Then remove old cable from vehicle.
INSTALLATION
(1) Route cable through hole in dash panel. Fully
seat cable grommet into dash panel.
(2) Place the auto transmission manual shift control
lever in "Park" detent (rearmost) position and
rotate prop shaft to ensure transmission is in park.
(3) Connect shift cable to shifter mechanism by
snapping cable retaining ears into shifter bracket
and press cable end fitting onto lever ball stud.
(4) Place the floor shifter lever in park position.
Ensure that the pawl is seated within the confines of
the adjustment gauge clip.
(5) Snap the cable into the transmission bracket so
the retaining ears are engaged and connect cable end
fitting onto the manual control lever ball stud.
(6) Lock shift cable into position by pushing
upward on the adjusting lock button.
(7) Remove and discard the shift cable adjustment
gauge clip from the park gate of the shifter.
easy?
Aug 25, 2015 | 1996 Jeep Cherokee
My oven has had three thermostats fitted recently and an oven thermometer is regestering about 50 degrees cooler. what cani do?
To get a more accurate indication, set the oven to 350 degrees. Place your thermometer on the lowest shelf, take a reading. Place it in the middle shelf, wait for it to stabilize (5 minutes or so), take a reading, place it on the top shelf, wait 5 minutes take a reading, Average out all 3 readings, the average should be close to the thermostat setting.
Feb 15, 2015 | Ovens
How to install 3G Mini Card in HP 8560w A6C86PA
those cards only work in your country.
they must match. (commications laws, RF)
no country stated by you, earth is big place and we are WWW.
the manuals cover all that. you asked, it has its own place .
the book is free to read. see the 10MB large book here,
service. bingo
https://support.hp.com/us-en/product/hp-elitebook-8560w-mobile-workstation/5071171/manuals
Sep 30, 2017 | HP Computers & Internet
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    How do I install new ram memory on my dell demension 3000 computer
    The RAM modules fit into slots on the motherboard and held in place with clips at the ends of the RAM module.
    To remove the RAM module, push these clips to down and the RAM will pop up out of the memory slot.
    When you insert the new RAM module/s, place the module in the memory slot, it will only fit in one direction, the RAM module have a notch on the edge where if fits into the memory slot.
    Press the RAM module firmly into the slot until the clips pop up and locks the RAM module in place then check the clips are firmly in place.
    I recommend you install DDR RAM PC3200 in pairs as per the manual.
    If you don't have the manual Please click on this link :-
    http://support.dell.com/support/edocs/systems/dim3000/en/OM/j6758A04.pdf
    Sep 21, 2010 | Computers & Internet
    ICE DOOR SEAL IS LOOSE AND NOT SEALING CAUSING FROST BUILDUP
    This is the step you will use to repair your ice door seal that is loose.
    There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
    As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
    Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
    Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
    Check the seal by closing the door. You should have a nice, tight seal.
    Good luck.
  • Step 4 Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
  • Step 3 Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
  • Step 2 As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
  • Step 5 fix-freezer-door-seal-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/k5/eg/fix-freezer-door-seal-1.5-800X800.jpg'); }); Keep the gasket clean to last longer. Check the seal by closing the door. You should have a nice, tight seal.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
    Jun 22, 2010 | Refrigerators
    INSTALLATION ON PRINTER DRIVER
    Close the manual. Open Windows Explorer and navigate to the CD. Explore the CD looking for a driver folder or a setup.exe command and double click the command which hopefully will set up the printer driver. If there is a driver folder, check to see what kind of files are there. If they are *.dll or *.sys files then you have to use Windows control panel to install them. Let me know what you find.
    May 29, 2009 | Canon FAXPHONE L80 All-In-One Laser...
    How to install suct tube and conncre hose
    Go to; www.managemyhome.com.
    When at that home page, place your cursor over, but do not click yet, 'Home Manager' in the red bar at top of the page.
    There you will see five choices, click on 'Owners Manual'
    Then find 'Kenmore' under 'Search Manuals By Popular Brand' and click on 'Kenmore'.
    Then under 'Narrow your Results', scroll down to 'Dehumidifier' and click on 'Dehumidifier'.
    Then you will see a five (5) page list of Kenmore Dehumidifiers along with the model Number.
    YOUR Kenmore model # 58054501400 will be found on PAGE#2.
    Click on page #2 and scroll down to the bottom of that page and find yours.
    Then look at the right hand side of that page and see 'View Manual'
    Click on 'View Manual' and there you will have it and the answers to any questions you have.
    Good luck. :)
    May 08, 2009 | Dehumidifiers
    Canon PIXMA iP1600 Printer Logo
    old marine
    old marine
