Question about Xerox 1 YEAR ON-SITE SERVICE AVAILABLE ON AN ANNUAL BASIS FOR THE PHASER 8500 / 8550. (095205219357) PC Notebook
Xerox 214 dc how to adjust the contrast, when copies are blades
How to adjust the contrast, when copies are blades
  • bernardasche Dec 04, 2008
    I mean that the copies aren't black enough. You can't read it properly.
  • Rick Kasper May 11, 2010
    What do you mean when you are stating " When copies are blades" ? Not sure what that is describing.
Copy is very light. Cannot open the MENU & hence cannot adjust the darkness of the Copy.
First off all to go to menu Press star (Additional function) - 28 together and again star Go to Function - Density and increase/ decrease the number. DE - DC- 24 Dev - 15 Off - 128 Den - 7-9 And again There may be a number of reasons for a light copy 1. Drum - change the drum if it is run above 10 - 20000 copies 2. Blade - changing the blade simultaneously to improve the copy quality
Thanking you.
Jul 02, 2011 | Canon imageRUNNER 400S Copier
Free solution of black bars on paper while printing on xerox dc 12 printer
Most likely this indicates a drum cleaning blade failure. This is especially true if the black Bars run up and down the page and get worse on multiple copy runs. So if you run 10 copies the last one out will be worse than the first one out. If this is the case, cleaner blades are pretty in-expensive at around $40.00.
Good Luck and Thank You for using Fixya.
Sep 10, 2010 | Xerox DocuColor 12 Color Copier
What is the solution of black bars on paper while printing on xerox dc 12 printer
Most likely a drum cleaning blade. If the streaks are verticle, up and down the page and if they get worse as you run multiple copies. So on a 10 page copy run the last copy out will be worse than the first. Cleaner blades are cheap at around $40.00
Have a 214 xerox copier get e5 error and it will not reset
Remove the copy cartridgte and look on the right side of the machine. Clean all the contacts you see with a soft cloth, maybe lightly saturated with alcohol.
Then on the door where the copies exit, open that door, you will see a metal, sawtooth shaped piece of metal, just before the paper exits the machine on that door. Take a brusk and gently clean the black ink off that sawtooth. Normally what happens is that builds up with ink and starts to arch causing the E-5 code.
You may want to check the socket that is one the upper left portion of that door to inspect the contacts for damage.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Xerox 214 dc
It means the cartidge alignment is dis-balanced. So you need to fix it and may be re-fill cartidges also.
Dec 11, 2008 | Xerox 1 YEAR ON-SITE SERVICE AVAILABLE ON...
High Contrast in Printing Photographs from DC-12
sir
u do one thing press 0+ start & go to max setup
trc adjustment press start u can get a3 print
next trc toner concentration start
ofter u can get some defference
Dec 11, 2008 | Xerox DocuColor 12 Printer
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
Xerox Copier 214
A U4 is a fuser overtemperature.
You can hold down the "0" while powering the machine on. That will enter the machine into diagnnostics.
Next enter code 401, and press start, See of that clears the problem.
If it does. Remove the fiser and clean the buildup off the thermistor.
If it doesnt you will most likely have to replace the fuser.
Jan 29, 2008 | Xerox WorkCentre 214 Laser Printer
93 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
