Question about Mitsubishi VS-60607 TV
Mitsubishi VS-60607 TV bottom of the screen has dark areas
We just bought this tv used and it worked fine till I cleaned the screen. I know I was wrong in doing this, but I used a sponge with water and I believe a small amount of water leaked into the bottom part of the screen. Now there's a dark area that has streaked up the screen and I"ve tried to use a hair dryer and tried to clean with alcohol and neither works. Where it streaks up it looks like a circle in one part...not sure how to describe this...I'm wondering if water came up on the other side of the screen and is causing this problem. Is there a way to go into the tv and clean the other side of the screen? Or, do you know what I might have done and what could fix this? Please please please someone give advicce soon before hubby comes home :-) Stephanie
  • Stephanie Marie Jan 24, 2007
    Well I believe I figured part of the problem out. I think there are two screens on this tv and water that touched the bottom of the screen kinda wicked itself up between the screens. It looks better today, but still like a smudge look. Does anyone know how to take the screen off?
Take the front bottom black panel off. it pulls off. unscrew the little panel in the middle. reach up and pull the wires down gently. unplug the 2 conectors gonig to the big metal frame holding the screen in. unscrew the 2-4 screws holding the big metal frame. pull up put screen on sheet to protect it. unscrew the screws holding both of the screens in. Pull apart and clean
Posted on Jun 08, 2007
Horizontal/vertical hold is off, picture is moving fom left to right Mitsubishi big screen vs-60607
You better take this fellow to a doctor. You have a stamp size IC with about 250 pins that is bad. Only a tech can replace this or reinstall a remanufactured board into this TV. You may ask the tech to use a freeze spray to find this IC first and then he wil decide how to operate!l
Jan 24, 2010 | Mitsubishi VS-60607 TV
MITSUBISHI TV VS-60607
HI there,
Check for any bad solder on the mainboard of the TV, and also check for any burn fuse on the powersupply area... BAd solder was very common problem on Mitsubishi TV..
micro
Jun 07, 2008 | Mitsubishi VS-60607 TV
I have a Mitsubishi VS-60607 Tv and it started out
Without going in with troubleshooting equipment it is hard to determine if the problems are related or not but it is unlikely since you seem to have a video problem and a convergence problem , which are two separate circuit(signal processing and deflection). Hope this help.
Please do not rate this answer(unless it helps)as it is only a suggestion.
Dec 03, 2009 | Mitsubishi VS-60607 TV
How can i get a schematic for the mitsubishi vs-60607 convergence circuit
U don't,the corporation does not allow it.U can get the convergence kit,comon prob.for all DLP tv.U know how to solders right?try this website for the convergence kit,use what in that kit,should solve ur convergence prob.
Oct 20, 2009 | Mitsubishi VS-60607 TV
Mitsubishi VS 60607 60" TV
From what i have been told the VS - 60607 was built in 2000 and i am not sure if it is HD or not.....
Aug 31, 2008 | Mitsubishi VS-60607 TV
Vs-60607 brightness problems
This sounds like it is a problem with the tv. Mitsubishi does have a problem with filter caps in thier regulator circuits. A repair tech will have to fix it.
Mar 06, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-60607 60inch projection TV, cannot turn on
i have the same and i am having issues with the screen going dark when its suppposed to be a white screen and the picture is darker than it should be during normal watching of tv. also there is a line at the top(letterbox style) of about 1- 1 1/2 inches......anyone know how to fix this
Feb 22, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-60607 TV Logo
157 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
