Question about Compaq Armada 110 Notebook
CD DRIVE The problem with my CD drive is that I can only open it by using a pin, the green active light is on all the time and if I look in explorer it tells me that the C drive and the Floppy drive are present but no CD drive. If I put a cd into the drive it does nothing and I have to use a pin to open the drive. Any ideas Thanks
    Sniper:
  • 114 Answers
I've serviced these units and the cdroms drives were always a problem. The problem on the cdrom is that the actuator switch in the drive itself doesn't allow the drive to spin up all the way to read the disk. The common way to diagnose this problem is push the cdrom drive in and hold it in with a cd is the drive, if it spins up, and works while you are pushing it in, it's the actuator. the fix for this problem is to replace the cdrom drive.
Posted on Jun 09, 2008
What you can do is you can go to computer, right click>properties>hardware>device manager, then look for removeable drives and there select the drive that is not working or malfunctioning right click on that and the uninstall and then restart the system and your problem will be resolved apurv jaitly
Posted on Jan 24, 2007
    President:
  • 2,961 Answers
Could be a faulty drive, but check first that it's not a driver fault. Go to my computer, right click>properties>hardware>device manager. Look down the list for your cd/dvd drive, right click and delete. Restart pc and let windows find it again nd see if the fault is corrected. If not it could be a drive or ide cable fault.
SOURCE:
Cd stuck in emachine and there's no pin hole
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Jun 15, 2012 | E-Machines emachines (emachinees) CD-ROM...
Cd rom wont open
Hi in front of the CD-ROM drive there should be a small pin size hole. Stick a pin in there to release the CD-ROM lock and it should open.
Jun 12, 2012 | Toshiba Samsung Slot Loading DVD+RW Slim...
CD/DVD drive still in use?
Cdrom has a small pinhole that you can insert a paper clip pin to push open the tray mechanically.
Mar 24, 2012 | ASUS Computers & Internet
How do i download music from cd onto my htc wildfire?
connect your phone to computer, use cable data, chose mass storage option
insert the cd to the computer cd room
at computer open windows explorer, there must show hard drive, cd drive and phone drive
at windows explorer open cd drive look at the music that you want to download to your phone
right click at music file that you want to download then chose copy
open phone drive, and open music/sound folder then right click then chose paste
and you was do download music from cd to phone
i hope this helpful
thank you foe using download
Feb 14, 2011 | HTC Wildfire Cell Phone
Product is Roxio Easy CD & DVD Burning. We put the cd in the drive, we get lights on the drive, we get hard drive disk activity but no installation program comes up. We tried turning off Norton AV,...
Most probably the CD does not have the autoun function or the autorun is no functioning. If you need to install the software, open the Windows Explorer and click on the drive for the CD and on the Explorer right side plane double click the "setup" installer and the installation should run.
Hope it helps.
Nov 13, 2010 | Roxio Easy CD & DVD Burning
Re. TEAC CD-224E, model version -B66. The drive will only open when inserting a pin in the release hole. When a disc is inserted and the drive closed the computer can not read it, the disc keeps...
This is an indication of mechanical failure of some part of the ejection mechanism. Since they are more expensive to fix than the drive is worth, replacement is your best option.
In addition, since the CD remains spun up and the activity light doesn't go out, there's probably something else wrong with the drive in addition to the failed ejection component.
Aug 03, 2010 | Teac CD-224E (cd224eb33) CD-ROM Drive
Cd drawer
there is usually a small hole right around the button to open the tray. use a paperclip or something like that and put it in the hole and it should open
Apr 12, 2010 | HP Pavilion dv9000z Notebook
CD driver problem for Telex SpinWise 4-52NH
Assuming you've used the 'eject' function in the software already.
Generic answer: Look for pin-hole size hole on front or back of CD drive (may have to open PC case to get at it) and push into it with the end of an unwound paperclip. Meant to release the disk. Hope this works for your drive.
Aug 04, 2009 | Telex SpinWise 4-52NH (301869000) CD-R...
Portable Hard drive. first time used. Green light is steady, attempts to remove say can interupt at this time.
I'm assuming you are using windows...
You need to close anything that has files open from the hard drive. Even having a Windows Explorer window or "My Computer" window open will cause the drive to be in use. Close these and you should be able to use the "Safely Remove Hardware" icon in the system tray.
Jun 23, 2008 | Computers & Internet
Drive won't open
u can see a pin hole on the drive just above the open button or the green light...press the button once n poke the hole with a pin ,,,,it ll hit a soft end...continue pressing it with some force....the tray will open...
Jan 02, 2008 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
Compaq Armada 110 Notebook Logo
76 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
