Question about Bulova Men's Black Leather, Black Dial Chronograph Watch
How to align seconds hand for stopwatch feature?
I recently had the battery replaced and afterwards the alignment of the stopwatch's seconds hand (big seconds hand) is aligned to 25 and not 0. how do i realign the seconds hand back to 0?
    Sniper:
  • 51 Answers
If you pull out the crown to the 2ed postion the push the upper start button that should move the second hand up to zero then push crown in.
Posted on May 04, 2007
  • capefearless Nov 29, 2010
    While the above method did not work exactly for me, it put me on the right track. On my Bulova I needed to pull the crown to the center position and push the upper button once for every second needed to advance (in other words - if the second hand aligned to 29 seconds, I would have to push the upper button 31 times).
    I hope this helps.
Thank you! I needed to do this myself, worked like a charm!
Posted on Jul 27, 2012
I'm able to set the time and date but once i push the crown back to its original place the watch doesn't start so i push the upper bumper and the seconds begin to run nevertheless the minutes never...
your watch is chronograph,. and it is not in the picture. probably your problem is the second hand won,t move, it is because that the sub dial on the lower part it is the real second hand. the big second hand is for the stopwatch. the to sub dial on the upper sides of your watch. the upper button/bumper is to start and stop the stopwatch or the big second hand and the bottom bumper/button is to reset it. i hope this can solve the problem...
Jul 25, 2011 | Swiss Army Wenger Sportedge Bracelet Watch
Hi, in my seamaster 2221.80 quartz most of the clicks of the seconds hand does not align with the second markers.is this normal & can it be re-calibrated. its a little out of character from an...
A competent watch repair technician can remove and reset the second hand on your watch so that it more precisely aligns with the seconds markers on your dial. However, it may not be possible to get the hand to perfectly align with all 60 markers around the dial. It is not uncommon in cheaper watches for this misalignment to occur, either because the dial has shifted slightly from its original placement on the movement (for glued-on dials) or because the second hand was not carefully aligned when it was initially installed. This problem is less common in watches where the watch dial is more precisely attached and aligned with the movement via screws.
To perform this service, the movement is typically removed from the watch, so this is not a 10-second job. Sometimes, the watch crystal is removed instead, but this may take more time and reduce the water resistant properties of the watch. Either way, if your Omega is still under warranty, this may be a valid claim for service.
Once the second hand is properly aligned, this problem should not re-occur.
May 06, 2011 | Watches
Second hand doesnt move. The ''stop watch'' second hand moves instead of the ''main'' second hand. also the stopwatch feature doesn't work. My watch is a Fossil Blue Titanium model TI-5071
Sounds like a job for Fossil!
Go to their web site "www.fossil.com" and at the bottom of their page is a menu which includes "store locator".
Feb 24, 2010 | Watches
Jacques Lemans 5015B model, drop my watch on floor yesterday, 2
You need a hand alignment at the very least. Sounds like your sweep arm is getting stuck on other objects in the face.
Sep 26, 2009 | Jacques Lemans Watches
Cannot get watch hands to sync with the digital time. mine is movement ''c320'' older watch, citizen ''navisail'' stars and stripes 2000 special edition....america's cup watch.
pull stem out and push all other buttons a b c at same time to reboot next step advance hands min/hour/sec to 12:00 push in stem M and start your reset
May 09, 2009 | Citizen Watches
Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Apr 03, 2009 | Watches
Invicta model 3209 watch
Your watch is fitted with chronograph movement 5040D made by Ronda (Switzerland). If you take a closer look, then you will realise that the subdial at 3 o'clock is counting seconds allready. This is your seconds dial, not the big one.
The big seconds hand actually is the chronograph hand (stopwatch) and, when activated, works together with 1/10th counter.
Follow this link and see for yourself:
http://www.ronda.ch/e/index_bedienung.html
Find movement 5040D and click on INTERACTIVE version.
Rate me, please.
Mar 25, 2009 | Invicta 3209 Lupah Diver Watch
Using the stop watch feature
Dennis,
"Chronograph" is watch terminology for 'stop-watch'.
There are 3 small dials on the watch.  The main dial has a minute hand and an hour hand.  The big second hand on the main dial is not for the main time of the watch.  It is for measuring seconds for the stopwatch.
The 2 small dials at 10 o'clock and 2 o'clock will give you minutes and 1/10 of a seconds.
There are 2 buttons on the side of the watch. Top Button:  Start/Stop Bottom Button: Reset
To set the chronograph to its default position, you would pull out the stem to the first position and push the buttons.  Also, pull the stem out further to the 2nd position and push the buttons.
Jan 13, 2009 | Swatch Chronograph Wach SVCK4035G Watch...
Ta Heuer Professional stopwatch minute hand reser to 12 position
pull the crown on first click and push the upper button until it reaches to your desired position.
Mar 16, 2008 | Watches
Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Oct 09, 2007 | Watches
Bulova Men's Black Leather, Black Dial Chronograph Watch Logo
1,383 people viewed this question
Top Bulova Watches Experts
Arturs Kalnins
Arturs Kalnins
Craig Butler
Craig Butler
Are you a Bulova Watch Expert? Answer questions, earn points and help others
