Back to:
Tags:
KLH R5100 5.1 Channels Receiver
No Analog output (by 5 users)
posted by MadMax59 on Feb 07, 2007
Have had my KLH R5100 for about three years. The first two years trouble free. About a year ago, when I turned it on, it had no audio output. After checking every possible switch,cable and option available, I gave up and unplugged it. Took it to a stereo shop about 4 mos later and left it for testing. He called an stated nothing was wrong and he was able to run it steady for 4 days. Brought it back, hooked everything up, and lo and behold, worked fine. The next morning, turned it on and again, no sound from any input. Even when I select the Test mode using the remote control, you see the receiver changing speakers from the front panel but no sound. (Yes, the volume control is up). I am very close to doing the 20ft drop test to see how many pieces I can gather. Any suggestions would be appreciated.
Thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by sietstra, posted on Jul 14, 2008
have no lights on front just clicks when turn on need to know how to change fuses or try something
Comment by Pat Fer, posted on Jul 01, 2008
Had no output from any speakers.
Checked internal fuses. They were OK.
Red LED is not on a when I turn system off.
Where can I get a schematic to trouble shoot this problem?
Comment by Guest, posted on May 04, 2008
same problem need fixed NOW!!!!!! plz :'(
Comment by Guest, posted on Feb 28, 2008
I am having the same problem, no audio out put of any kind even during "test", any one know of any fuses that could possibly blow? or any fix it tips?
Solution #1
posted on Feb 12, 2008
Not Rated (0)
tray22
Rank:Apprentice Apprentice
Rating: 85%, 3 votes
i need to know were did you take your to i need repair on my thank you tray
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on No Analog output:
I don't want to Accept this solution
Can you Help with these Receivers problems?
Hi! I hope you can help me, or point me to the right...
I wish to purchase a remote control for a KLHR5100 can you...
how do I know what size speakers to use with the klh...
the front left, center and the front right and sub woofer...
were do i send it to klh or who eals thank you tray
Loading problems.
Repair Service
Find Receiver Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
