Question about Frigidaire Washing Machines
FRIGIDAIRE WASHER LTF7000ESO ERROR CODE 41 - Frigidaire Washing Machines
  • mtgrusty Feb 07, 2009
    frigidaire model LTF2940ES3... error code 41--thinks door is open. Ran a load earlier today no problem....tried to start another one & this pops up. Any quick fix or am I screwed with having to call a $60 hour repairman?
2 Suggested Answers
lancaster5
  • 245 Answers
SOURCE: I have A Frigidaire Model
It definately could be your inlet valve, There is a clean out underneath the front panel, thee screws underneath will release the bottom panel. There should be a coke can size cylinder with a screw off top. Remove that a check to see if there is any obstruction. Good luck!
Posted on Aug 21, 2010
Replacing lock and latch on my frigidaire affinity washer
Error code 41 is about the door not latching. Appliancepartspros.com has the parts you need. Just enter your model #.
Jul 06, 2014 | Frigidaire ATF6000ES Front Load Washer
What is error code 41
Good Afternoon Donna,
I see that you are wondering what an error code 41 is on your Frigidaire washer, model# GLTF2940ES. Error code 41 means the control board thinks the door switch is open. You will want to make sure the door is closed. Reset your appliance by either unplugging it or shutting the power off at your home's circuit breaker. When you restore power select any cycle and start it. If you are still receiving an error code 41, I suggest contacting your local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 27, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washer LTF7000ESO error code E70
Good Morning Jazy, this is JK. I see that you are receiving an error message E70. The E70 error means that the Main Control Board is not seeing the correct water supply. I would suggest swapping the hot and cold hoses. Hope this helps!
Mar 24, 2014 | Frigidaire Washing Machines
Error 41 on Frigidaire Affinity Washer?
Hi Ricky, I am happy to assist you!
If you are receiving an error code E41, your loading door may be ajar. Double-check to ensure that it is closed. If it is secure, reset the power to your appliance for about 30 seconds. You can do this by unplugging the unit or flipping your circuit breaker into the off position. If the error persists, it could either be the door switch assembly or your unit's main control board. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Sep 26, 2013 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Affinity Error 41
Good Morning Beth, thank you for your post! One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. Please confirm that the door strike is properly installed on the door. If the error code persists, then the issue may now be related to a potential wiring failure between the main control board and door switch. At this point, please reach out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Aug 10, 2013 | Frigidaire ATF6000ES Front Load Washer
I have error 41
Hi Hector Aguilera - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Jan 26, 2013 | Frigidaire ATF6000ES Front Load Washer
I have A Frigidaire Model # LTF7000ESO The washer will not start. The washer makes a grinding noise. It sounds like the water valve will not open to let the water in the tub.
Aug 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
Hi, I got a Fridgiaire front load washer. I got an error code E 41. Machhine won't start at all. Replaced the board. Now water enters machine for 15 seconds then stops will not spin
The E41 error means the control thinks the door is open. From your description of the problem the most likely problem here is a bad door switch assembly.
Oct 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
270 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
