Question about StarTech.com StarView SV211K 2-port KVM Switch
Telly west codes - StarTech.com StarView SV211K 2-port KVM Switch
    Problem Solver:
  • 8 Answers
00= 3f 32 37 03 d0 73 84 84
01= c6 64 85 ef 47 5a 0e ef
Posted on Nov 30, 2008
Im trying to open an account i live in ireland an have no zip code or landline
In the sitaution where paypal request zipcodes in an outside location, the services can be achieved by registering the site to an overseas company with zipcode found familiar to carry the responsibilities to transactions on behalf of the foreign accunt holder.
Feb 04, 2011 | PayPal Accounts
Message stating check signal cable
Hi there, This could be a few possible issues. What you can try depending on your setup, is 1st to try and connect your ps3 to a different telly using the same cables if possible, like if you had it connected to hd telly with hdmi cable, use this setup on another telly to see if you have the same problem. If it's the same on the 2nd telly then it's the hdmi cable that's the problem, just replace and you should be good to go, but if it works on the 2nd telly then you will have to adjust some settings usually a resolution issue on the 1st telly. You can also try using an analogue cable that came with the ps3 to see if that works. If it was the analogue cable you were using anyway you may need to get a new one, but try on another telly 1st to be sure. It's most likely just a resolution issue but if you have the same problem on 2 tellys it's probably the cable then. Hope this helps
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
E01 code on west bend slow cooker - how can I fix
Your crockpot is giving you an error code EO1. Now you need to know how to get the code off of your crockpot so that you can use it.
Here is a tip that will tell you how to fix the EO1 error code.
West Bend Crockpot EO1 Error Codeheatman101
Jan 14, 2011 | West Bend 84496 6-Quart Slow Cooker
Unable to read massage 0 for update in tally ERP 9
Step 1
open drive where data is save
after it open your company data folder
than you have find a file (TMESSAGE.TSF)
it's error code 0
select this file and deleted its
after above process 100% your problem solve out
Dec 09, 2010 | Office Equipment & Supplies
I need the zip code from New York i need it fast becouse i wanna join the us army
Here, just look for the specific city:
Zip Code / City / Area Code
10996 West Point ( 845 )
10997 West Point ( 845 )
10996 West Point Military Reservat ( 845 )
Oct 11, 2010 | Computers & Internet
I need a list of codes to reprogram a universal remote for magnavox televisions.
hi, please could you let me know the make and model number of your remote, this may be written under where the battery goes as each model will have a different setup option.
if you do have the manual but dont have the codes then what you can do is an auto scan where you keep pressing the standby button until the telly turns off you then save it at that point then the remote should work the telly, if you dont have manual then let me know ok
i need to know if its made by ge or rct etc as their are a few people who make them
CLICK HERE
you may find the manual or codes here
here is the guide for an rca universal remote follow these instructions to scan through all the codes on the remote and save it when you come to the correct one, this is for rca how ever their are many other universal remotes so this may or may not work
1 turn on the target device, in your case this will be the telly
2 press and hold code search until the led lights light up
3 release the code search button
4 press and release the component button you wish to program in your case this will be tv it should flash then light back up and remain lit
5 press and hold the code search button until your tv tuns off then let go and press enter to save the code.
now if your remote is and rca one then keep doing this until the telly turns off then press enter and you should then be able to control the telly with the remote, if how ever this is not the instructions for your remote then let me know what make the remote is ok.
let me know how you get on or if you need further assistance ok
May 26, 2010 | Televison & Video
Bought urc-7515 code 0037 for bush telly only turns off telly does not change channell or work volume
The original remote for a Bush uses several codes for various buttons! I doubt that many of the universal remotes would have the sohistication to do this. Does your remote provide a 'Learning mode? If so this is the only way to get it to work close to its original.
Aug 20, 2009 | Televison & Video
I cannot get my universal remote to work!!! we have tried everything and it will change the channel once and then it doesnt work. i have tried all the combo codes and im getting really mad!!!!!!!!!!!
Hi have you tried manually searching for the frequency like it says in manual untill it turns the telly off then store this frequency in the control if this still dont solve your problem then the remote is faulty because if your telly is listed in the code sheet then it will work on the telly if not then the control is faulty so take it back and get a replacement ok.
What make and model is your remote?
What make and model is telly?
let me know then ill look for you ok
Apr 22, 2008 | Televison & Video
Sony RM-V202 remote control ... lost instruction book....
if you tell me the make of the telly i can give you the code but here is the manuall way
turn on tv
1 press and hold s or set
2 whilst holding s pressand releas power button n release set
3 press component button ie tv
4 now press ch+ button once and then try power button if this dont work telly then press ch+ again and try power button again you can repeat this upto 70 times before it will pick up the right signal but when it works your telly press enter or set button this should solve your problem
Sep 13, 2007 | Sony RMT-V202 Remote Control
StarTech.com StarView SV211K 2-port KVM Switch Logo
127 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
