Heater will not light,ignighter glows,fan comes on,wont light,then shuts off
  • Anonymous Jan 14, 2009
    heater will not light,ignighter glows,fan comes on,wont light,then shuts off
  • Anonymous Feb 14, 2009
    i have the same exact problem with my goodman-it flashes code 4-for open high limit fault-pls someone help with this
    Problem Solver:
  • 15 Answers
If your igniter comes on but no ignition, that eliminates the possibility of a bad or clogged pressure switch, high limit or flame rollout switch. Sounds to me like you have a control board, or a gas valve going bad. Could even be some loose, corroded, or faulty wiring. Before the igniter comes on the furnace does a self diagnostics to ensure everything is working, or the furnace will not make it to the igniter sequence. Inducer motor, pressure switch/s, limit controls are closed…then comes on the ignitier, gas valve opens, pilot runners and burners ignite, flame sensor detects the flame, blower comes on and all operations are working.
Hope this helps
Posted on Dec 02, 2008
Bradford White gas power vent water heater; just replaced power vent motor and fan assembly because a bearing went out. Now the new fan motor runs constantly without igniting. Is there a switch that...
Some how you have disconnected the sensor that tells the main burner that the fan is on. Its trying to light but cant. On some models there is a air pressure switch that reads the pressure inside the vent pipe itself. It will have a small hose on it and if that has cracked or was not replaced it wont light. This is how its supposed to work--- vent fan comes on,sensor confirms fan is on,hot surface ignighter starts to glow red,and main burner is opened,another sensor confirms that main burner is lit,then hot surface ignighter turns off. Hope this helps.
Jan 11, 2013 | Water Heaters
Ignighter lights but doesn't seem to be getting fuel. Heater has fresh kerosene, I have check fuel intake hose and aire intake. All seem ok. During the time the ignighter lights, the fan blows but shuts...
Clean the photo eye,it is right near the flame,clean it where the eye can read the flame,if it can not read the flame ,the unit will shut down.I have a pdf file I can send you for this ready heater,let me know,and give me your e mail so I can,thanks ronicon,,,,roniecon@gmail.com
Dec 21, 2010 | Reddy R70ET Utility Heater
Heater wont light fan run then shut off
If this is a gas furnace,check to see if the igniter is glowing, if not it
very well could be cracked.
Jan 05, 2010 | Dayton Heating & Cooling
My pentair minimax heater wont fire. The ceramic
If you can see the ignitor glow it is probally a gas supply problem. If you have continuity and it dosen't glow it is probally a voltage problem. They did have one model out when they first brought these out that needed a 110v ignitor and you will probally have to go to the factory help line for this info you will need serieal numbers from the heater and model numbers also. Then if this is the problem you will have to order parts from the factory as they are rare on the market. But it sounds like gas pressure or feed if you have good cont. and you have run the heater before. You should check your gas orfaces for tiny, tiny spider webs in the gas orfaces and soot on the burners. It's hard to cover it all with little info but I hope this helps. Good luck.
Oct 17, 2009 | Pool & Spa
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
Pilot light is on but burner will not come on
You may need to replace the ignighter!...easy fix! or what it really sounds like is your thermastat
Dec 10, 2008 | Goodman GMS90703BXA Heater
I am working on an older reehm furnace a corsaire.
either the sensor is dirty or bad,clean the sensor first if that doesn'y work replace it
Nov 21, 2008 | Heating & Cooling
Dryer Ignitor turns on then back off with no flames afterwards
the government mandated that gas appliances start using electronic ignighters because pilot lights would keep blowing gas even after they blew out now the way they work is calibrated on how much amps the glow bar draws the rest of the amps go to the safety valve to open it when the glow bar is drawing enough amps to be hot enough to ignite the gas now what this means is even though the glow bar glows it can still not be hot enough to ig night the gas so the safety valves don't get the right amps to the solenoids to open so you could have a weak ignighter or bad solenoids on the safety valves now i would lean toward the solenoids but i would buy both and first replace the solenoids then the ignighter if the solenoids work take the ignighter back
May 22, 2008 | Kenmore 74602 Gas Dryer
Please HELP
www dot desatech dot com is a parts distributor for reddy heat products. on their main page they have a short troubleshooting guide. the motor needs to provide 3.5 psi of air across the fuel nozzle to suck the fuel out of the reservoir. check your ignition source (spark plug, hot surface igniter) if the hot surface igniter is broken get a new one, if the spark plug don't spark, check the gap might be too big. see if the spark plug is grounded. poor grounds will cause intermittent sparking. check the high voltage wire for breaks in the insulation, might be shorting out to ground BEFORE the plug. gap should be 75 thousandths.
Dec 04, 2007 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
340 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
