Question about Sony CD Radio Cassette Boombox, CFD-E90 White : CD Player
I need a hard copy manual for Sony CFD-S150L Cd Radio Cassette
My father has lost his manual and would very much like a hard copy manual.
Many thanks
Kurth
  • 86 Answers
SOURCE: Play mode
Tape the play button down (better if you have a repeat button) I have done this and used a marble under the tape to simulate a thumb-like pressure imitation
Posted on Apr 11, 2008
SOURCE: How to preset a radio station on Sony CFD-S200 Cassette/CD boombox
You will need to use the Forward and Reverse buttons on the CD player. Set the station by holding the button you want to set it to until it blinks and shows the station number.
To set more that 10 stations. Press the (>10) button and then enter 11 or 12 or so on and set the stations the same as above.
Posted on Jun 12, 2008
SOURCE: Need replacement power cord, might be part HCJ SU-7P.
i have one
Posted on Sep 02, 2009
SOURCE: CD player says "no disk" when there is disk in player.
My CFD-f10 showed "no disk" after not being used for a few months. Before that it began to stick or skip toward the end of the disk. The trouble was the drive mechanism was failing to move easily due to poor lubrication of the CD drive mechanism. It can be lubricated, but the job is difficult. The top must be opened. First unplug from 120 V and also remove all 6 D batteries, then take 7 screws out from the top. One is under the Tape lid. Two are under the CD lid. Four are along the back. Also take out the screw from the bottom that holds the antenna. There are little arrows next to those screws. Do not take out any more screws than those. Gently lift the top, which includes the CD and tape lids, from the rear while moving the top a little toward the rear. It will seem very tight at first. Do not force it, but keep gently prying. There are circuit boards close to the seam, so do not pry open with long tools. The rear will lift up about 1.5". The handle stays attached to the bottom. Then the flat ribbon cable must be pulled from the ivory socket. The ends of the cable stick into the socket. The socket remains on the circuit board. As the top is raised further, unplug the cables preventing movement, Carefully note where they are plugged in. After the top is opened about 90 degrees, leaving the tape drive still close to the bottom cabinet, remove the 4 CD drive attachment screws with metal washers at the colored rubber washers and also the cable. Now the CD drive can be removed. With very fine synthetic clock oil, I lubricated the end of the motor shaft, (lift the plastic cover a little by unclipping the little snaps.) Very gently operate the mechanism by pushing on the larger gears. Sony had lubricated most, but the lub must have gotten thick with age. Put a little synthetic oil wherever there are moving parts. By turning the gears by hand, you will tell if all is working freely. Then carefully put all back together. Yes the CFD-f10 now does play CDs again!!! I do not know for how long. (Sony style outlet online is selling the newer refurbished CFD-S350 silver boom boxes for about $37.00, which also uses the more desirable 6 "D" batteries, and comes with remote. I have one on order.) The synthetic clock oil can be obtained from any company selling jewery or clock parts, but it is quite expensive, easily half what the refurbished CFD-S350 costs.
Posted on Jan 16, 2010
  • 4 Answers
SOURCE: Sony RCD W500C - How do I copy from a cassette
Insert the out puts from the cassette into any input jacjk in the back of the sony. Put on analog record. Start play on cassette with a blank disc in the record well of the Sony and press record. Its done. It is no different than recording an lp.
Posted on Mar 09, 2010
Need a relacement anntena for sony cfd-s22
Radio Shack is the only store that carries a variety of antenna's, but not sure if they still do.
Apr 12, 2012 | Sony Boom Box With CD Player & Cassette...
Need user manual
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDE90&LOC=3
here is the manuel.
thanks for choosing FixYa
May 28, 2009 | Sony CD Radio Cassette Boombox, CFD-E90...
Manual for sony cfd cd radio cassette recorder
javascript:moreinfowindow('http://www.docs.sony.com/reflib/docget.asp?manualid=16656&template_id=1&region_id=1&DL=',600,560,10,10,'Manuals')
Jul 28, 2008 | Sony CFD-G500L Cassette/CD Boombox
Mar 31, 2008 | Sony CFD-S200 Cassette/CD Boombox
Sony CD Radio Cassette Boombox, CFD-E90 White : CD Player Logo
116 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
