Question about Acer Aspire 3004WLCi Notebook
3004 wlci Need a new battery. My battery gets so hot and causes my laptop to malfunction. I checked and my battery is not eligible for the replacement program. Any suggestions where to get new battery and possibilty to get one that holds a charge for longer than 1 1/2 hours?
  • Acer Master
  • 4,338 Answers
Here are sites that carry a replacement:
http://www.google.com/products?hl=en&q=Aspire+3004WLCi+battery+replacement&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 30, 2008
My joer battery operated glue gun isnt getting hot but the batteries. Are red hot?
You may need a new one. Sounds like a malfunction causing the batteries to overheat, which could be dangeroua
Dec 20, 2016 | Crafts & Hobbies
Not power on
Your Pavilion DV6000 laptop is the key to your productivity, which is why it is essential that it turns on when you need it. The DV6000 is lighter than comparable models from other brands, and has a large, sharp display. While it has plenty of processing power, the DV6000 can have normal boot problems as well as problems caused by faulty battery packs that were installed in some units. Attempt to troubleshoot the laptop and find out if the laptop is eligible for a new battery pack.
1.Hard reset your laptop if there is no life at all. Unplug all peripheral devices and remove the battery. Unplug the AC cable and press and hold the power button for at least 15 seconds to drain all power. Reconnect the AC cable and hit the power button.
2.Verify that the battery pack is on the recall list if the laptop powers up without it. Fill out the form on the battery pack recall website (http://bpr.hpordercenter.com/hbpr/). You will have to input the serial number of the battery pack as well as a location to ship the replacement battery if you are eligible.
3.Hold the AC cable where it plugs into the laptop and wiggle it while hitting the power button one time. LEDs that come on and off intermittently indicate a faulty power cable. Order a replacement power cable through HP or a third-party vendor.
4.Write down any visual or audio error codes such as LEDs blinking or unusual beeping. The error sequence will be helpful when talking to an HP support person.
I hope this may help your concern.
Jan 22, 2011 | HP Pavilion dv6000t Notebook
Battery not charging
As you have tried to replace battery and still new battery is not getting charged in this case it seems there is hardware problem. Circuit which allows battery to charge is not working.
Apr 29, 2010 | Acer Aspire 3000 Notebook
Remove the hard drive in a acer 1690 wlci laptop
on the bottem are one or 2 srews this wil release the cover for the hard disk if removed place thin schrewdriver and lift up on serws hole and the disk are also with srews hold on his place look out befor you buy a new one there are diferend syses for the hard disk one fits the other are larger in hight
i hope i helps you with the explanation for it
Mar 10, 2010 | Acer Notebook
Acer Aspire 3003 wlci laptop. Uses Aspire 3000 display. Problem: part of the display has a black bar on the screen. You can still see through it though. I hooked up the laptop to an external monitor. No...
i think you have the ability to check your laptop and the only i can suggest to you is you have to check the backlight section of your laptop cause there might me cold solder parts that cause the dark side of your screen.
Oct 05, 2009 | Acer Aspire 3000 Notebook
Need to repalce an os
You can, you can even get a free operating system such as Linux. Puppy Linux and PC Linux are probably the 2 easiest ones to use.
Apr 04, 2009 | Computers & Internet
Acer aspire 3004 WLCi won't power on
Often times when laptop won't power on, it's jack on the back where the power supply plugs in. It needs to be disassembled, soldered back together and that should fix it. Good luck!
Aug 22, 2008 | Computers & Internet
I am not getting audio from my Acer 3004 wlci
Check Audio Codec in Device Manager under sound and game controllers.They might be disabled.
Aug 13, 2008 | Acer Computers & Internet
Start up
If the Computer In question is a PC Desktop computer a few issues. First power supply may be malfunctioning. Second check the the CPU fan inside computer is running and not full of dust when you turn it on. If it's dusty, get vacuum cleaner and clean it. Fans need to be able to work without overheating because CPU runs hot.
Thirdly try to take out battery and restart computer. If starts up replace with new battery.
In Case it's a laptop. Take out battery and try to run using power supply and if turns on place battery back in. If battery isn't charging you will need a new battery. Let me know how you go!
Aug 03, 2008 | Computers & Internet
Total Novice
the acer 3003wlci is better its got 512mb and the other one has only 256mb the wlci has a 60gb hardrive and the other one has only a 40gb hardrive the wlci has a better graphic card for games more features and a better operating system also is good for its price i say if you were going to by one of them the wlci would be the best choice
Jan 02, 2008 | Acer Aspire 3003LCi Notebook
Acer Aspire 3004WLCi Notebook Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
