Kenmore top load washer counter balance spring
I don't know exactly where my counter balance spring goes in my washer, it fell off, maybe broke off.
There's a nice picture here.
Posted on Feb 20, 2009
Were is the counter balance spring
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section covering the base and you should see where the springs fit.
Also see the following Whirlpool PDF Parts list with diagrams and part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Apr 10, 2010 | Kenmore 24902 Top Load Washer
Kenmore Oasis top load always out of balance and bangs
First just to let you know, the oasis is very sensitive to the load level and water ratio if its too heavy the load has to be perfectly balanced inside the tub. Next check to see if any of the straps are broke. The next thing is that the newtator has tighted up all on its own so when it spins the newtator grabs the tub while it spins at high speed. I have never had to fix this but i know it is a common problem. I hope i helped a little. Good luck!
Jan 14, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore mdl 10022622100 goes out of balance
to cause unit to go off balance taking in fact that you put clothes in washer even...check your counter balance spring it hold the tub to base at rear of unit,,,and check your balance ring at the top of your wash basket its fill with water if cracked will cause this problem,,
Dec 24, 2008 | Kenmore 22422 Top Load Washer
Kenmore Series 80 wobbles when spinning
the basket is attached to a triangular brace that must match up with the frame it sits on.
Dec 19, 2008 | Kenmore 24032\24036 Top Load Washer
My washer leaks occasionally from the back
ok i need a lilttle help from you,,,ok,,,open lid..take your hand and put it on the top of the agitator,,push the hole agitator and tub back,,and let it go if the tub stays back and does not come back center by its self,,your counter balance spring broke,,no mattter which way you push that agitator it shoud come back to near center..what could be bad counter balance springs ,,or tub surport springs.if you need help removing and changing please post
Dec 03, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore top load washer 92573210
4 springs on bottom of washer 3 from tub to top of base hidden, 1 from rear tub to bottom of base straight down, hole in inner lip of base, to counter weight of motor.
Nov 19, 2008 | Kenmore 22642 Top Load Washer
Drum out of balance
There are a few things that can cause this issue.
1. The counter balance spring broke or the mounting hole for the spring rusted through.
2. One or more snubber pads may have come off.
3. The suspension springs may have stretched or broke.
Start by removing the shell as follows:
A.) Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward.
B.) With console lifted you will find a lid switch connector (white in color). Unplug the switch from the connector.
C.) There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
D.) Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
1.) The counter balance spring is located in the bottom rear. It should be attached between the cabinet and a bracket on the tub.
2.) Inspect snubber and corner pads. May be brown or white in color.
3.) Inspect suspension springs.
If you need further assistance, let me know
Regards,
reg501
Jun 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer
3. The balance ring may have come loose from the basket or the ring has been damaged and the fluid has leaked out..
A.) The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw.
3. Remove tub ring by pushing down then lifting each locking tab.
Inspect balance ring for proper fit and any cracks. By moving/shaking ring you should hear liquid sloshing around.
Regards,
reg501
The FixYa Team.....
Jun 26, 2008 | Kenmore 15864/15862 Top Load Washer
Whirlpool LSR8233EQ0
Check base mount springs, there are 3 from base to tub and 1 from tub to back bottom for counter balancing. If all are ok then you will have a skid plate problem. Best to call for help.
Jan 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
686 people viewed this question
Top Washing Machines Experts
