Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Image is blury it comes and goes.
Already tried another monitor and it works on my computer. So it is not the sound card.
What is that bigger diameter on the monitor's cable about 6 inches from the computer. Is there a fuse in there?
Please,help!
Thanks
Eduardo
Lake Forest,Ca
  • walopalo Dec 03, 2008
    It started working again without adjustments....Thank you for the advise
    Walopalo
    Champion:
  • 293 Answers
Hi...there,
Try open your on screen display and set the Image settings to 50% on Pixel and 50% on Phase
Posted on Dec 01, 2008
When I try to switch the computer on Monitor says "vga input: no input signal" then it goes to sleep and yes, i have already checked that all the cables are in place
the problem may be with the vga card or the desktop see the desktop is working wether it work check that or if u have a laptop try to connect the monitor to the laptop and see if the display comes on the monitor of the laptop by this you will come to know about the problem is with the monitor or the pc
Nov 15, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor comes on for 2 seconds then goes blank
Check if the cable connecting your monitor from the video card is properly secure and not loose...
You can also try this... turn off your cpu..remove the cable from your video card.....Open the housing....remove your video card from your motherboard... clean the contact surface of the video card with moisten cloth.... after cleaning...connect the video card to the motherboard...attached the cable to your video card.. close the housing and try to boot again...
I hope that work.. if not my suggestion is you try your video card in other computer, try also the monitor to other computer.. to see which one failed.
Much appreciated if you rate this help.. thanks..
May 23, 2010 | Samsung SyncMaster 920NW Monitor
Blurred image in Samsung Syncmaster732nw monitor
For best pictures, you need to set your PC video resolution to the native resolution of this monitor, which is 1280x1024 @60Hz. Try that first before opening up the monitor to look for bad components.
Post back, see what usually goes wrong with SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Very fine hotizontal black lines are appearing and the text starts to melt. The cursor doesn't work at that point. Finally it goes black and comes back by it self. I put in a new graphics card and it was...
Try a different monitor on the computer, then if needed try another video card, then if you still have the same problem then that means the motherboard is the problem.
Nov 28, 2009 | Computers & Internet
Everything is blury have to set screen resolution to 800by600 pixels to try too make any thing out.
Connect the monitor to a laptop -- is it still blurry?
If so, then the monitor is the problem.
If not, then your computer (the video-card?) is the problem.
Oct 31, 2009 | HP Vs17 17" LCD Flat Panel Monitor
I have a gateway 383gm its worked fine for the past 4-5 years and the other day i turned it on and the monitor wont come on. I hooked the monitor up to another computer and it powers on fine (so monitor...
Have you already tried removing your memory card stick?If not, then remove the memory and then the pins of it using an eraser of a pencil and then put it back on..,reset again the bios and be sure to connect all the cords correctly of your computer and then power on. Hope this could help you.. Thanks..
Oct 23, 2009 | Gateway 838GM (RB838GM) PC Desktop
Monitor wont read the harddrive
First (and I am sure you have already checked this), I would make sure all cables are connected and all power cords are connected. If the monitor comes on but there is no image I would try to use the buttons on the front of the monitor to adjust the brightness and contrast and see if this fixes the problem. If neither of these solutions work, then try a different monitor. If you try a different monitor and still it does not work, then something may be wrong with your video card inside your computer and either the video card will need to be replaced. Or you may need to buy a video card if the monitor plugs directly into the motherboard (big circuit board inside the computer). Hope this helps.
Aug 23, 2009 | Gateway Computers & Internet
Connected my Samsung 206bw to my new computer using a DVI cable and I have faint (but very noticeable) vertical lines similiar to brush marks in paint. The computer is a Vista Home Premium 64-bit, Intel...
try using a ifferent dvi cable.if that doesn't work then try a different monitor.if those don't work then it migh be the onboard dvi connecter on the comp.are the images there all of the time or when the computer log ons.disconnect the monitor and see if the lines are there.if so then it is burnt in image on the screen.if not it is something vista is doing to the screen.
Aug 09, 2009 | Computers & Internet
LCD Monitor
Hi rhymers3,
First, check that monitor power save is disabled. Right click on desktop, properties, Screen Save tab, power button. Select "Never" for the "Turn Off Monitor" drop-down box.
Also, check that the monitor itself doesn't have any power save/ sleep options enabled.
Another possibility is a faulty graphics card or faulty cable to the monitor - try moving the cable/card and see if the image comes and goes.
Try using a different (lower) display resolution. It could be that the one you currently have is just on the limits of not working with that monitor.
Good luck.
Jul 06, 2009 | Computers & Internet
Computer turns on but i have no image on monitor
If your monitor is working, try taking all add-on cards out of your system to see if your monitor comes on. (Sound cards, modem, Network cards, etc.) If after doing this you still get no picture, very strong possibility your video card (on-board) is bad.
Feb 02, 2009 | HP Pavilion a620n (PC028A) PC Desktop
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
46 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
