Question about LG WD-16110FD Front Load Washer
Disolved lettering on fornt of LG washer
Help! The print on the front of my 6 month old LG washer has dissolved because it got detergent on it. I can't tell water temp,cleaning options etc. I called LG and they don't cover "cosmetic damage". I labeled the areas with a sharpie. Anyone have any ideas. LG didn't.
I have run into the same problem with my LG microwave oven/toaster. The did a poor job protecting the silk screened legends for the controls. I made my own labels. Avery makes label material that you can print on your ink jet printer. It's not crystal clear, but at least I know what button to push. Avery 8665 Clear Full Sheet Labels. Available at Staples and other stores.
Posted on Nov 30, 2008
My 6 month old Whirlpool duet front load washer will dispense detergent but will not fill with water or spin. The timer stays the same # of minutes. What is wrong?
Check Owner's manual. If there are no troubleshooting clues, look for a customer service number. There should be a warranty if only 6 months old. If no fix I'd go that route.
Feb 18, 2015 | Whirlpool Washing Machines
Various questions re operation of LG Washer
In general, you do not need to dissolve powders before washing. In some cases, you can alter spin speed but not time.
Nov 22, 2013 | LG Washing Machines
I've got an LE code on the front of my washer
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jul 06, 2011 | LG WM2301HW Front Load Washer
Mildew smell from LG washer after use
There is a cleaner that needs to be run through the machine at least monthly. VERY common issue.
Apr 11, 2011 | LG WM2050C Front Load Washer
MY LG WASHING MACHINE KEEPS FLASHING AE AND AN ALARM KEEPS GOING OFF
Have you tried cleaning your washer? I had a similar problem before and it is mostly caused by my brand of powder detergent. Detergent residues somehow confuses the functions of the system. I switched to an HE liquid detergent.
You can try cleaning your washer. Run an empty hot water cycle and add one cup of distilled white vinegar. It will help dissolve detergent residues as well as molds and mildew.
Source: http://www.washingmachineadvisor.com
Mar 31, 2011 | LG WM-2277HW Front Load Washer
Shows OE error. Won't spin
if its only 6ths old call out the manufactures.
Sep 28, 2009 | LG WM-2277HW Front Load Washer
Moldy smell in washer and on towels, etc.
Sorry to say but your washer will need a complete tub tear down to clean out the odor.  The reason this has happened is because of excess detergent usage.  It's not mentioned in the owner's manual but most manufacturers say to use only 2 tablespoons of detergent per wash.  But since most people are used to putting in a lot of detergent, the excess suds has stuck the upper half of the tub assembly and the front loaders are not designed to rinse that off.  You will need to call a repair technician to have the unit completely torn down and cleaned out properly.
Aug 06, 2008 | LG WM1814CW Front Load Washer
LG WFT851 - Flakes of dirt problem
try putting some milton or baby bleach into the machine with the hottest possible wash with no clothes with the highest water level
Jul 14, 2007 | LG WFT1071TP Top Load Washer
LG WD-16110FD Front Load Washer Logo
110 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
