Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Replacing the element in a diplomat 5706 cooker
Please can you give me instructions on how to remove and replace the element on a Diplomat APL 5706 Cooker. I have removed the rear plate to expose the element and fan, but i cant release the existing element to release it
  • s_howarth903 Dec 01, 2008
    Thanks barkencoa your advice was just the job. The ovens now fixed. Thanks again
  • Jenn-Air Master
  • 3,463 Answers
Hi.
You will probably have to remove the rear panel of the oven, this is on the outside that I am referring to, and you will see the 2 securing scews for the element, you might have to push the insulation to one side to see the screws.
This should solve your problem.
Please good feedback if this helps.
Thanks.
Posted on Dec 01, 2008
Flavel milano e60 how to fit new fan oven element that is riveted
That is complete RUBBISH the screws are accessible from the rear of the oven. At the back remove the screws holding the plate and you will see the element housing. Remove the two screws and the spade connections. Get someone to hold the new element in place for you and attached the screws. Fiddly job so be patient. Connect the spade connections and replace all plates front and rear. Should be the job!!! Someone hold the element in the cooker whilst someone connects at the back. Whatever you do, DON'T TAKE A DRILL TO YOUR COOKER!!
Dec 13, 2012 | Ovens
I have a Diplomat 600 fan assisted oven. When switched on, the fan can be heard running, but the oven does not heat at all. Any ideas please? Is this likely to be expensive to rectify?
Hi.
It is going to be a faulty oven element.
Remove the cover at the rear of the oven compartment, and see if there is a round heater element there, if there is, then it will be the element that needs to be replaced.
If no element there, then it will be either the top element of the oven , or rhe base element which is not visible, that is faulty.
If there is base element, then it can only be accessed from outside of the main oven by removing the outer panels, and is located at the bottom of the main oven.
Hope this helps.
Mar 11, 2011 | Ovens
How do i replace the heating element in a diplomat aca3200 oven?
make sure the oven is switched off.remove all trays etc from oven,remove 2 posidrive screws from bottom of fan plate,remove fan plate,the element is around the fan,remove 2 posi screws from where the element goes through the side of oven and the one screw that holds the top of the element to the back of the oven.slowly pull the element out and remove the 2 poz and neg spade connectors.refit as removed.
Dec 30, 2010 | Ovens
I have a zanussi built in oven model no zbf 860b which the fan is still working but the oven is no longer heating up?? Thanks
If the red light is coming on when you turn on the oven control then the thermostat is ok.You will need to remove the grids from inside the oven then remove the inside rear panel 4 screws, be carreful not to damage the thermostat as you remove the panel.When you have removed panel you will see the ring element,now remove the 3 screws holding in the element and gently pull it towards you,remove the 2 cables off element but do not let them fall into the back of cooker or you will have to remove the cooker and gain access to the rear of the cooker.Once you have element check with a multi-meter for continuity and replace if blown. Relacement is a reverse of removal.
Hope this helps.
Aug 04, 2010 | Zanussi Ovens
Are the oven ellement retaining screws secured
If there is no slot for a screwdriver or cross point screwdriver, then, yes, it will be secured from the outside of the oven.
It will mean removing the rear panel, and possibly the top as well.
Hope this helps.
Feb 06, 2010 | Jenn-Air JJW8530C Expressions Collection...
I have a Hotpoint EW86X Electric cooker, I went to change the element and one of the cables that connects to the element disappeared down the back of the cooker, any ideas of how I can get to the cable?
Only by removing the rear outer panel of cooker, this will give you access to the element terminals..
If it is built in, then it will have to be removed from the housing.
Hope this helps.
Jan 12, 2010 | Hotpoint Ovens
I have moved into a property that has a diplomat cooker. I am looking for instruction booklet for it can you help
Diplomat are no longer trading. These appliances where fitted with MFI kitchens who have also gone
Oct 19, 2009 | Ovens
We have a hotpoint cooker UY46, our electric tripped the cooker off and , now the nob and grill works but the bottem/main oven is turning on and the fan is circulating but not getting hot ? please help ;(
You need to replace the element. Very easy job remove the back plate from inside the oven (4 screws) and you will see a circular element held in place by one screw in the centre of the fixing plate. Remove the fixing screw then remove two wires and refit new element job done.
Regards Neville
Jul 16, 2009 | Neff U1721 Double circotherm Electric Oven
B1641 Fan Element Renewal.
If you can see the element once you have removed the inside rear panel, then remove any screws that you can see, and ease the element forward, pull the wires off, but do not let them slip behind the rear wall of the oven, or it means removing the whole oven, to fit the wires back on.
If you cannot see the screws, or they are fastened from the rear, then it will have to come out of the housing.
Hope this helps.
Please leave feeedback.
Dec 05, 2008 | Neff B1641 Single circotherm super...
Beko DCC4521
almost certainly the element. take the back panel off inside the oven and the element is exposed. often you can see the damage. if you want to go further and repair yourself, then get back to me
Sep 04, 2008 | Ovens
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
469 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
