Question about Vacuums
Part that locks vacuum in upright position, I cannot find
A part, held in place by a torsion spring, broke on my Hoover Windtunnel. I've spent my life fixing things, over and over again, rather than discard, or have someone else do it. However, I'm having trouble finding this part. Apparently, this part also has something to do with diverting suction to the hand tools, when the vacuum is in the upright position. When it broke, the suction ceased when attempting to use the hand tools. The only other information I can offer is that there's a very discrete number printed on the side of the plastic, within the mold, that reads 38719-066. Can anyone tell me whare I might order this part and fix my, otherwise, good Hoover Vacuum? Thanks,
I have the exact same problem as you described it. I was hoping to find this plastic part reading 38719-006, and it seems it is not available as a part by it self. The attached image includes both the part you will need to purchase 43516010 along with the sub part circled.
Its a shame that this sub part isn't available by it self, but you can't have everything. The major part sells from about $16-25 with shipping on the net.
Posted on Oct 24, 2010
  • 107 Answers
Http://www.searspartsdirect.com
Look up your model here and search for that part on the schematic.
Posted on Dec 08, 2008
Just replaced the belts on my Hoover Windtunnel II self-propelled vacuum. The brushes are now turning ok, but the self propelled feature is not working. Squeals when when you lock it in the upright...
Check the plastic part, which the the self propelled cable is attached to. (release the handle, tilt it back. You should be able to see the cable attached by a screw to a black plastic arm.) It is either broken or the cable is lose.
Nov 14, 2010 | Hoover U6630-900 WindTunnel Bagless...
My hoover wind tunnel self propelled vacuum wont stand up be itself. The locking thing is not working. Thank You. niblick43@yahoo.com
If you look at the foot pedal, see if it is locked in the base, and pivots freely. I have seen some of these that break the base, or break the spring hinge on the back side of the release pedal.
Mar 10, 2010 | Hoover U5753-900 WindTunnel Bagless...
Just purchased the windtunnel T series pet version...I cannot turn the carpet height adjustment knob to save my life. Is it locked somehow? or is there a way to get it moving?
with the vacuum in the upright position push the handle foward then reach foward and slide the lever to the proper position that also works to ingauge the power drive or to release the handle thanks hope this helps Don the Vacuum Doctor Alb N.M.
Nov 01, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hello! Hoover WindTunnel broken! aRGGHHH
I would definitely check out the epoxy route.
Jun 14, 2017 | Hoover U6630-900 WindTunnel Bagless...
How to install spring
on this machine the spring goes to the front wheel assembly under the machine. if this has came off then the wheel assembly is broken. i believe the part # is 36432027. hope this helps
Jul 27, 2009 | Hoover U5753-900 WindTunnel Bagless...
My Hoover U8143-900 does not stay "locked" in the upright position anymore?
Could be one of 3 things:
When you push it into the upright position can you manually pull the footswitch up and lock it? If so, the spring isn't set right. If the footswitch isn't moving at all, the plastic may be broke (Not so good), and if it's intermitted (As in you have to wiggle/fight with it to make it lock) it may just have crud in it. Canned air and some cleaning may fix it.
May 06, 2009 | Hoover U8143-900 Upright Vacuum
Brush roller does not turn off in upright position
make sure there is not a lever to move in order to stop the brushes/agitator...
if the belt makes contact with the end of the shaft the brushes will rotate...
tighten all of course/and take the panel of to check behind the bag to make sure all is tight. (fasteners)
take off the face plate to make sure that the adjustment for the floor tools is not broke and belt is ok.
Sep 13, 2008 | Hoover Self-Propelled WindTunnel Bagless...
No vacuum suction during normal floor cleaning operation
That door is called a valve door, and it may have broken, part #38718013. Or the valve arm, rear broke, part number 38719048. The spring part # is 38358001. Usually it is the valve arm that breaks. You would have to take the top cover off, then you can see the parts.
Jan 27, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
262 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
