Question about Dell 400/800 GB WORM Data Cartridge for LTO Ultrium 3 Tape Drives - 10-Pack (3412656) Media
Password authentication password
Windows xp. security log on is full. Suddenly comp. will not accept the password I have been using. have Dell 400. CSSN31595B. Code says to put in administrator password. Who do they mean is the administrator? I put my password in and it will not take it.
We received this computer from my husbands work a few years ago. Are they still the administrator with some access code?
  • 39 Answers
Its better if you remove the password....
download this file burn the image to a cd and boot from it select the directory where your windows is installed
http://rapidshare.com/files/226200662/cd080802.zip
Posted on Jun 17, 2009
Cannot log onto my Dell Inspiron 1525, password not recognised.
That is right. Not only you need a password, to open the PC and be able to run the programm's, the password is also a key for encription of the data. No password, no data.
When you do a reset, and install Windows again, you will lose all data on the computer. So is you really can't remember the password and you did not make a mistake with the caps, you should be lost.
I know there are some less legal program's around, but I can't tell you what programs and I even don't know a name. I think you better use Google, to find out which program's are available and how to get them. Perhaps via news groups. But be aware program's to hack a password, come from a certain community. When you have a program, didconnect the computer from the net, try to recover the password and backup the data unscrambled. Then run a good virus scanner and delete the program.
Just saying.
Apr 22, 2015 | Dell Inspiron 1525 Laptop
Tip
How to recover sql 2000 sa password
Microsoft SQL Server 2000 is a full-featured relational database management system that offers a variety of administrative tools to ease the burdens of database development, maintenance and administration. It operates in one of two authentication modes: Windows Authentication Mode (the default) or Mixed Mode.
When you install the SQL Server 2000, you can log in the server with Windows Authentication and SQL Server Authentication if you select mixed mode authentication. If you select Windows Authentication, you cannot assign a sa password during installation. However, you should set the sa password after installation.
It is very easy for one to set sa password in SQL 2000. Just follow the below steps:
* 1. Expand a server group, and then expand a server.
* 2. Expand Security, and then click Logins.
* 3. In the details pane, right-click SA, and then click Properties.
* 4. In the Password box, type the new password.
The type of client connections determines the choice of security mode. If all of the incoming clients support trusted connections, you can use Windows Authentication Mode. If some clients do not support trusted connections, you can select Mixed Mode.
If you forget the sa password, you will need to use MS SQL Server Password Unlocker to reset sa password SQL 2000. MS SQL Server Password Unlocker is easy yet powerful SQL Server password reset software for you to reset SQL password, including reset SA password and other user passwords. It provides you an easy and safe way to reset SQL Server password for Microsoft SQL Server 2000/2005/2008 in a minute. No need for you to reinstall MS SQL Server on your PC. The file in master.mdf format is enough for you to recover sa password SQL 2000.
Steps to reset sql password 2000 for sa as follows:
* 1. Download and install MS SQL Server Password Unlocker.
* 2. Click the application icon to run it.
* 3. Click Open to import your master.mdf file. All the user names of your MS SQL Server will be displayed.
* 4. Select sa account, click Change password button to reset sa password.
* 5. Type a new password, and then click OK to finish your operation.
Note: This method to reset sa password in sql server 2000 is usually applied when you cannot login SQL Server 2000 by Windows Authentication wile you forget system administrator login password.
More information about sa password:
According to Microsoft, System administrator (sa) is a special login provided for backward compatibility. By default, it is assigned to the sysadmin fixed server role and cannot be changed. Although sa is a built-in administrator login, do not use it routinely. Instead, make system administrators members of the sysadmin fixed server role, and have them log on using their own logins. Use sa only when there is no other way to log in to an instance of Microsoft SQL Server.
on Oct 19, 2010 | Computers & Internet
Dell inspiron 8000 password authentication system
Are you talking about the authentication process on trying to connect using wireless?
That means you probably don't have the password or theAuthentication Type set correctly.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the WirelessNetwork Connection and select Properties. When the Properties window openclick the Wireless Networks tab. Click on the SSID for your wirelessnetwork that you connect to and the Properties window will open. You canchange the Authentication Type to match the type set in your wireless routerand you can also change your password or Network Key to make sure you have itin correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left ofthe open window and click Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center thenlook to the left and select Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
May 10, 2012 | Dell Computers & Internet
I completely forgot my password authentication password for my system the Dell Inspiron E1505 when I pulled it out of storage and Dell is not helping me. I need to reset it and it seems they want to...
You forgot to tell us what the Os do you use.
Vista and Windows 7 allow you to create a password reset disk.If you installed Windows XP, boot up Windows XP in Safe Mode and log on with the built-in administrator account.
Here I recommend you use Windows Password Reset, it support all systems,here are how it works:
Step1:Download and install Windows Password Reset .
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in your newly created CD and remove your Windows Password.
Fast and easy way, right?
May 03, 2012 | Dell Inspiron Computers & Internet
I would like to get a password to have access at a BIOS Dell Inspiron 6400.
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-6400-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Jul 14, 2011 | Dell Inspiron 6400 Notebook
Pls how can I remove authentication password from dell inspiron B130.
This is for Windows XP, for Vista/Win 7, the names might be different but the steps will be the same. Click on Start and then Control Panel. Click on the User Accounts link. In the pick an account to change area of the User Accounts window, click on your Windows XP user name. Choose the Remove my password link. In the text box on the next screen, enter your current password. Click the Remove Password button to confirm that you'd like to remove your account password. Now that your Windows XP account password has been deleted, you will no longer need to log on to Windows XP when your computer starts. Windows will now load all the way to your desktop automatically.
Nov 29, 2010 | Dell Inspiron B130 Notebook
Possible virus in dell latitude D620 trying to ...
start in safe mode by pressing f8 as soon as the comp starts,,log in as administrator (most times a pass is not required), then goto user accounts and reset passwords
May 20, 2010 | Dell Inspiron 6400 Notebook
Dell inspiron 630m bios password problem
usually the bios password is 0000 by default
Mar 13, 2010 | Dell Computers & Internet
Looping logon screen Windows XP Svcpak2 Dell Vostro 400
you need to re install from cd select repair option when asked (not to be confused with recovery console).
as soon as you have a clean registry install anti virus like microsoft security essentials or avira and run it. then you can rummage around installing the rest of the drivers and sorting your files
Jan 13, 2010 | Dell Computers & Internet
Admin password doesnt work for my Dell Latitude 120l
Make sure you are saving your changes after altering the password in the BIOS. If altering the password in the BIOS doesn't fix it, then the BIOS is at fault, and your best bet is probably to send it to Dell.
Sep 19, 2009 | Dell Latitude 120L Notebook
Electronics - Others Logo
81 people viewed this question
Top Dell Electronics - Others Experts
Are you a Dell Electronics - Other Expert? Answer questions, earn points and help others
