Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Green dot on inside of screen
I have had our tv for 2 years and have noticed a green dot on the inside of the screen. Is this dust? Can it be cleaned? Can I remove the screen and clean it or should I get a Technician to clean it? HELP! The dot is annoying the H--- out of me! i have an HDTV (SONY BRAVIA KDL-40W4100), and it has a little green dot inside the screen. can it be fixed anyhow? Can anybody help me with a good advice please?
  • SuperT25 Dec 17, 2008
    I have the KDL 40S3000 and that green dot just showed up a couple of days ago, is it possible to fix it?
  • 58 Answers
Its a dead pixel. its not fixable, and deos not even qualify as a defect as its just one.
Posted on Dec 06, 2008
I have a problem with the colour prints...there are different kind of lines all over the page..how can i clean the laser heads?is there any automatically way?
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer is clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Try cleaning the toners and see if it makes any difference. You would also have an idea about the toner drum/ parts quality etc and check if they need to be replaced. Furthermore, issues with Laser Unit like dust/ toner dust on the lenses and mirrors inside the printer usually result in faded or discolored prints. For instance, faded text/ picture at certain areas or any color missing when you print.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 21, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
My panasonic pt-61lcx has green dots on the screen)
sorry but it's the bulb.....hince why there is a class action lawsuit against them......
Feb 10, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Hitachi Plasma EDTV has green dots flickering all over screen
that is called diffusion. that can be adjusted out in most cases by adjusting the y sustain pcb but can also be the main pcb, the logic pcb and panel itself but not likely.
Jan 11, 2009 | Hitachi 55HDS69 55 in. Plasma Television
White dots on screen
your dmd chip is defect this a good job you must tack emgine apart calculate atleast 200 dollars
Dec 06, 2008 | Samsung DLP HL-P5663W 56" TV
Need to take off tinys green dots in my screen tv.
It seems that your DLP Engine is going. The DMD board in the engine is the problem. it is an expensive fix
Jun 29, 2008 | Olevia Televison & Video
Kolin PT-501 LCD/LCOS HDTV, rear projection TV
Well i really do not know what that is but i do have a thought it could be a bad connector and if you want i have the same tv for sale for $300 shipped just for parts the problem with my pt501 was the screen turned colors but the lamp is in excellent shape and so is the lcos screen the ownly thing that does not work is the main board (ciruit board) i will send you the hole thing for just 300$ shipped if you'd like email me back giovani.rivera@yahoo.com
Jun 29, 2008 | Olevia Kolin DLT2711M 27 in. LCD...
Large dust circle on a Toshiba 50H95 RPTV
No the front panel will only give you access to the CRT circuits. Remove the back panel. UNPLUG your set. You should be able to reach inside (its a stretch for sure) to clean the screen, clean the tubes and if you reach up behind you can actually clean the mirror. This will greatly improve your picture. Do not use windex just a damp soft cloth then dry with a soft cloth. The mirror cleaning is most important to get a nice bright picture. Over the years the mirror tends to get dull. Hope this helps.
Jan 20, 2008 | Televison & Video
Green and Blue spots on screen
Sounds like stuck pixels, you really can't fix that. Do some google research if you are curious what a stuck pixel is.
Oct 30, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Cleaning Internals
yes you have dust in your optical block may have to be replaced
May 25, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
425 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
