Question about Kenmore Vacuums
Lid will not snap shut over vac bag on kenmore magic clue
I opened the canister to check on the bag and can not get the lid to shut over the lip of the canister...I can see that it lines up properly but will not snap over the part...I do not want to force it for fear of breaking it.
  • barb_larsche Dec 04, 2008
    Hi...I can not seem to locate the soloution to this problem...the vac is a Kenmore Magic Blue...please forward tips on how to fix the problem. Thank you! Barb.
  • Anonymous Mar 19, 2009
    I can't get the lid closed either.  Did you ever get the lid closed, and if so, how?
  • 269 Answers
You have probably closed it by now :-) but when this happened to us we found that if we opened the tool compartment on the lid, the main lid then closed on the bag with a tiny bit of jiggling around. I don't know why, but this worked.
Posted on Jun 17, 2013
  • 55 Answers
What kind of vacuum do you have?
Posted on Dec 01, 2008
How do you change the bag in a kenmore progressive true hepa canister vacuum?
There is a latch just under where the hose enters the main canister section, just behind the handle. Pull back on the latch to open the bag compartment. The bag will pull out of it's plastic holder, then slide the new bag all the way in and close the lid.
Apr 14, 2010 | Kenmore 25512/ 25513 Progressive Canister...
I have an older Electrolux canister vacuum - model #2100 and the temperature sensor shuts down the motor. How to I take apart and clean?
Check to be certain the thermo lite is on and not the bag full indicator. The thermo detector is very reliable, but the bag fill valve often fails. If it is the thermo, check your hose and wand for blockage by dropping a coin through them,before opening the vac itself.Otherwise you may have a bad set of motor bearings causing the motor to overheat due to its age.
The 2100 and all its canister cousins made since 1982 seem to be prone to failure of the dial valve on top cracking internally. The causes the bag full indicator to come on and the vac to shut down.
To open the vac you will need to slide the locking keys and bumpers forward with the bag door open. Do this with a set of pliers. Once done the vac will open from front to back like a **** shell. Be careful to look at the underside hinge are of the bag door before separating and mark and locate the wiring harness . This vac only goes back together one way, perfectly assembled it pops together with ease. If any piece is out of line it`s like a RUBIKS Cube. Take your time . OEM parts are only available through an AERUS Elctrolux dealer or repair shop
Dec 14, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Vac has no suction,hose clear and tried new bags
make sure lid is all the way down, detach hose from canister and drop penny through to make sure is clear..
Nov 27, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Also have a Kenmore Model 116. Power retractor not holding cord
The cord winder on these is spring loaded and has cog which is meant to lock with every full rotation of the spool the cord winds onto. It is tricky to work on.
Try pulling a bit more slowly and see if the rewind will stop.
The back housing on top of the vac needs to be removed to access the rewind. The housing snaps into place at the back corners, generally must be carefully pried and popped off by someone familiar with the vac. Some models may also have 2 screws under the lid in the bag area.
Sep 10, 2009 | Kenmore Canister Vacuum Vacuum
Bag full indication comes on; changed bag; still wont run.
Turn the knob on the top of the vacuum all the way to the right and try it again
Jun 15, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Kenmore canister vac 25614
Have you checked and made sure that the hose is COMPLETELY clear and the bag is not full?
Feb 13, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore Progressive Canister w/Hepa Filter
May have a problem with the motor protector or the motor itself. The motor thermo protector will shut the motor off if it senses it getting hot. So it could be bad.
Apr 13, 2008 | Kenmore 22313 Bagged Canister Vacuum
Vacuums Logo
249 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
