Question about Whirlpool LSR9434PT Top Load Washer
It will not fill with water
When I put the washing machine to wash mode it starts to agitate but no water goes into the machine. If I hold the knob that says small large or extra large load in betweeen xlarge and large the water enters the machine. As soon as i release the knob the water stopes. When it gets to rinse it will not fill with water. Any suggestions would help. Thanks Tom
How do you open top on whirlpool washer?
Posted on Mar 13, 2009
    Problem Solver:
  • 18 Answers
Check your water level switch. most likely youll need to replace it.
Posted on Feb 04, 2007
How do I fix a top loading washing machine that isn't spinning, agitating or draining?
if this is a top loader put a pencil into the lid switch opening if the machine spins and drains when the timer knob says it should the tab on the lid or the lid switch has failed...replace the switch or the tab that goes into the lid switch opening
Jan 26, 2016 | Amana Washing Machines
The washer starts in agitation mode. Will not do anything but agitate. Is it Water Level switch that needs to be replaced?
Washers start in fill mode as it requires the level of water set to start the agitator mode.. If your machine goes immediately to agitate then I would think that the agitator control module is failed and needs replacement. have an appliance electrician check it out.
Aug 17, 2013 | GE WDSR2080D Top Load Washer
Water fills to over flowing and never starts agitate or spin cycle
With the tub empty disconnect the air hose from the water level switch in the console. Blow through it to see if its kinked or restricted. Check the air bell for a buildup of **** especially near the opening where the air hose attaches.
If all is OK reattach the hose and disconnect it from the air bell. Turn your water off and set it to wash. Blow through the hose to see if the switch goes from fill to agitate.
Jan 03, 2012 | Maytag Performa PAV2200
Kenmore washer does not fill first ,goes right into washing.Replaced timer ,same problem.
Hello Sue,
The reason your washer starts agitating instead of filling first is shortted water level sensor switch that should be replaced.
The part number for that switch is W10177795
GENE
Nov 11, 2011 | Kenmore Washing Machines
I have a whirlpool ultimate care II that won't fill with water it just starts agitating. Sometimes if you hold the load size switch in between load sizes it will start filling but you have to hold the...
The problem is quiet obvious and it is the water level pressure switch behind and connected to the load size switch knob. The pressure switch is stuck in the full position that's why the machine doesn't fill and it goes directly to agitate. Holding the load size switch in between load sizes releases the contacts from full position and allow the machine to fill as long as the switch is held on.
Disconnect power then release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Behind and connected to the load size switch under the console is the water level pressure switch with a clear hose attached to it.
Remove the pressure hose from the pressure switch then reinstall the console and reconnect power. Start The pressBlow air forcefully into the pressure swic
Feb 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Doesn't fill with water - goes straight to agitation.
open the console and find the pressure switch. it has a clear hose attached to it. pull the hose off the switch and turn on the washer. if water starts to enter shut it off and blow through it back to the tub. some piece of junk may have plugged it causing the switch to "think" the tub is full of water. put the hos back on and run a short spin cycle to reset it and try again making sure to run a small load to see if it shuts off properly. if no water enters when hose is pulled off most likely bad pressure switch. keep the lid closed while doing these tests. some units wont work w/lid open.
May 25, 2009 | Whirlpool Washing Machines
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Washing machine agitates at beginning of cycle without filling
Chances are either:1) the water pressure switch has failed or 2) the hose that connects to the air bell has debris in it and it will not allow the switch to reset
Mar 02, 2009 | Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool LSR9434PT Top Load Washer Logo
175 people viewed this question
Sal De
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
