Question about Compaq Presario 700 470024-192 Notebook
Monitor problems my screen has turned 45 degrees, how do I turn it back?
  • 1 more comment
  • han2nic Nov 30, 2008
    i am on vista, the screen has turned 45 degrees while i was playing a game and now I cant turn it back round, help, ive got neck ache!
    DONE! Thank you sooooooooooooooooooooooo much
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    are you using vista or xp?
  • 28 Answers
You may try CTRL-ALT- and one of the four arrow keys. Usually CTRL-ALT-DOWN ARROW solves most of them, but it depends on which way the image is rotated.
Posted on Nov 30, 2008
Toshiba Satellite M305D-S4830 laptop won't boot up. It sounds like it starts to (can hear fan), but the screen never comes on.
It sounds like either your display is turned off or the backlight went out. If you have a display selection button on your laptop(usually on one of the function keys), try that. If that doesn't work, try plugging it in to a monitor or other display and check if that works correctly. If it does, your screen either has a bad backlight or other physical problem.
Jan 04, 2013 | Computers & Internet
Screen has turned sideways
Right click on an empty spot on the desktop and scroll down to either the Nvidia or ATI control panel. Once you are in the control panel, look in the left hand pane and look for something that says, screen orientation or screen rotation. When you select that it may give you the orientation in degrees of a compass or rosary. Make sure you place the monitor orientation at "0" degrees. This will bring the screen back to normal.
May 16, 2010 | Tatung LD23HL Monitor
Screen comes on for about 45 seconds then goes out. if you turn it off and back on it does the same thing.
You have an power supply problem.you can fix yourself if you can solder. if not the it needs an repair shop..
Feb 23, 2010 | ViewSonic VX1962wm LCD Monitor
When turning the notebook -- I get a 'black' screen. Is this an easy fix?
It would be helpful to know if the LED indicator lights that you see on boot up and after are acting normally. If so, and you shine a flashlight close to the screen on a 45 degree angle and can see icons or password prompts, etc., then you have narrowed the problem down to the screen and/or the screen inverter. If you have access to an external monitor and can hook up to it with the laptop, that will show quickly if it's just a screen issue. If the display is good on the external monitor, you know the screen is the problem.
Nov 24, 2009 | ASUS Eee 4G Notebook
My screen (not my monitor) just turned 90 degrees! how do I get it to turn back?
Try clicking ctrl>alt> and a combination of any of arrow keys (left or right or up or down) simultaneously, until your display comes back to place. Hope this corrects your problem.
Oct 22, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
Screen goes black after 30 mins of working.
There are a few things you need to check here.
1. It could be that your computer power management is set to turn your monitor and harddrive off after 30 to 45 min.
If the computer is however working for 30 to 45 min while you doing stuff and it shuts off, the there is an internal problem "Hardware"
I would suggest you check to see if the power management is set to turn off monitor 30 min and harddrive after 45 min. IF that is not so, then we go on to the next test.
It could possibly be your processor fan is not working so once your processor gets over heated it shuts off the computer.
Turn off the computer, remove the case "this is only if you know what you are doing" with the case off, power on the computer and see if the processor fan is working.
You can get back to me and I can walk you through it.
Hope thiss help.
Aug 23, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Monitor display is rotated 45 degrees. Can't get it back to normal.
right clik on the desktop and select graphic options then choose rotation. set to normal mode. fine ???
May 03, 2009 | HP Compaq Presario SR1110NX PC Desktop
Dell Inspiron 1100 screen goes into power saver mode after 45 sec
it sounds like your most likely having trouble with the hibernate feature try this
start>>control panel>>power options>> click on the hibernate tab
un check enable hibernate mode
this should fix your issue
Apr 10, 2009 | Dell Computers & Internet
Dell 17" monitor has turned 45 degrees
http://internetducttape.com/2006/08/01/stupid-windows-features-monitor-display-turns-sideways-or-upside-down/
Feb 08, 2009 | Dell E173FP 17" LCD Monitor
Screen problem
Perhaps your connections on the inside have come loose. It may warrant you take it to a specialist to check it over before it gets any worse. Some other person was on here some time ago who had a similar problem and all it was is the switch in the lid. Apparently they tinkered with it by just kept on pushing it back and forwards as if to continue to open it and it came right they tell me that they hardly used it thats why!.
Oct 02, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario 700 470024-192 Notebook Logo
74 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
