Question about Kenmore 74602 Gas Dryer
Coins stuck inside dryer fins
I need to know how to remove the fins without breaking them. It is a Kenmore King size heavy duty dryer 90 series.
Thanks!
    Sergeant:
    Champion:
  • 291 Answers
Raise the top and there are 2 1/4 screws running into each fin ,,,,, take screws out and dump fin and that wit do it for you / larryyb
Posted on Nov 30, 2008
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
Maytag 3000 series dryer, coins stuck in dryer fin
open the top of the dryer. slide the belt down to the power unit. of course you shoudl always unplug the unit first before removing the cover. carefully lift up ont he drum and they shoudl fall out. carefull y palce the drum back and the belt. replace the cover and plug in to see if that works.
Dec 04, 2009 | Televison & Video
Kenmore dryer- remove fan to change motor on dryer.Do I need a gear puller to remove ? 7 yr old 90 series dryer ,seal drum came lose from damage to dryer when purchased. Did not relize damage until motor...
The wheel has left handed threads. Use an impact wrench and an adjustable wrench to get it off or get a vice grips or pipe wrncha nd lock down the shaft then get a stick of wood or a hammer handle and shove it in between two fins at the 3 oclock position. Slam downwards on the wheel and it should pop loose.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 22, 2009 | Kenmore 659 Electric Dryer
Where to reconnect yellow-red wire on series 90 heavy duty
At about the 4 oclock position look had for a male spade clip mounted between the inner and outer front panel. Look inside the panel and you will see the metal stripes below the filter that collect the wetness data from the clothing as it tumbles past. Great question! Post your model number to any of these fine forums for
a simple answer that will save you lots of money:
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
Feb 18, 2009 | Kenmore 62602 Electric Dryer
Motor removal and replacement on a kenmore electric dryer 90 series model# 110.86984110
remove screw at each end of console. pull & flip back out of way. remove top, remove bottom panel, slide putty knife to release both retainer clips. remove screws to remove door panel assy. remove belt, remove drum. remove motor clamps & remove wires from motor conector.good luck.
Aug 07, 2008 | Dryers
Kenmore heavy duty 70 Series Electric Dryer
If you are using Fabric Softener Sheets than look in the dryer closely for one to be wedged in a fin or anywhere inside .They will make the streaks you mention. Please rate this !!!
Jul 03, 2008 | Kenmore 63942 Dryer
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
Feb 18, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 74602 Gas Dryer Logo
895 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
