Pioneer Pro-118 I have a Pioneer Pro-118 that just all of the sudden has the red convergence way outo of whack and is now unadjustable. I saw Your post about the repair solution You had available and I would be very happy to get the link from You where I can find parts/repair instructions. I can be reached at denverford@hotmail.com. Thanks, John.
  • John Heitz Nov 30, 2008
    How hard is this to change?
  • 8,617 Answers
You need two STK392-110 convergence Ics they are available at the following link with free instructions.
http://servicemanuals.vstore.ca/
Posted on Nov 30, 2008
I have a pioneer pro 730hd took the back off and now the red power light just blinks and it wont turn on
If convergence was off it may have railed (shorted convergence chip) and the set is now in shutdown.
Also go over inside in case you moved or pulled a plug loose.
This is not an easy set to replace the chips and only the original remote will adjust convergence.
Mar 17, 2012 | Pioneer PRO-730HD 64" Rear Projection...
Pioneer elite pro 118
if the tv is more than 10 years old no its not worth replacing the power supply.if its 5 years or newer yes it owuld be worth the money
Jul 17, 2008 | Pioneer PRO-200 60" Rear Projection...
Pioneer sd-533hd5 convergance
for pictures on where is the convergence settings click on this given link.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
but if its the problem in convergence board then check out for this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks.
May 08, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer Pro-118 won't turn on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine. Check all three fuses while you're in there.
Feb 12, 2008 | Pioneer PRO-200 60" Rear Projection...
Pioneer Pro 1009W
Replace conv ICs. This usually does it.
Mr Bob
www.imageperfection.com
Jan 11, 2008 | Pioneer PRO-1009W 57" Rear Projection...
Pioneer Pro-119 Rear Projection TV
HEY DF-YOU SET HAS 2 BAD STK392-110 CONVERGENCE ICS.THEY WILL NEED TO BE REPLACED AND IF NO OTHER CONVERGENCE CIRCUIT PARTS HAVE FAILED YOU SHOULD BE ABLE TO SET YOUR CONVERGENCE ALIGNMENT PROPERELY.TV REPAIR ESTIMATE SHOULD BE ABOUT 300.00$.DO IT YOURSELF FOR ABOUT 40.00$.
Nov 24, 2007 | Pioneer PRO-200 60" Rear Projection...
PRO-100 Pioneer Elite
convergence can not go all a suddenly it might be due to magnetic affact.if it is so remove it very near to tv or you must have tilted tv due to some reason. if it is due to ckt near e/w correction.
Sep 14, 2007 | Pioneer PRO-100 TV
Is this Pioneer Elite Pro 118 worth fixing?
You most likely have cold solder connections on the convergence IC's or on the B+ sources for the convergence. The longer you wait to have this simple repair done, the worse this will get and cost you double or maybe even triple of what it will cost now. Good Luck
Jun 28, 2007 | Pioneer PRO-200 60" Rear Projection...
Convergence problem or??
Yes it has power supply and convergence problem let me know if you need help with part # s or how to fix it
Jun 23, 2007 | Samsung PCN5425R 54" Rear Projection...
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
Electro Med Services...
