Question about Kenmore 75620 / 75621 / 75622 / 75624 Gas Kitchen Range
Oven has mini explosions
Oven will start and not stay on, will constantly reignite, and having mini explosions.
My rheem wedgewood stove oven door blows open when gas reignites after initial warm up
You need to turn this off and get someone out to this you have explosive ignition . asap .
Jan 11, 2018 | Kitchen Ranges
Main oven works but the ignition keeps clicking while oven on
check the operators manual or with a servicing agent
being gas it may require the clicking to reignite the gas when the temp starts to cycle or there may be a problem in the control system for the gas operation
May 04, 2016 | Ovens
I have a whirlpool accubake duo, super capacity 465 and when I try to bake something the oven wont stay on...how do I get the oven to stay on
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
Mar 01, 2011 | Whirlpool Ovens
My 36 " thermador oven,
The sensor on the burner is not sensing the flame. It could be the sensor itself or its' controller. You need to call for service.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 24, 2011 | Thermador Professional Series PO301...
Oven does not "burn" steadily when set below 300 degrees.
Sounds like you have a bad oven ignitor and oven burner tube. install a Amperage meter on one of the oven ignitor wire, It should draw above 3 AMPS, if it is below then you have a bad oven ignitor, or just change the oven ignitor to see if it makes any difference. Have fun.
Dec 28, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
The oven of maytag range mgr5775qdw poorly
The ignitors/burners need to be cleaned properly.
Build up of grease, dirt, rust, mineral deposits, etc can cause improper gas flow resulting in a delayed ignition. That causes a build up of gas and the delayed ignition ignites it all at once, and you have your WHOOMP mini explosion.
Sep 25, 2009 | Maytag Ovens
When starting to reheat a loud crack, explosion, sound occurred,
As long as the door latches correctly there should be no danger. Some items will cause loud "explosions" in a microwave, such as whole potatoes when the skin has not been pierced. If the food contains pickling spices for example, the seeds will explode with a very loud sound like a gun.
As long as the oven continues to heat, there may be no other problem. But I suggest you stay near the unit when using it. Watch for smoke and be alert for strange odors. You don't mention the age of your oven but if it is new you can call GE customer care at 800 432 2737.
Ray
Nov 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag oven won't stay at temp.
new ignitor is you problem part number 1240035, wont reignite after reaching temp, common issue with all gas stoves
Nov 10, 2008 | Kitchen Ranges
I have 2 problems. The first is that the oven, every minute and 10 seconds or so, has to reignite itself. This goes on constantly for the duration of the cook time. Now a new problem has just occured. The...
The first problem - I am not sure this is a problem - it is normal for ovens during cooking to cycling on or off several times. Is this something you notice recently or this is the first time you have ever noticed this.
The second - this may be happenning because the microswitch at the knob may be deffective (constantly on) check this and the wiring harness to make sure nothing is shorting out
Regards
Oct 01, 2008 | Viking Kitchen Ranges
Kenmore 75620 / 75621 / 75622 / 75624 Gas Kitchen Range Logo
176 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
