Question about Acer Computers & Internet
My C:\drive is full and i have removed files to make space but it stil says there is not enough space on drive. What can i do?
  • 59 Answers
Hi, how about your other partition, such as D, E. If there are free space of other partition, you can move free space from other drive to your C drive with AOMEI Partition Assistant, a clean simple hard drive partitioning software. http://www.disk-partition.com/help/allocate-free-space.html
Posted on Feb 16, 2013
  • 340 Answers
Copy this text into a word document, print it and have it next to you when you ferform this:
Perform the steps given below to increase you system performance and clear space.
Uninstall all unwanted software:
To uninstall software
Click on Start -> Settings -> Control Panel -> Add/Remove Programs
Select the software (one at the time) from the list and click on Add/Remove button and follow the online screen instructions.
Erase unnecessary files in the windows temp folder.
Double Click My Computer.
Double Click the drive where windows are installed. This is typically drive C.
Double Click the windows folder. This is typically C:\Windows.
Double Click the temp folder. This is typically C:\Windows\temp.
Press control A to select all files and folders.
Press the delete key.
If confirmation is asked to delete these files choose yes to all.
Defragment hard disk.
Close all applications.
Disable your screen saver.
Disable all the programs on the taskbar if possible.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag.
You should defrag every hard disk on your system.
This process can take quite some time.
Click Ok.
Enable your screen saver.
Remove Startup programs (if you know what you are doing)
Click Start
Select Run
Type msconfig in the text box
The "System Configuration Utility" window will open
A list of programs will be shown each having a checkbox to the left of the name.
Click on the checkbox to enable the program (so it runs when windows boots) and click a second time to Uncheck the box to disable the program (so it does not run when windows boots).
Set the size of the virtual memory (swap file) to a constant optimal size.
Right click My Computer
Click Properties
The System Properties window lists the amount of RAM in your PC
Click Performance
Click Virtual Memory
Click Let me specify my own virtual memory settings
Click the arrow next to the hard disk.
Here are some guidelines to choose the best location for your virtual memory file
a) Select the quickest hard disk.
b) If you have, two hard disks that are similar in performance select the hard disk that does not contain Windows system files (usually C:).
c) Make sure the drive has free space equal to at least twice the size of the recommended swap file size.
d) If the partition is on the same physical drive, select the partition in alphabetical order. For example, if you have one 20GB hard disk and you partition it into two 10GB partitions drive C & D) You should pick Drive C over Drive D if meets all the guidelines of a, b & c.
Set the Minimum/Maximum to: With large hard disks settings at least 128mb or 256mb swap file should be sufficient in almost every situation.
Note: The amount of RAM plus the size of the virtual memory file is the maximum amount of RAM you can use at once.
Click OK.
After setting the size of the virtual memory file windows will display the following message. You have chosen not to let windows manage virtual memory automatically.
Click Yes.
You must restart your computer before the new settings will take effect. Do you want to restart your computer now?
Click Yes
Next :-) please vote if this help you
Posted on Nov 30, 2008
  • Teis Thomsen
    Teis Thomsen Dec 05, 2008
    When less than a quarter feel the need to vote for the effort some of us at FixYou offer, I think to myself, ”is it worth it”.
    They get help, and do not care to thank you; “thank you” do not cost a dime, so why????
    I KNOW this was a great help, so why????
    /Teis
  • Teis Thomsen
    Teis Thomsen Dec 15, 2008
    Hi, back again,
    Wondering if you got your problem Fixed,
    - if not, let me know,
    - if it´s Fixed, then vote “FixYa” to close this case,
    Thank you
    /Teis
I ca not perform the delete deleted items action , not enough space in local disk?
Find some other files to delete or move onto a flash drive to make some room. Make sure your recycle bin is empty.
Jan 11, 2014 | Microsoft Office Professional 2007 Full...
MY DATA (D:) IS NEARLY FULL
Hard disk maintenance should be carried once a month to make your computer run efficiently. This removes redundant and temporary files, recovers disk space and speed up hard disk access. Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too. Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment. Repeat Defrag for the D drive.
Sep 05, 2012 | Acer Aspire Z5700 PC Desktop
Hi experts, my computer indicates there's only 1,14 gb space left on my usb stick but really there's only 8 items on it that don't even add up to 1 gb all together. I want to put a movie on it, (there...
Most movies are about 4.5GB to 8GB, this is probably why your not able to put a movie on it. Secondly a lot of flash drives say its 4GB but really its 3.5-4GB. There must be something your overlooking as file size for ti to take up that much space. go to the properties of each file and look at the folder size, might find something you missed that's taking up more space.
May 03, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Acer 5315 HD C is full HD D empty
Very likely the answer is yes, IF: 1) there is enough space and 2) that D drive is not being used for something else. Check on what is on the D drive. It's usually reserved by the manufacturer and contains OS restore files (used for restoring your system after a crash). Don't delete these, but if there is enough free space, just create a new folder and put your files in there.
Jan 31, 2010 | Acer Aspire 5315 Notebook
Cant download new Windows live messenger, not enough space!!!
Then you need to clear out more space to your c drive, you could try a program called **** cleaner (ccleaner)
http://www.filehippo.com/download_ccleaner/
if you haven't emptied your temporary files etc in a while, this program will most likely clear out enough space for you to install live messenger.
Nov 15, 2009 | Computers & Internet
A window appears saying "unable to scan. Be sure there is enough space in the destination disk."
Your hard drive may be getting full...
Or the account (user name) you are using on the computer does not have enough "rights" to create the output file.
Assuming it is Drive C:
Open [My Computer]
Right-click Drive C: (one time)
and select "Properties"
In the [General] tab, locate and click on [Disk Cleanup]
The system will harmlessly "scan" your hard drive to try to free up space. It is not deleting or compressing anything.
When the scan is complete, a list will appear, place a check on:
Tempoary files, Temporary Internet Files,
(do not "compress" any files)
and click [OK]
Try your scan again.
This is a temporary fix. You need more hard disk space.
Sep 28, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
Tells me I don't have enough hard drive space
I would first check the capacity of your external hard drive. From "My Computer", right-click the drive letter of the external drive and select Properties. Make sure that the drive has the amount you need in *free* space - it's possible that it's just full with other files.
If this is the first time you're using this drive, you may need to format it before it will recognize its own capacity. Right-click the drive letter and select Format.
Aug 11, 2009 | Western Digital My Book Essential Edition...
KINGSTON removable disk error
Find and check real free space go to my computer and right click your driver letter and click properties it will show what is real ammount of disk. For one 4GB file it must not be problem but for meny little file can take more space besider their sum of capacity is 4GB. At format check correct ammount of data "capacity" is 8GB (7.9) also file system for NTFS or FAT32. FAT cant bear 8GB.
Aug 04, 2009 | Computers & Internet
Cannot delete files from D drive
Try deleting the files inside the folder first
If not
Copy some of the files off the drive onto a DVD or two that will make working space on your hard drive
Jun 25, 2009 | HP Pavilion DV2740SE Laptop
Low disk space, how do i fix this problem,i have unistall some of the programs but stil having problem.when i restart the computer a pop up still diplay low disk space
low disk space because one of the drive is almost full it is having below 200MB space so this message will appear . i think so C drive is full just right click on the drive and make disk cleanup and in that select temporary internet files,temp files, recyclebin,compress old files and say ok it will remove all the files from u r computer which is not required finally space will get increased and message will not come
Jul 31, 2008 | Gateway Computers & Internet
Computers & Internet Logo
137 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
