Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
650 refrigerator door light switch
Light does not turn on unless I wiggle the switch.  I want to replace the switch. Is it difficult?  Do I remove the 3 screws holding the piece of the door frame that holds the switch and then remove the switch?
  • flakeyblonde Apr 14, 2009
    all lights out - think it is the switch
    Sniper:
  • 56 Answers
Go to Sub Zero.com and click the showroom locator on the top left of the screen. This will take you to a locator to find the authorized parts distributor for your area I beleive the part number is 3060140 . Once you have the part remove the three phillips head screws that hold the grill in place this is assuming you don't have the louvered grill. There is a grey power cord with a white quick connect seperate this or turn the power off at the circuit breaker. You will be working on live electricity if you don't.Not good for yu life expectancy. There is one more phillips head screw for the cover of the two switches. The light switch has a white back and the fan switch has a black one. Remove the two wires then push it down and slip the new one in. Replace all that you took off. While you have the grill off vacuum the condensor.
Posted on Dec 02, 2008
Ice switch dispenses water
If the refrigerator water dispenser is not working correctly the water supply tube in the door may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Apr 27, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
SUb-Zero 650 fridge lighting issue
Just a bad door switch. Turn the unit off, remove the upper grill, then remove the cover over the switches. there are 2. 1 with a black backside, and one that is all white. you want to replace the all white one with a new all white one. it just has 2 wires, doesn't matter what order they go in. pull em off and pop that thing out, then snap the new one into place. all of this should be done with the power off and the door open. Good Luck!
Jan 03, 2014 | Sub-Zero 650 / O Bottom Freezer...
Contol panel lights are no longer lit; why?
Control panel lights are behind the panel, so if the compartment lights are on the panel is lit. If no lights are on when you open the door, check your door switches as you may find the light switch has failed. Look there first, no lights, possible just a bad switch.
Good Luck
Aug 01, 2013 | Sub-Zero 650 / O Bottom Freezer...
What does the second switch about the door in the refrig control. we know one is for the light what is the other? we have a 550 sub zero
Typically the second switch is for the ice dispenser and fan,when the door is open the fan and the ice dispenser power is cut off via that second switch
GENE
Sep 24, 2011 | Sub-Zero 650 / O Bottom Freezer...
E522BLMFD model refrigerator door alarm won't stop beeping. Fridge eventually turns itself off because it thinks the door is still open. How can we disable or replace the microswitch which presumable...
The door switch has 3 terminals and wires on it. Jumper the wire that does NOT turn on the light to the wire that is on C of the door switch. If you look at the switch it will have one wire distant from the other 2.... that wire is the power wire "C". You jumper that to the wire that would be attached to the "NO" terminal. After you jumper the wire... and TAPE IT with electrical tape the door alarm should be silenced and the internal light will NOT work until you replace the switch. Label the remaining wire with masking tape... NC and Actually label all 3 wires as you remove them... C, NC and NO. Just use write that on a strip of masking tape and then put it on like a horseshoe pennant.
You can order a switch from Fisher and Paykel AU. (See number below)
Phone Contact our spare parts team on 1300 650 585
If your not in AU the door switch is very common... call any LOCAL appliance parts source and they should have one.
Thanks for choosing FixYa,
Kelly
Apr 28, 2011 | Fisher and Paykel RF201ADUX Bottom Freezer...
I replaced the light switch on the subzero 550 and now the frig isn't staying cold. When door is open and I press the switch light goes off so light switch is working.
On sub Zero's this has been a common problem. Pressing with your finger to test isn't good enough. You have to test the switch function, by slowly closing the door to see if the DOOR turns off the lights.
There are so many lights in the food compartment producing so much heat that if the lights are on with the door closed, it will not cool.
When I run into this problem, which is common, I take a thin plastic shim
and tape it on the part of the door that hits the switch. 2" x 3" shim will
work well. If that solves the problem, I put a few drops of crazy glue on the shim and remove the tape a day later.
If the switch has 4 wires to it, the second 2 wires run the fan in the fresh food compartment. You can test that by pressing the switch and listening to see if you can hear the fan in the fresh food compartment start up.
Oct 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
650 sub zero
Go to Sub Zero.com and click the showroom locator on the top left of the screen. This will take you to a locator to find the authorized parts distributor for your area I believe the part number is 3060140 have themm check it using your model and serial number. . Once you have the part remove the three phillips head screws that hold the grill in place this is assuming you don't have the louvered grill. There is a grey power cord with a white quick connect seperate this or turn the power off at the circuit breaker. You will be working on live electricity if you don't.Not good for your life expectancy. There is one more phillips head screw for the cover of the two switches. The light switch has a white back and the fan switch has a black one. Remove the two wires then push it down and slip the new one in. Replace all that you took off. While you have the grill off vacuum the condensor.
Nov 30, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 -- lights/fan not working
you can check the bulb's resistance if they still have. they could be both busted. if they have, the problem could come from thre door switch if you have mechanical door switches that controls bulbs. on the LED read outs, you could have a loose connection to the main board because if the board is not functioning well, then you should not have a cooling refrigerator.
please rate me, i hope i was able to solve your problem.
Jul 12, 2008 | Sub-Zero 650 / O Bottom Freezer...
Light is out in 650
Check continuity on door light switch with ohmmeter (turn off power and disconnect wire harness at switch first) Probably a second switch that turns compressor off if door open. my 690 sub zero had a bad light switch that was stuck on initially but now only works if I wiggle it. Can a person buy parts online? Some new subzeros have a fuse panel behind the compressor grill??
Just bought a used 690 and found a nice wiring diagram for a model 630 or something in a nice ziplock pouch behind the compressor grill. Look there for clues.
May 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero 650 light won't stay on when door shut
super...sounds like the switch you're pushing is damaged. test it.
Dec 15, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
1,638 people viewed this question
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
halftank123
ACME Sub Zero...
ACME Sub Zero...
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
