Question about Motorola Mobility H3 Bluetooth Headset, Black Headset
Discoverable Mode I have a Motorola H350 bluetooth headset and I can't get started with using it. When I go to the menu on my phone (LG 8600) and "add new device", the message reads that no device can be found. It says to put the device in Discoverable Mode & I can't figure out how to do that. Can someone help me? BTW I don't own the users manual for this--someone gave it to me w/out it. Thanks-
  • 1 more comment
  • Michelle Corazza Jan 24, 2007
    Thank you very much--I charged the headset, I think that may have been the problem. Thanks for pointing me in the right direction.
  • Anonymous Jul 05, 2008
    JabraBT150
  • Anonymous Mar 31, 2014
    Im trying to add my bluetooth headset to my laptop and it is not being discoverable.
  • 624 Answers
Here is the on-line manual: http://www.motorola.com/mdirect/demos/how2_h3/main.html -First off make sure the headset charges for at least two hours. Also make sure theindicator light turns on indicating charging is occurring. -After the charge is complete you will need to refer to your phones manual to pair the headset to the phone. The discover mode is a mode the phone goes into not the headset. I don't have an LG8600 nor can I find a manual on-line so I can't help you with that part. If you still need assistance let us know and please don't forget to rate the posting.
Posted on Jan 23, 2007
How can I use my cell to get connet to my laptop ?
Posted on Jul 04, 2008
Press the call button on blue tooth for 7 to 8 seconds & blue tooth goes to discovery mode.
Posted on Apr 25, 2007
How do i connect my Motorola Bluetooth to my Nokia 6350
Hi
Please follow the Instruction and set your motorola bluetooth in Nokia Phone
    • 1 Press the Menu button on your Nokia phone and select "Settings" from the available options.
    • 2 Select "Connectivity" from the Settings menu and then "Bluetooth" from the menu that appears.
    • 3 Ensure that the first line on the Bluetooth menu says "Bluetooth On." If the line reads "Bluetooth Off," select the line and change the setting to have the Bluetooth powered on.
    • 4 Power on your Motorola headset and put it in discovery mode. Discovery mode is indicated by a solid (non-blinking) blue light on the back of the headset. You can put your headset in discoverable mode by pressing and holding down the "On" button for eight seconds. In the case of a headset with a sliding on/off switch, simply slide the button to the "On" position and hold it there for eight seconds.
    • 5 Select "Search for audio enhanc" from the available options on your Bluetooth menu.
    • 6 Select your Motorola headset from the list of items that appear. Your Nokia phone will list all of the Bluetooth-enabled devices powered on nearby.
    • 7 Enter the passkey for your Motorola headset when prompted. The default passkey for all Motorola headsets is 0000.
    • 8 Start using your headset with your Nokia phone. The two will be permanently connected, with no need to repeat the pairing process in the future.
Read more: How to Connect a Nokia Cell Phone to Motorola Bluetooth ' eHow.com
Jun 07, 2011 | Nokia Cell Phones
Trying to set up my motorola h350 bluetooth to my samsung s30 phone.
Turn your H350 on by pressing and holding the black "Talk" button on the side of your headset. Hold it until the blue status starts to flash. To turn the H350 off, simply hold the talk button until the headset turns off.
Pair your headset with your cell phone by entering into your cell phone's bluetooth menu--Menu > Settings > Connection > Bluetooth Link > Setup (see Resources below).
Put your Motorola H350 into pairing mode by holding the "Talk" with the device turned off. Hold the button until the status light on the side of your headset begins to flash, and turns back into a solid blue.
Back in your phone's bluetooth menu, choose the option to "Search/Discover" bluetooth devices. And when your phone recognizes your H350, select the headset and enter "0000" as the passcode.
Thank You
Sep 05, 2010 | Motorola Mobility H350 Wireless Headset
Maual for Motorola H350 bluetooth headset
To pair your bluetooth with your new phone...
Step one: make sure bluetooth is fully charged. While off, press down and hold the mulitifunction key on the bluetooth until light remains on.
Step two: put your phone in discoverable mode and click on add new device to search.
The phone will then find the bluetooth.
Jan 17, 2009 | Motorola Mobility H350 Wireless Headset
I have a LG scoope that I'm trying to hook my motorola H350 up to it. I lost the instructions and I don't really know if it will go with it. I need help!!!!!!
The quick answer is that you can put it into pairing mode, and your phone should recognize it. To put into pairing mode, push and hold the large power/answer button for at least 6 seconds. The light will start flashing, indicating that it is in pairing mode. Go into the Bluetooth menu on your phone and make sure Bluetooth is turned on, that your phone is visible, and that you can search for new headset devices. Make sure the headset is still flashing. When you discover the headset in the phone, it may prompt you for the code. I believe the pairing code is "0000". Add the device to the phone. You should now be able to use it with your phone.
If this doesn't get you there, do a search for H350 Manual to get a pdf of the user manual and quickStart guide.
Jan 12, 2009 | Motorola Mobility H300 Wireless Headset
Need to setup H300 bluetooth to my LG VU phone! How do I do this?
Jan 08, 2009 | Motorola Mobility H300 Wireless Headset
Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
  • press and hold MFB until indicator light flashes blue and red. The headset will also beep twice
  • to pair your device to the bluetooth headset use the bluetooth pairing instructions from you device's instrucition manual.
  • input ID code 0000 when requested by the device
  • the headset and device are paired correctly when the blue and red indicator light flashes blue only.
Any questions email: shyrosi@yahoo.com Subject: omnitech bluetooth
Dec 29, 2008 | Motorola Mobility RAZR V3
How to set up bluetooth
go into bluetooth menu and get phone to search for the headset, have the headset turned on, and make sure it is in pairing mode. The instructions should tell you how to do this.
Jan 11, 2008 | Motorola Mobility H350 Wireless Headset
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Motorola Mobility H3 Bluetooth Headset, Black Headset Logo
1,474 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
