Question about PC Chips M848ALU Motherboard
Front panel connections
I have swapped my ATX case and the new one seems to have more connections than the old one and I can't seem to get the configuration right.
Firstly do the HDD Led/Power SW Led/Reset SW (All are 2 pin connectors) need to fit a particular way round - if so how can I tell which way they go?
Secondly (and main problem!) is that the new case has a 3 pin connector for the Power Led, and I can't see where to connect it - reading the motherboard manual it suggests there is an Optional 3 pin connector, but I don't have it. The old case had a 2 pin connector and it was lighting the LED, but I am not sure where it was plugged in. There are spare pins on the board, but the end 2 are marked "SUS LED" if that is any help.
All replies gratefully received.
  • sjcrofts Nov 30, 2008
    OK thanks - how do I get the wire out of the connector - you are right that there are only 2 wires - it seems to be soldered in??!
    Thanks Again.
  • sjcrofts Dec 01, 2008
    Thanks for your help everyone - I swapped it last night, but still couldn't get it to work, but then worked out I had to pull both wires out and put the coloured one in the middle, white to the side.
    Why don't they just use a 2 pin connector, and why call it SUS when all the others are labelled in plain english? - ideas for improvement to PC CHIPS!
    Thanks again for all your comments
    President:
  • 2,351 Answers
Hi sjcrofts,
The most common problem for most people is knowing what wire color is positive & which wire color is negative. The colors blue, red, green, light blue, light red & light green are normally positive. The color white & black are negative. Your board uses only 2-pin connectors. The 3-pin power connector can be turned into a 2-pin connector to work with the M848ALU pins.
(Page 13, PANEL1). How to? Take the three pin connector, on the back side of the connector you'll see a small tab that holds the wire into the connector. Use a needle & pull tab up while pulling the wire out at the same time. The wire should slide out. Insert the wire back into the connector next to the other wire. You do not need to hook up the SUS led which stands for suspend.
Pin 1 is positive & the manual shows this by adding the _P = positive.
Pin 3 which is to the right of pin 1, is negative for the hard drive led. Pins 9 & 10 are not used.
Good luck sjcrofts!
Mike
Posted on Nov 30, 2008
  • 519 Answers
Usualy the power LED plug is for three pins, but only has 2 wires. You have to remove one wire from the black plastic connector plug and put it next to the other wire in the empty slot. To determine if you have connected the plugs the right way around is simply the fact that the LED will not light if its the wrong way around. You cannot damage *********** board by connecting these pins the wrong way.
  • Graeme van Malsen
    Graeme van Malsen Nov 30, 2008
    On the side of the black plastic plug is a thin plastic strip which holds the pin in place. This pin is soldered to the wire in question. You can remove the wire by gently inserting a sharp object under the plastic strip and lifting it up. this should release the wire from the plastic plug. Now insert the wire next to the other one. Let me know if you are successful or not.
1988 w/2003 engine. How do I connect new harness?
WOW?
yes, the new ECU;PCM uses a real electronic 3 wire
hall sensor for speed, (or uses ABS if opted)
swaps are complex. we need
what you had before the swap (drive line)
and what was removed from the 2003... every part.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Aug 26, 2015 | Jeep Wrangler Cars & Trucks
I had a dell Inspiron 580s I'm swapping cases and everything is working find except the front power switch I can't seem to find that layout of the fp1 thing I'm very new to hardware but any type of help...
hi
check your front penal conecation for front pwoer switch u will get problem solve still your not able to slove then you have to change the front penal hardware
find link for penal wiring on board
data:image/jpeg;base64,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
Jul 09, 2014 | Computers & Internet
Case switch connected to motherboard is messed up. i need a new switch for the case or the configuration for the pins on the motherboard to be able to use a new case/new switch
The Power On switch is located inside the plastic Power On button assembly.
It is a Momentary Contact Switch, and is named an ATX power on switch.
This ATX Power On switch I have found fits many computers,
http://www.directron.com/atxswitch.html
The plastic front panel of a desktop computer is the Front Panel.
The pin area on the motherboard, that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Tell me the manufacturer name, and Model Number of the computer, or tell me the manufacturer name, and Model Number of the motherboard, and let me see if I can find a Pinout for it's Front Panel header.
(What pins the cables connect to)
Post in a Comment.
Nov 12, 2010 | Computers & Internet
Need manual or instructions for connecting frint
The model of the motherboard is actually more helpful. Most of the FP Connectors will be labeled, i.e. HDLED +/-, PWR LED +/-, etc. Loook in your motherboard manual for which pins they relate to.
Dec 24, 2009 | Power Up 2532 Silver ATX Mid-Tower Case...
I have a old atx case new mobo no front sound
make sure the front panel jacks is connected, chek the motherboard manual to c how to connect
Oct 08, 2009 | Biostar G31-M7 TE Motherboard
M2N MX SE Plus Motherboard
Read the labels for the connectors on the motherboard.
Polarity does not matter for the POWER and RESET buttons.
If the lamps for AC-POWER or HARD-DRIVE-ACTIVITY do not light-up when you expect them, then reverse the connector.
Try the PC SPEAKER connection one way, and then shutdown
the computer, reserve the connection, and start the computer.
If the "beep" at start-up is better, leave it as-is.
If the "beep" does not happen, or is quieter/distorted, reverse the connector.
May 21, 2009 | Ultra Products Ultra M923 Full Tower ATX...
Asus K8V SE Deluxe - will not turn on
it should have pins to reset it touch the two reset pins with screwe driver to activate it if still gont work you have a bios problem
Dec 05, 2008 | ASUS K8V-MX Motherboard
Front mic port and headphone
to connect your front panel header you must refer to your motherboard manual ...
it will given in detail with the pin diagram how to connect ....
check the motherboard compatibility some motherboards dont support working of the back panel header and front panel header at same time especially the old motherboards ....
almost all new motherboard supports working of both the panel headers at the same time if the motherboard supports multi streaming...
thank you
any doubts you can reply me
i am always here to assist you
bye
rate my solution
Aug 06, 2008 | Computers & Internet
Power on Problem!!
Did you plug the cables for the front devices and buttons into the motherboard at the right locations? Are the polarities correct on for your cables?
Jun 26, 2007 | XION Onyx (XON-301P) ATX Case
PC Chips M848ALU Motherboard Logo
731 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
