Question about Nokia 6600
Keypad buttons not working
I have a Nokia 6600 and recently the 1 4 7 keys stopped working, having taken the front cover off and removed the dust, the problem has moved from the 1 4 7 keys to the 4 5 6 buttons. Anyone have any suggestions on how to solve this or what it could be?
Some time if your cell has felt then it can also that print hve open of your keypad .so please check your signal first and then if it is opened ,check your keypad ic.
Posted on Mar 22, 2007
Ull have to open the mobile and check the keypad strip or change the strip
Posted on Jan 31, 2007
KEYPAD PROBLEM
Remove the front cover, lift the rubber keypad and clean the button surface with damp cloth. NOT WET. Allow it to dry for a few minutes, reassemble and start using. Some dust may have gone between the rubber pad and the keys.
Oct 25, 2013 | Nokia 6300 Cellular Phone
The n6600 is turning on properly but after a few seconds it turns white screen only and keypad lights turn off and turns on when power button is pressed.,.,how can i repair it?please help me.,.,
The Problem is with your 6600 Software just Flash it (renew mobile software)
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 16, 2011 | Nokia 6600
You know wat is the keypad to push,to reprogram my cellphone unit 6600
1.Green dial key, * Star key, no. 3 key on keypad Together.
2.Turn your device on while you are pressing the three buttons.
3.You should now see "Formatting " on the Screen! Leave the buttons now.
Thank You
Dec 14, 2010 | Nokia 6600
How 2 farmat
basic method
1.Turn your device off.
2.Remove SIM card and MMC card
3.Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad Together
4.Turn your device on while you are pressing the three buttons
5.You should now see "Formatting .." on the Screen! Leave the buttons now
secondary method
1.You can remove the mmc but keep the sim card and restart your phone
2.Then press the keys *#7370#
3.The phone would ask a confirmation
4.Select yes.
5.Then it will ask for a code.The code is 12345
6.The phone now ought to restart with the memory formatted.
Jul 26, 2009 | Nokia 6600
Nokia 2100 keypad suddenly stopped working
Please try to open the pad and clean its contacts. below is the proceedure to open the phone (if it is not under warranty). you two credit cards and a screw driver.
  • Take front faceplate off by inserting card 1 between housing and silver key. As you pull up, take card 2 and slide it on the side of the phone prying the clips off.
  • Unscrew these 6 screws at the edges with the T6 screwdriver and release the 4 clips surrounding the LCD screen.
  • Slip the little black frame off of the LCD screen, and lift the screen. You should now see a screw. Removing this screw removes the back cover.
  • That’s it! Put your new faceplate or housing in and figure out how to put things back by following the directions here in reverse order.
May 28, 2009 | Nokia 2100 Cellular Phone
SELECT KEY NOT WORKING IN NOKIA 6600
i can solve that but first ad me at my ym ken_craze
Mar 14, 2009 | Nokia 6600
Nokia 6600 not starting
Hi there...to fix your problem you have to format your 6600...just simply turn off the phone...and then hold this buttons at the same time Power button,3,*,Call button...be sure press it at the same time...wait until the formatting msa appears after that your phone will work now normally...hope this will help you
Feb 11, 2009 | Nokia 6600
Number 7, 8 & 9 key is not working
change your keypad or clean keypad.
Feb 21, 2008 | Nokia 6600
Nokia 6600 keypad problem
Dear sir,
pls change the original UI ,if it is not solved than change the key pad IC (both), it will solve the key pad problem.
Jan 18, 2008 | Nokia 6600
Keypad problems
it's all about between key pad papper scrape i hope you will understand
Dec 17, 2007 | Nokia 6600
Nokia 6600 Logo
216 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
