Question about Sony Ericsson W910i Cellular Phone
W910I KEY PAD PROBLEMS
Hi there my phone has just landed in a bowl of soup. I've tried to clean it up as much as possible. Now the following keys won't work
The call button
Key pad no 8/TUV
Delete key
Can this be fixed?
    Guru:
  • 97 Answers
Well when ever a phone falls in a liquid or water, the first thing you would have to do is put the phone off and dismantle the parts for it to dry out completely. This is because, the way a phone's main board is designed, any liquid on it will cause a malfunction.
This is what can be done; The phone's main board must be cleaned very well with 'cleaning alcohol' and allowed to dry . To unpack the phone to do this, you would need expert hands to unscreew and dismantle the phone. If you are not sure of how to do this, see a mobile phone technician or any experienced hands.
Normally, you are assured of getting all the keys to work but not all the functions of the phone; though all may work. This depends on how long the liquid still remained on the phone.
The good news is, you don't lose your phone.
Thanks
Posted on Nov 30, 2008
2004 Yard Machine Rider is backfiring through carb any solution? I've tried replacing the plug,checked the key and cleaned out carb bowl.It was running fine then this happened.
Hi, check and adjust the valve clearences. When you do this take the piston 1/8 inch past top dead centre on the compression stroke and check the clearence, it should be around 5 thou on the inlet valve and 7 thou on the exhaust. regards Phil.
Jul 02, 2012 | Garden
My 3 year old has changed the language on my sony ericsson w190i phone from english to arabic. I have been trying for hours to get it back to english, but no luck so far. If possible, please help.
just remove your current sim card, get another spare sim card or your friends sim card and insert it in your phone and switch on then follow the instructions for basic setup on your phone and it will directly lead to the language options of your phone, then select the language appropriately
if this did not work go to settings (differentiate menus using the icons) 1st option (general) use your track pad and press it twice this will land on the language menu then press the center button or select button
Jan 28, 2011 | Sony Ericsson W910i Cellular Phone
Call key, end key & clear key do not work. Unable to make a phone call
Possibe accumulation of dirt in the front panel or damage to the pad switches. You will need to open the phone and check on the board, clean and set them , use some methy spirit to wash carefully the accumulated dirt . check the specified pads carefully for any damage to the tracks.
If this wont help must confirm if the interface IC is defective.
Aug 26, 2010 | Sony Ericsson W910i Cellular Phone
I have a Verizon Moto Q. The buttons are not working properly. When I hit the start button, back, the arrows, or center select button, mail button and certain letters it just enters numbers or letters and...
Hi, from the question you posted, there are three likely problems to the phone. One it's either the key button pad is bad which needs to be replace, the interface of the key button pad is dirty which needs to be cleaned, or the glass I.C which controls the key button is bad which also needs to be replaced.
But i think what the problem is the cleaning of the key pad button interface because the buttons are working but they only misrepresent whatever function you try to perform on the phone.
You just need to get a mobile phone technician or an electronic repairer around you to help service and clean the board and key pad button interface, and the phone will start working fine..
Take care
Mar 26, 2010 | Cell Phones
My w910i keypad not working at all.call, end call,menu,cancel, and shortcut key not working.how to fix it...
my w910i keypad not working at all.call, end call,menu,cancel, and shortcut key not working (but num'ric key pad is working properly). can any one guide me to fix it...
Feb 06, 2010 | Sony Ericsson W910i Cellular Phone
Hi! my SE w960i has a problem in scroll. its not working. pls help.
check upper keyboard for collosion caused by dirt or waterdamage. if ok, check flex cable, could be developing a cut. if flex ok, then replace the upper keyboard not key pad
Feb 02, 2010 | Sony Ericsson W910i Cellular Phone
All the buttons except for the number and d pad are not responding on my sony ericsson w910 how do i fix it
hi,sir possible defect is the ribbon wire connection going to key pad control.may dirty contact,loose connection or disconnect.
Aug 03, 2009 | Sony Ericsson W910i Cellular Phone
Problems with Keys of my w910i mobile
change the keypad because they might have blunt edges and not being able to press properly or either the keys below the keypad have lost their sensors
May 24, 2009 | Sony Ericsson W910i Cellular Phone
Sony Ericsson W910i Cellular Phone Logo
186 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
