Question about Samsung PS42P2S 42 in. Plasma Television
Program code for moxi remote for Samsung 50" plasma
I can get the remote to turn the tv on and off but it does not control the volume very well. a friend told me that he had same problem with a motorola digital remote and found a code that worked after trying several. I have tried the codes listed and a couple work for power but have same problem with volume.
4 Suggested Answers
SOURCE: Charter MOXI Remote doesn't work with Sony Bravia 42'' Flat Screen
Hold down the moxi and ok button until the remote flashes twice,then enter 9910. The remote will then blink twice again.Then go back and fourth pressing the mute button and the up arrow key(the one above the ok button)this will go thru all the codes,when your tv finally mutes,press ok that means you found the correct code.Hope this helps
Posted on Apr 12, 2009
SOURCE: just received a new moxi
Jax123 you are BRILLIANT!!!! You fixed my Moxi box after having tried THREE times calling Charter tech support which was worthless!!! THANK YOU!!!!!!!
Posted on Jun 11, 2010
nainamainaka
  • 380 Answers
SOURCE: virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Posted on Nov 18, 2011
I have a Samsung TV iamuseing a ermsom remote need codes for this remote
Search Results
    Remote Control Codes
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    ... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...‎Guide to Programming the ... - ‎Download the Manual - ‎8 Device Learning Jumbo ...
    Remotes - Device Codes - HiFi Remote
    www.hifi-remote.com/codes-tv.shtml
    TYPE, BRAND, CODES ... TV, Emerson, 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, ... TV, Samsung, 0019, 0060, 0030, 0056, 0178, 0032.
Feb 05, 2016 | Samsung 50 in. Plasma TV
How to program a vizio tv without a remote vizio
Upon first start you should be prompted. If not, you will find a series of buttons on the TV itself; power,channel up down, volume up/down, input and menu. Hit the menu button and the menu will pop up. Scroll up and down with channel button, select and controls are the volume. either that or you can get a Samsung phone that has an app built into it called watch on, which has a universal remote that works for virtually everything. Happy surfing.
Mar 05, 2015 | Vizio P50HDTV10A 50 in. Plasma HDTV
Virgin remote control code for volume on my 50" samsung plasma tv
Nov 18, 2011 | Samsung 50 in. Plasma TV
Remote code
I have an RCA F27676BC, I'm trying to program a MOXI remote to it. RT-MOXI-8X The manual has about 30 codes to try, but the remote will only turn the TV off and on, not mute, or change volumn, Suggestions?
Aug 22, 2010 | RCA 24V511T 24" TV
Just received a new moxi remote because i was having trouble with my old one. My moxi box is a silver motorola box that says broadband media center. my old remote says charter digital on the bottom and...
Do you know what model MOXI box you have? The new remotes weren't programmed to the MOXI 3012 box. If you have the Moxi MP12, BMC9012, BMC 9012F, BMC 9022 you will need to program the remote to the box.
1. Turn on the Moxi STB.
2. Press and hold the MOXI and OK buttons on the remote until the red LED at the top of the remote blinks twice.
3. After the red LED has blinked twice, release both buttons.
4. Using the numeric buttons on the remote, slowly enter 0, 0, 4. The correct entry of this code will cause the red LED to blink twice.
5. The remote is now programmed to operate the Moxi STB listed above. Go to “Programming the TV”.
Apr 01, 2010 | Televison & Video
I have a moxi box and i just bought a vizio tv and i cant find the code so i can use the volume control on the moxi remote or to turn off the tv either
The Code for the Moxi Cable box remote control for VIZIO TV's is "1178". I just programed my 47" VIZIO TV with this same code
Feb 10, 2010 | Vizio VW42LF 42 in. LCD HDTV
Same problem as don5625.my moxi box will not control volume mute or power on my olevia lcd hdtv
Is this the style of Moxi remote that you have?
If so try these steps to find your TV
1. Turn on the power to your TV.
2. Press and hold down the MOXI and OK buttons.at the same time until the LED at the top blinks twice.
3. Press the numbers 9910 on the remote and the led should blink twice again.
4. Press the mute button. If the TV mutes then press OK to lock in the code. If the TV does not mute press the up arrow once then press mute and continue to press the up arrow once then press mute until the TV mutes once the TV mutes press the OK button to lock in the code.
*** Note this may take a couple minutes of trying to cycle through the code list to find which one will work with your TV *****
Good Luck...
Jan 05, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Volume button doesnt work on my sky remote
please follow the steps below:
TV
RED + SELECT
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
May 25, 2009 | Samsung HL-S5086W 50" HDTV
Mar 26, 2009 | Sony Televison & Video
Moxi remote control
The "universal code" 9910 is just the first step in doing a program search. Hold down the MOXI and OK buttons simultaneously until you get the double blink. Then enter 9910 and it will blink twice again. Then begin alternately pushing MUTE and the up arrow (above the OK button). Pushing the up button effectively cycles through the codes and pushing MUTE tests the current code that it is on. Do not go too fast because when you finally push MUTE and it actually mutes (or unmutes) your TV, you must push the OK button to store that code. I just performed this procedure and my first positive code that I stored only affected the mute and volume settings on my TV and would not turn the power on or off. If this happens to you as well, repeat the above process and just skip over the first positive you get until it mutes (or unmutes) your TV again.
Oct 18, 2008 | Televison & Video
Samsung PS42P2S 42 in. Plasma Television Logo
325 people viewed this question
Henry  Thomas
Henry Thomas
