Question about HP 4570C Flatbed Scanner
HP 4570c scans totally black or bluish-green with vertical bars
Problems started out to be intermittent and I could solve it by unplugging the power source for 5 - 10 minutes and then restart the scanning. Now the unit will only scan very, very dark or totally black from a white document. I have been to the HP website and followed suggestions they offer, including the "homing" procedure outlined on this site. I have installed the newer version 2.0 software, still no improvement. I have ruled out electromagnetic problems because the scanner has been in the same location since 2004 and nothing has chaged at my desk. I even tried installing the software and connecting the scanner to a completely different model and brand computer; same problems. Great scanner, very reliable and good quality, until now.
  • 2 more comments
  • duendi Dec 08, 2008
    I too have had this problem since having to reconnect my scanner after moving my computer from one end of my office to another. I have several times tried reconnecting it following all of the directions to a "T" both in the users manual and online troubleshooting - all to no avail. I even cleaning the glass following the directions online. I had no problems whatsoever with the scanner previous to this. Haven't been able to use it in several months. Would appreciate any and all suggestions. Duendi
  • Anonymous Jan 16, 2009
    Exact same issue. Scans full black with vertical bars. Very annoying.
  • denwel7 Jan 24, 2009
    Have never had a problem before now. Now, no matter what I scan, be it text or picture, the result had been the bluish-green, now all black. Have tried reinstall, and all connections are fine, but to no avail.
  • Anonymous Mar 22, 2009
    At one point, I noticed some shadows on preview, but later with scanning or previewing, the entire page scanned came out pitch black.
  • HP Master
  • 2,794 Answers
It could be one of two things:
1) The scanner isn't registering black or white during the initialization processing depending on what color it needs to get it started.
2) The CCD unit in the scanner could be failing which could explain why it was only working briefly before getting worse.
Posted on Nov 30, 2008
Bluish green colour vertical line is coming in my
Your laptop screen has been faulty. you can checked it from service center.
Nov 13, 2009 | Dell E173FP 17" LCD Monitor
Black vertical strip on Hitachi plasma
seems like a lose ground issue from the vertical scan board which usually causes this problem. A scan board repair or replacement should fix this intermittent problem.....take it too your local repair shop before this problems spreads and the tv totally shuts down....
Nov 03, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Light bar stops too soon
I assume you are using this with a computer. One thing comes to mind that relates to software. You should be able to do a preview scan of the whole scanner bed, then move the frame to the area you want to scan only, sort of like cropping the picture. If those crop borders are set to less than the whole document, you will get this kind of scan.
Now if that isn't the problem, the scanner likely has a electronic issue unless the scanner has had a nasty fall. If you want to really explore deep and don't mind if it doesn't work afterwards, turn the scanner off and unplug the power. Open it up just enough to access the optical unit and see if it will move the entire length of the scanner without binding where you experience the end of the scan. Go rather slowly and gently so you don't strip the toothed belt if it has one. You will feel a wierd sensation and some resistance as you move it along which has to do with the stepper motor and that's normal. If that works, it's likely it failed on it's own. If it binds where the scan ends, you'll have to investigate whether it's due to a rusty rail (hope not!) or some other obstruction.
Jul 28, 2009 | HP 4570C Flatbed Scanner
HP Scanjet 4570c/5500c producing dark, blotchy, almost black scans. Has worked fine for years on XP. Reinstalled drivers/downloaded and updated drivers/rebooted/unplugged/replugged USB and power--same time...
Is the glass clean?
Often the plastic will out gas and it will deposit a film on the glass. You might have to open it up and clean the inside of the glass with window cleaner. There is also a mirror in the scanner head. That can get fogged up too (in fact it gets fogged up more frequently than the glass plate). The trick there is to find the mirror below the slot and then clean it with a q-tip that has been dipped in alcohol.
Jul 17, 2009 | HP Office Equipment & Supplies
Hi, My HP 4570C scanjet has an intermittent problem - during scans, the light bar will stop/jam at an arbitrary spot in the cycle. My guess is that the problem may indicate the need for lubrication on a...
Posted by Lonu Feruz,
I have HP scanjet but unfortunately i dont have the driver CD and it is not written anywhere to show HP scan model except this number C7710A. Which driver works on type of scanjet using windows XP
Jan 04, 2009 | HP 4570C Flatbed Scanner
Scanning bar light
Do you mean the green power light? I have the same brand and a similar scanner, and the light does always stay on. I think it is a normal function of the scanner. It may not be a good idea to unplug the scanner. I am going to be a bit more research so that we can both be reassured that this is normal.
I'll get back to you.
Aug 15, 2008 | HP 4570C Flatbed Scanner
Color problem and inacurate scaning
I solved my problem by simple re-boot. Unplug scanner power and USB for several seconds then replug. This solves a large percent of such problems. I wasted a lot of time before I did this. mike123456
Jan 06, 2008 | HP Scanjet 5470c Flatbed Scanner
HP 4570C Flatbed Scanner Logo
631 people viewed this question
Seeker5211
Seeker5211
