Question about Toshiba Computers & Internet
How to adjust touchpad and pointer settings on satellite l30 10y. at present the pointer activates commands when not wanted
  • 31 Answers
Go to Control Panel, then select Mouse/Touch pad Icon. You will see there the MOUSE POINTER OPTION. Just adjust your desired settings for the mouse and pointer settings.
Posted on Dec 01, 2008
Jumping print size
If there's a touchpad icon in the notification (tray) area on the lower right, it might have an option to lower the sensitivity. The Control Panel should supply an applet to the touchpad. The best answer is to get a mouse and disable the faulty touchpad.. the can be replaced too. Once a touchpad gets sensitive like that, the mere tapping on the keys of the keyboard can cause the pointer to move on you.
Nov 20, 2013 | Computers & Internet
Tip
Mouse pointer with keyboard keys
<span><b>You can control your mouse pointer with keyboard keys in all windows versions. When your mouse stops working, you can enable this keyboard feature to complete your important work. This keyboard mouse can performs all tasks same like a normal mouse.</b><br /><b>Follow the given steps to activate the keyboard mouse:</b><br /><b><br />To edit this feature, first you should log onto your computer with administrative rights.<br />To activate this feature, press Alt+Shift+NumLock keys at once and you will receive a small MouseKey box.<br />To keep MouseKeys on, click on Ok button or click on cancel button to cancel MouseKeys box.<br />Click on Settings button, if you want to adjust the mouse cursor detail settings.<br />Here a new dialog box will appear with the title Settings for MouseKeys", now you can manage all mouse settings for example mouse cursor speed, acceleration and some other features.<br />Now using Numeric keypad, you can move your mouse pointer. The controls are:<br />*<br />1,2,3,4,6,7,8 and 9 keys are used to move the mouse cursor into different directions.<br />*<br />Key 5 is used as mouse click button.<br />*<br />Insert key used to hold down mouse button.<br />*<br />+ Sign used to double click on any object.<br />*<br />Delete button used to release the mouse.<br />*<br />Click on NumLock button to disable this keyboard mouse feature</b></span>
on Apr 04, 2011 | Computers & Internet
My right and left touchpad buttons on my Dell Laitude XT Tablet have the same functionality! How can I fix this?!!
You can use the Control Panel mouse options to adjust settings for the mouse
and the track stick (Windows Vista) or pointer (Windows XP).
• In Windows Vista, click Control Panel? Mouse.
• In Windows XP, click Control Panel? Printers and Other Hardware?
Mouse.
Apr 20, 2011 | Computers & Internet
My pointer moves very slowly in my pc which is xp
You can adjust your pointer's moving speed by going on control panel from My computer. Click on mouse option. Drag the cursor as high as you want your mouse pointer's speed. Save the changes.
Jul 22, 2010 | Computers & Internet
My eMachines notebook, the touchpad is no longer working. Re-loaded drivers from web site, still not working?
For touch pad lagging, adjusting the mouse setting should fix the problem.
Select Control Panel from the start menu
double click on Mouse icon
Select the Pointer Options tab in the top
In the motion section, set the pointer speed in the middle.
And also tick Enhance pointer precision .
Click Apply and OK.
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 10, 2010 | E-Machines eMachines Desktop PC
Frozen touchpad
use a mouse for 2 months and (i know this sounds gross)lick your finger and start swipe untill works
Dec 25, 2009 | ASUS Computers & Internet
Activating COT2 wireless mouse
Your ACME COT2 wireless mouse must have come in two pieces, the USB connector the mouse itself.
Insert the USB connector of your wireless mouse to your Toshiba Satellite and press simultaneously the button in your USB connector and the button in the wireless mouse. This is done in order to pair the mouse to the USB connector.
Jan 05, 2009 | Computers & Internet
Dell C640 change touchpad settings
All,
I read on this a while then found these 2 packages and downloaded from DELL's site:
R49155.EXE
R46325.EXE
I installed the R49155.EXE and got 2 more tabs in the properties window for my mouse (Start + Control Panel + Mouse).
In the new "Device Settings" tab I can either totally disable the touchpad or in "Settings", just disable the "TAP to click"; which is the feature causing the cursor to bounce all over.
Also in the active application section of the launch bar, lower right next to clock, an ICON is now present and "TAP to click" is an option, which I can now easily inable/disable; after opening the ICON with a click.
As I understand it, R46325.EXE is the R49155.EXE on steroids, but did not need that.
Cheers!
OMR
Jul 01, 2008 | Computers & Internet
The touch pad pointer is very jumpy. When it is pointed and tapped it Jumps to top bottom or all four coners. Some times while typing a text it jups on its on. The driver has been installed successfully.
Try going to control panel, mouse/touchpad properties and reduce the sensitivity of the touchpad. You may also want to disable the "Tap to Click" option if you often inadvertantly click on an item.
May 17, 2008 | HP Computers & Internet
Keyboard touchpad not working
y-ran 77 cordless keyboard...doesnt work with the l3600 multimedia desktop..it cannot recognize the said hardware...you need to use standard keyboard and manually install the driver for your y-ran77 cordless keyboard
Jan 13, 2008 | Computers & Internet
Computers & Internet Logo
141 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
