Question about Canon LV-LP11 Projector Lamp for LV-7345, LV-7350, LV-735
Lamp problem When initially turning the projector on the image is clear and visible, however within 1 minute the screen just goes blank and the lamp warning light flashes. You can restart over and over again but the same thing happens each time. The lamp replace light never came on prior to this it has only shown the lamp fault light. Is this a failed bulb, lamp assembly or something more sinister?? Ta in advance
  • 1 more comment
  • Stuff4Guys Jan 18, 2008
    I have a very similar problem. I already check the filter and cleaned it but it was not very dirty and it didn't help at all. Any other thoughts would be helpful.
  • Anonymous Mar 27, 2008
    same thing here. Temp inside the projector is normal, maybe its a failure of the overheat detector.
  • Anonymous May 23, 2008
    My projector turns on and the lamp comes on for about 12 seconds. Then the lamp shuts down. I cleaned the fans and filters. Still does the same thing. I opened the top cover and I saw a thermal sensor right by the lamp module. I believe it is the problem. I will replace it and if it works, I will make another post. Meanwhile, if someone has already tried this please let me know. Thanks.
  • 69 Answers
Could be an overheat problem, check any fans and filters are not clogged with dust, lack of ventilation and cooling will trigger a safety shutdown
Posted on Sep 24, 2007
Why does the lamp shut off on the Panasonic PT-AE1000E Projector within 1 minute of starting?
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 26, 2014 | Panasonic PT-AE1000E Projector Lamp...
Why does the projector keep going to standby mode?
If the lamp usage time has passed 2 000 hours (when LAMP POWER has been set to NORMAL), the projector will switch to standby mode after approximately 10 minutes of operation. The resetting procedure should thus be completed within 10 minutes.
1. Insert the power cord plug into the wall outlet and then
press the MAIN POWER switch.
2. Press the POWER button so that a picture is projected onto
the screen.
3. Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
4. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
5. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, "LAMP RUNTIME
RESET." is displayed and select OK.
6. Turn off the power.
This will reset the cumulative usage time for the lamp
unit to zero.
Mar 12, 2011 | Panasonic PT-AX100U-EC DLP Projector
Sanyo plc-xt16 Projector After the projector is turned on and the countdown finishes on initial start up the projector shuts itself off within 5 seconds. The fan runs for 1 minute and then the projector...
It sounds like the lamp is going.
Do you know how many hours of use are reported on the lamp?
Many times these projectors have circuitry to shutdown when they suspect the lamp is near the end of life. Lamp hours vary and usually will go up to and even beyond expectancy, but there is occasions you can receive a bad lamp and have it blow in a matter of hours...not common but it does occur.
I hope this helps,
Magoo
Mar 09, 2011 | Sanyo PLC-XT16 Multimedia Projector
Projector powers up, after 2 minutes image goes away, projector goes into cool down, then shuts off. why?
FAULT: lamp of your projector is faulty.
Experience: when lamp life is near to end and environment temperature is too low you are facing the same problem and if you are facing this problem in normal temperature then also lamp is faulty.
Sulotion: Just replace the projector lamp
Jan 07, 2011 | Panasonic PT-AX100U-EC DLP Projector
Projector turns off after 3 minutes, lamp needs replacement?
Try reseting the filters for the lamp and also clean the air/dust filters.
May 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
My viewsonic pj400 projector switches itself off
hello
i have the same problem, a clear image, the the projector shuts down, turn the fan on, and "lamp" blinks.
i returned my projector to viewsonic service center, they told me to change the lamp.
the problem is that a lamp is very expensive!
HudgeFR
Jul 13, 2009 | ViewSonic PJ400 LCD Projector
Projector shuts down after only a few minutes.
I'm having the same problem. My Model is PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing.
Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem.
Anyone with similar problem or solution, please contact me at dartveiga@gmail.com
Jan 19, 2008 | BenQ PB6100 Multimedia Projector
Canon LV-LP11 Projector Lamp for LV-7345, LV-7350, LV-735 Logo
196 people viewed this question
old marine
old marine
