Question about Sharper Image Ionic Breeze GP SI730 Air Purifier
Won't work Ionic Breeze S. A. P. model # S1720 won't come on, plugged the conveter into another one we have (that works) and it came one so problem has to be in the unit itself; had ad both of them for approximately 2 years or more.
  • 734 Answers
Please read all ---to find the solution---
Ionic Breeze GP began losing power occasionally but I could shake it and get it to turn back on. It got worse and worse until it would not turn on anymore.
The problem on mine is the micro switch that detects whether the collector plates are inserted or not, so it is part of the safety mechanism. There is a about a one-inch cylindrical piece of plastic on the front of the collector plate handle. This cylinder goes through a hole and pushes on the micro switch (actually a plastic cover over the micro switch).
On mine, it appears that arcing inside the switch caused it to get hot, deforming the plastic a little bit and apparently ruining the inside of the switch.
The following URLs describe the switch, but I have not found a retailer that carries it:
http://www.dicgroup.com/pdf/SM/SM5-01N.pdf
http://www.dicgroup.com/e-pro01-sm.html
Another of the same model switch is used in the back of the unit to detect whether the rear cover is on (over the UV bulb).
If I cannot find a replacement, I am thinking of either bypassing the bad switch entirely or swapping the switch from the back. Either way would defeat a safety feature so it's probably not to be recommended, but I consider the sacrificing the switch for the back cover to be introducing only limited risk, so I might take that route if I have to.
I found a suitable replacement switch at Mouser Electronics, mouser.com. It is Mouser part # 101-1203-EV. The problem is that the lever is too long, so I cut it with my Dremel cutting wheel before installing.
Mouser also has a similar switch, part # 101-1201-EV on which the lever is the correct length, however it has solder lugs instead of PC board legs.
I ordered both switches and then made my decision about which to use after looking at them. The choices are either cut (shorten) the lever on the 1203 switch or enlarge the holes on the mounting board to fit the 1201 switch. In my judgement it was easier to cut the lever.
The new switch is installed and the unit is working fine again.
Thanks for using FixYa
Posted on Nov 30, 2008
  • futureloginn
    futureloginn Nov 30, 2008
    Another Try-----
    The rear grill has an electrical contact on it. If the grill is not seated properly, electrical contact is lost and the unit will not run.
    Here's how to remove and reseat the rear grill:
    1. Turn off the unit.
    2. Unplug the unit.
    3. Remove the collection grid.
    4. At the bottom of the rear grill is a blue tab. Pull it toward you and lift the grill up and off.
    6. Put the grill back on so that the locking tabs go into their slots.
    5. Slide the grill down to lock the tabs in place. Verify the blue tab is latched.
    6. Put the collection grid back in.
    7. Plug the unit back in and turn it On.
    If that doesn't work, it is possible the contact in the rear grill is still not touching correctly. Use the steps above to remove the rear grill. Then locate the metal strip on the inside lower portion of the grill. Clean it and clean the metal pin it is supposed to touch on the chassis. If the contact is tarnished, use an emery board to shine it up. Also shine up the pin. Then VERY gently lift the contact a little so that is sticks out further. Replace the rear grill. Insert the collection grid. Turn the unit On.
    Thanks
  • 2,794 Answers
Usually the culprit is the blades. This site has replacement blades for them:
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=0&ProductId=473&gclid=COSTqtrQnZcCFQkiagod_Bg3JA
Since Sharper Image has recalled the units, support from the company isn't possible.
  • 19,396 Answers
Check that there is powere coming into the unit from the AC network.
There must be a circuit breaker and also a fuse on the unit control board, check them out..
My dad has an ionic breeze that quit working. A repair shop told him it was the power supply. Where can you buy a replacement part?
Hi.
If the model is post 2007, to get parts or repair contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read below, in that case I suggest not proceeding with the repair.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Sep 17, 2010 | Sharper Image Ionic Breeze 3.0 Air...
WHAT ARE THE GREEN AND BLUE LIGHTS FOR
To let you know when the ionic breeze is working properly (Green Light) and when it needs to be cleaned (Blue light). Hope this helps.
Apr 19, 2010 | Sharper Image Professional Plus Ionic...
My Ionic Breeze was working fine.. then just stopped working....both of them....but not at the same time.....within weeks apart.....
STILL PLUG IN AND IT JUST STOPED WORKING.ALL LIGHT WENT OUT SO WE CLEANED IT THOUGH THAT WHOULD DO IT BUT IT STILL WILLNOT START.
Mar 31, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Ionic breeze gp does not work .
Hi.
Check power cord. If power cord has a built in fuse, replace it.
Regards.
Ginko.
Mar 27, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Ionic Breeze - Cleaning Overdue light stays on even after unit has been cleaned
Hi.
The filter is damaged and may need replacement.
Regards.
Ginko.
Nov 18, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Ionic breeze stopped working won't turn on was very dusty, cleaned it wont light up
Hi.
When this happens, usually the filter must be replaced.
Regards.
Ginko.
Oct 23, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Ionic breeze gp just stopped working
Hi.
I don't know if you are still trying to repair the air purifier.
About your Ionic breeze purifier, I wanted to report that they are not being manufactured anymore because of heath concerns. New model built from 2008 use a completely different technology. Parts are also not distributed anymore, and the new Sharper Image does not provide any support for the old model.
Regards.
Ginko.
Sep 28, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Ionice breeze quadra Model # S1637
had the same problem with ionic pro ca500. i took the unit apart and found a fuse that was blown and it works now. sorry but i don't know if there is any repair shops.
Aug 02, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Professional Series Ionic Breeze Tabletop
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
Jul 29, 2008 | Sharper Image Professional Plus Ionic...
Ionic Breeze Model SI637
I did that on mine, and was able to take it to an appliance repair shop, some how they were able to fix it
Apr 21, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Sharper Image Ionic Breeze GP SI730 Air Purifier Logo
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
