My sony 8 mm ccd fx411 camcorder door won't close when tape is inserted. closes fine when no tape is in, worked fine 2 days ago - got 1 tape transferred to dvd but have many more to do - help
experttv
  • 203 Answers
SOURCE: sony kp-57ws510 convergenece prblem
You didnt replace the STK's? You must replace the convergance IC's or you will continue to have this problem.
Posted on Sep 18, 2008
tommya300
  • 724 Answers
SOURCE: Sony Video 8 Handycam CCD-FX411tape problem
I have a handy can and had trouble with the cage closing with a tape installed. I found the most unlikely problem the rotation of the drun was slowing up and then siezed eventually.
I took it apart abd it was not a good idea to go any farther into the cage to extract the drum. The drum goes for over 250 dollars the price of half of the camera. Well I figure what the heck I experimented. I soaked the hole cage and drum in Denatured alcohol and unn siezed it. then I blew it out with the air compressor and really made the head spin. Then as I put the unit back together I found i was not careful with the audio ribon cable lost sound but the unit did work for silent movies. It was junk anyways over 250 dollar 3 head drum.
Posted on Jul 25, 2009
SD Tech
  • 14553 Answers
SOURCE: Sony xl 5200 door close safety switch
not sure if this helps---some of these sets had a problem---the three blinks usually means door not closed properly--remove door and look carefully at it--if it is warped from the heat---the plastic peg on the back of it will not engage the lever(it is a safety switch that prevents the set from working if the door is removed) look behind the door where the plastic peg is--if it is your problem you just have to use something not metal to move the lever and then while in place turn the set on---if it comes on normal--order a new door---they are about 5 dollars plus shipping--if you need direct help email me with the exact model number--if this has been helpful give me a vote------
etower.766@netzero.net
Posted on Aug 13, 2009
  • 68 Answers
SOURCE: TV not working after replacing lamp
yes, the door has to engage a switch and if it doesn't the tv will not come on it usually has a 3 blink error if this is the problem. Is your red light flashing in a 3 blink series?
Posted on Sep 16, 2009
satavlad
  • 405 Answers
SOURCE: Sony Handycam CCD-TR64 cassette door won't close
Common problem with this mechanism. In order to fix the problem you will have to replace part called CHASSIS LS. Expensive repair, probably not worth the effort.
Posted on Dec 04, 2009
Testimonial: "Thanks. We ended up getting a new camcorder. That Handycam was as old as I am (18 years), so it was time for an upgrade anyway."
Sony CCD FX500E ejects tapes
Mechanical fault. Contact any service technician; or the authorized service centre for Sony. Electro help
Nov 29, 2014 | Sony Video Cameras
Jammed by putting tape in upside down
Take off the battery on the camcorder. Insert the battery and at the SAME time, push the power and the eject to see if this resets the camcorder so it will eject. If this does not work, I'm afraid the unit will need to be taken apart and removed manual. Good Luck
Jun 25, 2007 | Sony Handycam CCD-TRV37 Camcorder
Sony video handycam ccd fx420
The take up spool is no longer working. Time for a new V8 machine.
Jun 10, 2017 | Video Cameras
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
I have a Sony Handycam CCD-TR61. It has worked fine until today. It will not accept a tape. If I close the door without a tape it closes and completely shuts like it is supposed to. But if I put in a tape...
Many times it's a belt slipping. Since the tape isn't pulled into position, it's rewound and the tape ejected. A damaged or mal-adjusted switch could cause this too. The most you can do is blow it out with compressed air to see if that helps. I doubt there are many thing the end user could do.
Oct 29, 2017 | Sony Handycam CCD-TR618E Camcorder
Handycam CCD-TR618E Hi-8 Analog Camcorder: I have a Sony Handycam CCD-TR61. It has worked fin...
that is look to be the cassette in switch
located on the side of the cass housing
or a sensor ...
hope that will help and this kind of trouble
is easy to fix for experienced tech an hour max
hope you will find one
regards Alan
May 18, 2010 | Sony Handycam CCD-TR618E Camcorder
Dec 04, 2009 | Sony Handycam CCD-TR64 Camcorder
Have a 1993 Sony CCD-FX420 camcorder that I have not used for a few years. The tape deck opens and closes fine without a tape, but when I insert a tape it won't completely close. How do I fix this? Thanks....
It is more than likely that during the period of prolonged storage in less than ideal conditions, some moisture has entered the camcorder and rendered it useless. This camcorder is also some twenty-four years old, and all consumer electronic devices have a limited life, even if well looked after. I feel your only choice is to replace it, and keep the replacement in optimum storage conditions - maybe in a dry cupboard indoors.
Apr 03, 2017 | Sony Video Cameras
Tape door wont close on my Sony CCD-TR416 camcorder
Try this for anyone having this issue:
HERE'S WHAT WORKED FOR ME PER SONY TECHS:
Take? OUT the battery or disconnect the AC cord.
Turn the camera ON (tape, memory, edit settings) for 15 seconds.
Turn camera to off setting.
Plug battery or AC cord back in.
VOILA!
Worked for me and I had the stupid C32:11 error code for weeks! Door would not close. Followed the SIMPLE and SAFE instructions and IT WORKED! Just like magic. I couldn't believe it! Save your money TRY THIS!
Sep 22, 2009 | Sony Handycam CCD-TR416 Camcorder
Loading tapes
I had the same Problem. My Solution was i open the camera, then i take the batery away. I put the tape into and close the camera, then i put the battery into and the camera close with the tape
Nov 05, 2007 | Sony Handycam CCD-TRV40 Camcorder
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
