Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Hitachi 51f500(flicker+warp) I have a problem i bought my hitachi 51f500 in 2003, only about 4 months ago the screen started to flicker and warp. This began on the right side espically on the top. Now it happens all the time but now the entire right side is warped and flickers and it even crosses the screen to the left side. I have done manual convergence, this seems to help only for a while(within 30min or so). Please note to the right side of mt rptv i have my power amp and pre-amp. Can this be the reason for interference? is the amp causing an electrical field causing the guns to mis-align?. The picture is always fine, no clor changes or brightness issues only the warping and flickering. Can someone please help me with my problem. Thanks.
    President:
  • 1,284 Answers
Most likely bad convergence IC's! Location numbers should be IK04 and IK05. Generic numbers STK392-110.
Posted on Jan 26, 2007
Red bulb is out and flickers on and off
COUNT THE TIMES AND SEQUENCE..OF RED FLICKERS.CONTACT TECH SUPPORT
Dec 12, 2013 | Hitachi 51F500 51" Rear Projection...
MY TV HAS BLUE AND YELLOW SHADDOWS, cAN i REPAIR IT, OR IS IT TO OLD. 2003 MODEL mARK
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 01, 2011 | Hitachi 51F500 51" Rear Projection...
Blue Wave on Screen
If this is a DLP set the type that takes a lamp the light engine is going bad. I would get ahold of Hitachi they may do something for you.
Feb 15, 2010 | Hitachi 51F500 51" Rear Projection...
Screen on tv is turning blue through the center
you have a lcd plate that is warped in the light engine and it will have to be repalced to correct this problem
you might contact hitachi and see if there still offering assistance or will provide a light engine you may have to pay labor if it still is on going but thats better then footing the whole bill
Oct 24, 2009 | Hitachi 51F500 51" Rear Projection...
Hitachi 50" tv bought in feb 07-Approx 6 months ago tube was repl
YOU NEED A LIGHT ENGINE COST ANY WHERE FROM 800 TO 1500 TRY TO GET ONE BY COMPLAINING LOUDLY TO HITACHI FIRST
Jun 10, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 51G500A and the screen when blank
Hi I am vortash I have just looked at the service manual for this set and it actually does not use a bulb as it is not an Lcd or DLP projection TV . It actually employs three CRT based tubes that produce the picture with automatic focus and convergence systems . If you do not have the manual for this set you can download it from http://www.safemanuals.com free of charge It says that if you have sound and no picture turn the set off and unplug it for 3o seconds then replace plug and turn on from switch on set not from the wall plug switch .. as this may reset the tv and cure the problem .. hope this helps regrads Vortash
Jun 08, 2009 | Hitachi 51F500 51" Rear Projection...
Picture is blurry
remove front panel and check the 6 control knobs adjust the intensity of each color as well as the focus of the picture with those colors.be sure to mark the knobs so you can return them to there original position if the set shuts off. Good luck
Jan 28, 2009 | Hitachi 51F500 51" Rear Projection...
Hitachi 51F510 screen wont turn on
lighting can effect anything and everything, call insurance and get replacement value for set.
Nov 16, 2007 | Hitachi 51F500 51" Rear Projection...
Leaky CRT's
i would not repair unless you also replace any circxuit boards that the liquid fell on. although it is now water it will corrode the parts & will most likely cause further problems. the only way to ensure that future problems are not related to this is to replace the boards affected. good luck.
Feb 01, 2007 | Hitachi 51F500 51" Rear Projection...
TV Flickers up and down and screen is shifted to the right w/ red color dominating the screen.
the last hitachi that had this problem i fixed it bad finding bad solder conenctions throughout the board that the convergance ic's are on, also i foind some on the two main board in my repair. hopefully resoldering the convergance foard will fix the jitter or jumping around problem. if the picture is too red you can also try turning down the screen control slightly. good luck
Jan 02, 2007 | Hitachi 51F500 51" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
133 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
