Question about Kodak EASYSHARE 5100 All-In-One Printer
Banding on my pictures
When i print pictures i get banding
i have tried getting into maintenance or instruction to clean heads but it won't let me
i just need to knoe how to clean the heads
  • 91 Answers
Try the following:
Clean the printhead, then print a demo sheet.
1. Verify that inkjet paper is loaded in the paper trays.
2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
Let me know if this works, Thanks Binary Bob
Posted on Nov 30, 2008
Prints pictures faded
On the pixma printer each time you remove a cartridge. you will need to do a clean of the nozles and print head. you can find instructions in your online operators manual. You hold down the wi-fi button and watch the
Home Click Here to Search
MG3500 series > Overview of the Machine > Maintenance > When Printing Becomes Faint or Colors Are Incorrect
Maintenance Procedure
Printing the Nozzle Check Pattern
Examining the Nozzle Check Pattern
Cleaning the Print Head
Cleaning the Print Head Deeply
Aligning the Print Head
Page top
error light flash. 1 flash release prints all saturation levels2 flashes prints the head alignment chart. 3 cleaning 4 flashes deep clean and so on. or its a transfer problem and this case do a transfer belt clean, and a head alignment.
Feb 28, 2014 | Canon Ink Cartridge for Pixma MP252
Magenta won't print at all on test page. Tried normal cleaning cycle several times to no avail. Also tried "power purge" cleaning cycle twice also with no success. Help!
The magenta print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
May 20, 2013 | Brother MFC 6490CW InkJet Printer
I put in new ink cartridges and the cyan pink won't work.i have a lexmark prevail pro705.
Hello Rina! Welcome to FixYa!
If you have changed Ink Cartridge and after changing Cyan Pink is not printing then you may resolve this issue by Cleaning Print Head, Sometimes due to clogged print head nozzles this problem may happens. By cleaning the Print head Nozzles, This problem may resolve.
From the Printer Control Panel, Navigate to Maintenance, Press Up and Down arrow button to scroll Clean Print head or deep Clean Print Head and then Press OK.
Now try to print again. I hope this issue will be resolved
I hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Feb 14, 2012 | Lexmark Office Equipment & Supplies
Lexmark X75 won't print in color. Tried cleaning print heads, didn't work. What now?
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 16, 2011 | Lexmark X75 All-In-One InkJet Printer
Copying black but it is only printing in bands with white bands throughout.
Your print head is probably clogged. You need to go to "start", then "settings", then click on "printers and faxes". Right click on your printer, then click on "properties". A window will appear with several tabs. Go to the last tab named "maintenance". You have several options, but the one you need is "deep cleaning". Click on that and follow the instructions. You might have to repeat the process several times in order to get a satisfying copy. I also have to warn you that cleaning the print head uses a lot of your ink, but it should solve the white bands issue.
Apr 01, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Mar 18, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Horizontal banding on prints
try aligning the print heads before cleaning them
Oct 10, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Red lines across page
What program are you using to print the pictures? Try cleaning the print heads and using another program.
Feb 20, 2008 | Epson Stylus CX3200 All-In-One InkJet...
My canon multipass f80 printer makes colored bands (1/8 of inch) through the pictures
Prints heads have to be alinged and or you let it sit too long without print and your print heads have to be cleaned
Dec 08, 2007 | Canon MultiPASS F80 All-In-One InkJet...
"Banding" on Prints
Do a thorough manual cleaning of printerheads (where the cartridges sit). Many printers are notorious for clogged nozzles and the ink dries on he prinheads until it becomes a bandind issue or ladders appear, smudges too. Use a proper cleaning solution and cotton buds, until most colour is gone off cotton buds. Reinsert cartridges and try again.
Aug 25, 2007 | Canon i9900 InkJet Photo Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
49 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
