Question about KitchenAid Architect® Series II KEBS208S Electric Double Oven
No power and door locked after starting self cleaning cycle
KitchenAid KEBS207DBT 6 built-in electric thermal-convection ovens.
Started self dcleaning cycle for forst time, got 2/3 of the way through and power shut off (no circuit breaker tripped) and now cannot use either oven and cannot open the top oven door.
Please help
  • Carolyn Bartz
    Carolyn Bartz Nov 30, 2008
    Thank you for your help. Can you give us any suggestions on how to get the door open so we can locate these fuses
    Sergeant:
    Champion:
  • 311 Answers
Thermal fuse went out by door latch and thermal fuse on back of oven probably tripped too; once failed they need to be replaced. This is probably a job for the repairman as something caused fuse to go out in the first place; unless resolved it will recur. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
  • JEFF SIEGEL Nov 30, 2008
    Fuses must be obtained from appl parts store; no one else has them. You can probably stick an allen wrench in vent at top of door and catch latch- pull it to the left to disengage; I am unsure how latch is on yours, so this may not work as some latch motors won't let you maove the latch hook. Let me know if you get it open. Don't forget that cause of this problem must be fixed-replacing fuses will not solve the issue.
    New Friend:
Offered solution to problem doesn't sound like my oven's symptoms
Posted on Feb 07, 2014
Door is locked after self cleaning
Most ovens with self-clean cycles have a door lock to keep things closed when it ramps up the the extreme heat levels for cleaning. Usually, the door will stay locked until the thermostat sensor says that the oven is back down at or close to room temperature. If you just finished the cleaning cycle, you'll likely need to wait a while longer.
Nov 24, 2015 | Whirlpool Gold 30 in. Electric Convection...
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
Started the cleaning cycle, and cycle stopped with a beep. Power is still on. Error F5 E1. The door is now locked.
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.
This code means the control has detected a problem with the door latch switch. Switch is defective and needs replaced. Part # is W10107820 and cost is $39.99. You can get it at this LINK
Before calling a repair shop,go to the circuit breaker box and turn off the power to the oven. then turn it back on and then see if the door is released and the error is cleared.
its probaly bent door latch or door sensor gone bad. try pushing on the door when you start the clean cycle see if that helps.
if not our suggestion would be to replace the part....
Oct 23, 2010 | KitchenAid KEBC107 Electric Single Oven
Thermal protection fuse has started burning out when oven self-cleans. Ran fine for years, now this has started happening. Not every time it self-cleans, but have now replaced second fuse in 2 years. Is...
The most common reason for this is the door not sealing properly, if hot air escapes out the seal during the clean cycle it will be pulled across the thermal fuse.
The second most common cause is reduced air flow. If the blower wheel is dirty it cannot move as much air across the fuse to keep that area cool, if the vents just above and below the door are dirty and dusty they can block air flow too.
Aug 01, 2010 | KitchenAid KEBC101 Electric Single Oven
After using self cleaning feature...oven door locks up...4th time this has happened...kitchenaid says "no known issues with your unit or the problem you reported...can you halp
Hello - we have had this same issue a number of times as well. Do you lose all power on the unit too? We do - have discovered that using the self-cleaning isn't really a good idea with these ovens. The ovens aren't really made to heat to such high heats that are used in the cleaning cycle and during that last hour of cleaning it hits it highest peak - and it blows it's fuses. We recently blew 2 fuses at the same time, locking both doors (Double oven) and knocking out the power for the entire unit. Our repair man said that the average on wall ovens is anywhere between 6 - 12 cleanings before you will blow the same fuses and the whole cycle starts all over again. Our expense was $350. So, self-cleaning now means elbow grease around this house. How this information was a bit helpful for you.
Jul 02, 2010 | KitchenAid KEBC208 Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Jan 18, 2009 | KitchenAid Architect Series KEMC308KSS...
OVEN will not heat
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Feb 24, 2008 | KitchenAid KEBC107 Electric Single Oven
KitchenAid Architect® Series II KEBS208S Electric Double Oven Logo
365 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Jim Goldsmith
Jim Goldsmith
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
