Question about Compaq Presario s4020wm (DK214AR#ABA) PC Desktop
Presario v6000 Sart up.
Hi
I have just ordered recovery disks as the hard drive went down. I have inserted it and loaded it on the laptop but after a certain point it just reboots itself and goes through the same procedure again. Im only a novice so just wondered if theres anything im doing wrong. HELP
Thabks
Jay
  • 64 Answers
After reboot, before restart, take the recovery CD out and let the computer start from hard disk. Let me know what happens.
Posted on Dec 01, 2008
My system files disk stops loading about half way through. What can I do to fix that?
Hi Sobig,
Several possibilities:
What is the read capacity of the DVD drive vs the recovery disks?
Some disks come in the high-capacity 8 GB storage format, whereas most DVD drives are designed for 4.7 GB.
If that's the case, your DVD only 'sees' half the optical disk data. Is RAM enough?
The system could be locking up when resources are used up.
Other than that, (I'm guessing) that e-disks are faulty or incompatible.
If I lived nearer, I could look at it.
So hope something helps here.
Regards,
Clive.
Oct 28, 2017 | Computers & Internet
No bootable device - insert boot disk.
press F8 continuously after you turn on the laptop, then you will see a bios screen. Look if hard disk is detected in bios
May 20, 2012 | Compaq Presario CQ60-220US PC Laptop
Installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Apr 22, 2012 | Toshiba Satellite P105-S6104 Notebook
Black screen v6000 laptop "HELP Please"
It appears the hard disk has been wiped/formatted and does not have an operating system installed.
You need to get a Windows Vista installation CD and if the Windows label on the bottom of the laptop is still attached then this label has the product installation code.
Boot up with the Windows Vista installation CD to install the Vista operating software then you need to install the Presario device drivers.
You can download the device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Mar 19, 2012 | Compaq Computers & Internet
Compaq presario v6000 computer does not detect hard drive storage
The hard disk may be faulty or it just needs reseating to make proper connection.
Reseat the hard drive and boot up your laptop. If it does not boot up then go into the BIOS configuration to see if the BIOS detects the hard drive.
If the BIOS deos not detect the hard drive then most likely it is faulty. In this case to get your laptop working again, replace the hard drive and install Windows on the new hard drive plus the Presario's device drivers and your programs.
Jun 21, 2011 | Compaq Presario Notebook
I have a Compaq Presario CQ60-211 DX. My son was messing around with it, and it went to a blue screen, shut down, and when i tried to restart it, it says no bootable device, insert boot disk and press any...
Make sure the disc is readable. Try to copy the entire disk on another laptop/pc. If the copy runs fine, then it must me something else -- perhaps the HDD.
Apr 29, 2011 | HP Compaq Presario CQ60Z Notebook
COMPAQ PRESARIO M2000 RECOVERY DISC WILL NOT LOAD ON NEW HARD DRIVE
The issue here to be quite frank is the hard drive needs the compaq image before the recovery disk can be loaded. This provents people from taking there compaq disk and getting wise and installing it on multiable computers what authors call piracy.
What you need to do is have compaq NOW HP send you out a IMAGE recovery disc usually when a hard drive crashes they send you out the hard drive with the IMAGE.
The other solution is purchasing windows 7 upgrade and going at it from there.
Thanks hope this helps please do not shoot the messenger and leave postive feedback and ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 11, 2010 | Compaq Presario M2000 Notebook
Compaq Presario C300 Recoivery Disc 2 corrupt
Hi John.
F11 process is not working and you get a NTLDR missing when you turnon the notebook.
Steps to be performed:
1. Perform hard drive self test from BIOS.
2. If it is passed then use retail version of operating system disk to install XP or try using new recovery disks which nay cost you $15.00.
In your notebook model this issue appears if there is any issue with the hard drive.
Jul 04, 2009 | HP 435768-001 - Compaq Presario C300...
Recover problem
This can happen if the Recovery Partition is corrupted or the Hard Drive is bad.
 First, I recommend you to check the Hard Drive using the Hard Drive test utility available in the BIOS by following the steps below :
Start or restart the notebook and start tapping the F10 key.
This will get you the BIOS Setup window.
In this. go to the Diagnostics or Tools tab where you can find the Hard Drive test utility.
Select using the Up/Down arrow keys and press enter to start the test.
Make sure that you complete the Full test which may take around 80 minutes to complete.
If the Test result is Pass, we can come to a conclusion that the issue is with the Recovery Partition which is corrupted.
You need to purchase the Recovery Disks for your Notebook in this situaiton.
Contact HP Chat Support to get the exact link to order the Recovery Disks for your Notebook.
However, if the Test Result is Fail, you need to take backup of the data in the Notebook and replace the Hard Drive with a new one.
Hope this helps...
Oct 07, 2008 | HP Compaq Presario v3000z Notebook
Compaq Presario s4020wm (DK214AR#ABA) PC Desktop Logo
85 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
