Frigidaire washer does not fill as quickly as it should; do I have a solenoid problem?
    Sergeant:
    Champion:
  • 311 Answers
Check screens on valves and hoses first; if clear repl valve. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
My drum fills with water and is not turned on
Sounds like water control solenoid is stuck in the open position.
The hot and cold solenoids are located just inside where the hoses attach to the washer.
Feb 28, 2015 | Frigidaire Affinity FAFW3801LW 27"...
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
Will not agitate or spin, does fill with water. Just happened. GLWS1233A Frigidaire top load
I replace a new solenoid, I started to get my cold water but then, I replace a new lid lock and it stop agitating. Could you please help me.
May 16, 2011 | Frigidaire GLWS1233A Top Load Washer
Frigidaire fwsb5700ds0 top load washer is dripping water from the water fill spout..why would this be occuring?
sounds like you may have a bad inlet water valve the solenoid is not closing all the way... you may be able to try and shut water off and remove hoses and clean screens out of valve itself. first unplug unit and if water continues to drip then that is going to be your problem as that elements anything electrical energizing the valve and shows you have a faulty solenoid not closing all the way...\
hope this helps good luck
Jan 06, 2011 | Frigidaire FWSB5700DS Top Load Washer
Washer filling with water when washer is not being used.
You have leaking solenoid water valves. You can shut off the faucets when unused to circumvent replacement of the solenoid valves, but the leakage is repaired by replacement of the valves. Hope this helps!
Mar 05, 2010 | Kenmore HE2 Plus Front Load Washer
Frigidaire Washer GLTF530DS0 motor doesn't run ohm test ok
could be a thermal fuse that has blown that protects the motor.Does your washer fill with water and set there? If so its probably your door or lid switch. There is a quick way to find out unhook door switch and connect wires together with electrical tape then try the washer. If it works replace the bad switch
Aug 24, 2009 | Frigidaire Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer has quick cycle will not fill on this cycle only on larger cycles
Seems you have a faulty water fill valve. It's reading full before it really is.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Top wand does not spin
You may have a water volume problem.
The water fill sequence on most washers is timed. Insufficient water at the bottom of the washer will cause the pump to cavitate.
Ensure water is filling to just under the heating element.
You can fix this by isolating the water and electricity then remove the fill solenoid. Inside the solenoid is a top hat filter screen. This screen captures sedement.
Once the sedement was removed on my washer the wands turned
My machine also had a check valve on the bottom near the back of the machine that was blocked.The valve needs to work freely in order for the pump to build pressure. The check valve can be removed from the top by turning the assembly counter clock wise.
Feb 01, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire gallery stack wash/dryer
Sounds like it could either be a bad solenoid in the fill valve or a bad pressure switch...both issues are easily repairable.
Jul 28, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
