Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
I own 3 motorola ht 1000 radios 450 -512 mhz & need to program
Is software available to do so? If so, where & approx cost? Thank you
Lloyd
  • l_plassejr Nov 30, 2008
    I need to program 3 motorola ht 1000 radios. Is software available & how much does it cost?
  • eradiostore
    eradiostore May 11, 2010
    The subject line of your post was truncated due to it being too long. Could you please give more information, so we can understand what your question is?
  • Motorola Master
  • 1,654 Answers
The software for programming the HT1000 radio is only available by subscription to authorized Motorola dealers and other entities authorized by Motorola. The cost of reprogramming varies from dealer to dealer, but in most cases it is between $25-$40 US, for the first radio, and sometimes less for the next ones, if they are the same model number and clone-able.
FYI: You may find "pirated" versions of the software available online, but be aware many are flawed, and can cause a corrupt codeplug in your radio.
Posted on Nov 30, 2008
Motorola astro moblie programming !!!!!
"No longer supported" means they don't repair them at their repair depot anymore. However, software for most models is still available. All Motorola software is by subscription, and they choose who can obtain a subscription. You must be a Channel Partner (dealer) or meet their criteria for obtaining it.
Most 800 MHz radios are trunking radios, and require a tower system to operate. Many towers in this bandsplit have been shutdown or retired due to changes in the licensing/availability of 800 MHz frequencies.
If you are planning on operating the radios with a tower system, see the owner of the system for programming. If you are wanting to use the radios in simplex (radio-to-radio), you could get them programmed at a full-line Motorola dealer. You will need to provide your FCC assigned frequencies.
The model number you mention is incomplete, and I could not determine which of the softwares you might need.
Best regards.
Feb 07, 2013 | Motorola Astro Spectra 800mhz Mobile...
Need a user manual for ht 1000
For this concern that you're looking for the user manual for this device , you can go to this link then download the user manual save a copy of the manual to your computer or print it out for future use.
http://www.repeater-builder.com/motorola/jedi/ht1000-specs.pdf
Jan 06, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
I have a motorola Ht 1000 i need to no how to program it with the keypad only...
The HT1000 is not keypad programmable. The HT1000 is dealer programmable using a radio interface box (RIB), cable, the appropriate Motorola propietary software. A sister radio named the JT1000 can be made keypad programmable with an accessory called a programming key.
Best regards.
Nov 29, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
GP300 frequency programing
Here is what you would need: RIB (radio interface box), HKN9857 programming cable and HVN9128 programming software. You are correct the software is only capable of running on a DOS box, such as a 286 or 386. The software mentioned is Motorola proprietary and is available to Authorized Motorola dealers by subscription only.
The book also shows a cloning cable HKN9755 as being available. Don't know anymore details on it.
Lastly, the cost of programming to your FCC assigned frequencies would be approx. $15 per radio, and less for cloning like models. It might be less expensive to have the radio programmed by a dealer. Just an FYI.
Best regards
Jun 02, 2009 | Motorola GP300 Compatible 2 Way Radio...
I need to learn how to program my motorola HT 1000 that has a number pad on the fron.
You cannot program the radio from the DTMF keypad. The HT1000 is only programmable by an authorized dealer or person with a subscription to the software. It also requires a programming cable and RIB (radio interface box).
Jan 31, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT 1000 programming cable
Sorry to let you down, but the cable will only function with the appropriate Motorola software (and possibly a radio interface box (RIB) if the cable type you have requires one.) Software is only available to dealers. If you are needing reprogramming, it is generally available for between $25-$40 US.
Nov 17, 2008 | Motorola For MT2000 HT1000 HT6000 GP900...
Motorola HT 1000
Your radios might need reprogramming. This is done by a Motorola dealer using the appropriate cable and software. The software is not available for end-users. Cost generally is $35-$40 US.
From the information you provided, it is unclear if the radios previously worked together; or if the radios are the same model number. These are facts the dealer would be able to inquire about, and it would help them determine if your radios can talk to one another.
HT 1000 Set Scan mode
First, your radio must have one of the side buttons programmed to be scan on/off. You will need to experiment while one or more of the channels is active and press the side button to see if it puts you in scan mode.
If it is, most likely a short press turns on scan, and a long press would be nuisance channel delete. This feature will temporarily eliminate a channel out of your scan list for the time your have your radio turned on. Once you shut the unit off and turn it back on, it would return to the original setting.
The only way to have a button programmed for scan/nuisance channel delete, is to us Motorola propritary software available to dealers and certain businesses and governement agencies. If you are needing to turn on scan or change a scan list, you would need to have the radio reprogrammed. This typically will cost between $25 and $40 at more dealerships.
Oct 03, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Ht 1000
a computer with a 286 or 386 processor
Dec 24, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Anyone have a User Manual for a HT1000?
This "switches" functions are asigned by the programmer, and depends on the systems requirments or the user habilities check with your radio programmer for any feature that you can have on your radio.
Nov 21, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
142 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
