Question about Roper RGX4634KQ Gas Dryer
No heat and the timer won't turn the dryer off
Model # is rgx4635ew1
  • 121 Answers
The timer runs thew the heat cycle with no heat it will run forever the heat runs thew the timer and thew thermstats and thermal fuses be for going to the heat elament check for 220volts at the heater if the heater has 220volts to it and not heating the elament is bad
Posted on Nov 30, 2008
Dryer wont heat
The only thing left to check is the voltage at the heating coil. IF it is not present then the timer or relay is bad.
Jul 22, 2013 | Speed Queen AES17AWF Electric Dryer
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
Dryer won't shut off.
Will the timer advance in the NO HEAT mode? If it does advance you would know it has something to do with the temp alright but if it don't advance in No Heat then the timer motor is bad in my opinion. And it can fail by more than one way. Open winding OR stripped motor gear.
Aug 30, 2012 | Maytag Dryers
Kenmore front load dryer won't heat and timer broken
The most likely cause is the timer is bad. It turns on and off things as it cyles through and the first step is to get the tub turning before it turns on the heat.
Jun 01, 2012 | Kenmore Dryers
Check lint screen sensor won't go off
dryer runs but won't heat timer must be turned by hand
Apr 30, 2012 | Kenmore Dryers
The timer doesn't work and the dryer does not heat up.
I would look for reasons why the dryer has this condition. Remove the vent pipe and see if their is lint buildup. If you see air restrictions that means your safety has tripped or melted.
That model number is incomplete. Gotta shoot from the hip on this one:
Get the back off there. You made no mention if the dryer was not working nly said it was not heating sooo.....
I think if you found this:
9_29_2011_4_29_16_am.jpgand the dryer does turn and it is electric heat then this is the probo:
It is mounted on the heating element housing:
OK if all of the safety are good when being checked with a meter with their wires removed yall could have a bad timer:
OR a bad circuit breaker
If your unit shuts down in less than 10 minutes then I would guess yall have electronic sensors but since you made no mention of that being the case then I feel like your model must be one which features autodry. Autodry uses the limits on the heater housing to determine movement of the timer motor. When the heat is on the timer won't advance and when no heat is applied it moves a little bit. Eventually them clothes will get so dry the heater will be needed less and less by the control thermostat. At which point the timer motor will advance steadily towards cool down mode.So what goes wrong? The vent being blocked causes excessive heat. If the filter housing was blocked like this:
The fuse would melt and kill the motor through the door switch circuit. It would be as if you opened the door. The dryer won't go no mo. But if the vent was clogged the fuse would not melt because it is rated for 350f. That leads me to believe your small limit on the heater housing has failed. That being the case it will run all day and never dry them clothes. NOW if yours is a gas model then that is an animal of a different nature. A gas dryer that is also an autodry model would never give power to the gas assembly if this duct fuse was blown:
It is wired into the gas valve assembly circuit And if that is the case then yall have a clogged filter housing like this one:
I recently did a tune up on one of these dryers and took some photos
I also wrote a tip for FixYa about these wonderful dryers HERE
My dryer BLOG
Nothing is difficult about repairing a dryer. A handful of knowledge is betta than a bag full of gold.
Sep 29, 2011 | Kenmore 500 6952 Dryer
Dryer wont shut off unless turned off and dryer just tumbles with no heat.
If it won't turn off or heat then it is probably the timer or if it is a newer unit the control board.
Aug 06, 2011 | Kenmore Dryers
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
Whirlpool electric dryer
As long as the timer is on your heating element will be on.Sounds like you've have lost both.
Feb 11, 2009 | Whirlpool LEQ9858P Electric Dryer
Roper model #rgx4635ew1
replace thermal fuse when no heat in dryer will not advance timer will continue to run all day long
Nov 30, 2008 | Roper RGX4634KQ Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
182 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Roper Dryer Expert? Answer questions, earn points and help others
