Question about Dell A940 All-In-One InkJet Printer
A940 printer will not power up.
Power cord connected. Verified power at surge protector. "Green" power light will not come on. Is there a fuse somewhere?
  • pblose Nov 30, 2008
    Additional info from pblose. This is a 4 year old printer that has worked fine up to this point.
    From pblose. Already tried alternate power strip and outlet.
  • 33 Answers
If you have a DC volt meter, pull the little box out of the back of the printer, (the one that the power cord goes into), and see if you get power at the 2 terminals you see. If not, then you have to replace. The part number is 13D0300. I have a used one if interested. Or you can seach ebay and find one.
Larry
Posted on Nov 30, 2008
    Scholar:
  • 69 Answers
Please remove the All-in-One from surge protector and try connecting it directly to a different wall out let.
Thank you.
How to turn on hp 3600
Unplug the power cord from any surge protector, extension cable, or power strip, press the power button on the printer several times. Plug the power cord directly into a wall outlet.
Feb 21, 2015 | HP DeskJet 3650 InkJet Printer
We had a power outage, now pixma Mx410 won't come on, any ideas?
Is pinter plugged into a power strip? Try plugging directly into wall. Make sure wall outlet is working correctly, try another item in plug in. Does printer have a power module or brick that is plugged into printer? That power module is there to protect your printer during a power surge, it may need to be reset. Is there a light on that brick or power module? If so, does it light up? If not, could be a bad power module. There is no such thing as "reset" button, so don't look there...It will have to be reset in a series of ways for an "external" module.
  1. Disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet, power strip, or surge protector.
  3. If the printer uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. If the printer uses a power module with a detachable power cord, reconnect the power cord to the power module.
  6. Reconnect the power cord to the rear of the printer.
  7. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  8. Check to see if the power module or the power cord has an indicator light and if it is on
For an internal module:
  3. Wait 15 seconds.
  4. Reconnect the power cord to the rear of the printer.
  5. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  6. Check to see if the power module has an indicator light.
Not sure if this will help you..but worth a try.....
Jun 15, 2014 | Canon Pixma MX410 All-In-One Printer
No power to computer, flashing green light by power cord
reset the surge protector first!
then investigate the power supply
Mar 27, 2012 | Compaq Computers & Internet
No power to LexMark x6650
If you are encountering power problems with your printer, please go through the following checklist:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Jan 18, 2012 | Lexmark X6650 4-In-One Wireless InkJet...
There is no green light on my printer
Nov 19, 2011 | Lexmark X5150 All-In-One InkJet Printer
Display not showing anything but the cord has a green light inside cube protector and red light under copier deck and lid
Try to unplug the power adapter from the printer.
Wait at least 10 sec before replugging the adapter. This will give enough time for the printer to reset itself. Also, make sure the printer is plugged in straight to the power outlet in the wall and bypass any power surge protectors.
Apr 25, 2011 | Lexmark X5495 Printer
Of 3 lights: green on right and red in center are flashing, unable to stop them.
How to fix blinking lights Printer lights blink in certain patterns to tell you about specific problems. Read this document until you see the pattern that your lights are making. The solution is below each pattern. NOTE: There may be more than one reason why the printer lights are blinking, so you may see several solutions. PRINT CARTRIDGE light RESUME light POWER light Off Off Off c00106861.jpg c00106862.jpg c00106863.jpg Problem
The printer will not turn on.
Solutions
1. Check the power cord or power module connections at both the printer and the power source (power outlet, power strip or surge protector).
2. Try disconnecting and reconnecting the power cord or power module to the printer.
3. Try reconnecting the power cord or power module to the power source or try a different power source.
4. Verify that the printer is connected to a power outlet that works.
5. Make sure there are no additional switches turned off, such as those on a power strip or surge protector.
6. Check the power breaker to make sure the power source is working.
If these solutions did not fix the problem, have the printer serviced. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09170&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=59129
Dec 09, 2010 | HP DeskJet 940c InkJet Printer
I have a gateway desktop computer. Recently moved
Before you actually replace the power supply, check some other things first:
1. Wall socket
2. Power strip/surge protector
3. Power cable
4. On the back of the computer, where the power cable plugs into, is the red switch set to 115? It should be 115.
5. Make sure that the power cable is not connected to a regular extension cord. Power cable must plug directly into a surge protector that is not daisy-chained to another power strip, surge protector, or normal (household) extension cord. Surge protector must be directly plugged into wall socket.
If none of the above solve the problem, open up the case and ensure that all power connections are secure. Also check ALL other components' connections. Any loose connections can cause problems for you.
If everything is secure and the problem persists, replace the power supply.
Nov 27, 2009 | Office Equipment & Supplies
Compaq Desktop won't start after city wide power failure
Dear! format your system and istall drivers after individual reboot ..
by khalid (Kashmir)..
E-mail:-shahworld_2998@yahoo.co.in
May 05, 2008 | Compaq Presario S6300NX PC Desktop
Emachine with XP home edition doesn't start
Hi hearalso, down to the basic's. Replace power cord.
No help there than, remove the case's side panel to expose the motherboard. (Normally it is the left side panel while facing the front of the PC.)
Look closely for a small (green in color) led light. The power cord must be connected to the PC & connected to you're power strip but do not press the power on button on the PC.
The green led tell's you the board is receiving 5volts. Check all connections. Un-plug & reconnect every data & power connector in your PC. (Double check). There is a fuse inside your power supply that may have blown. Check you're manual page, Approva Statements B-1. Fuse Warning Instruction Caution.
Check fuse in power supply. (Unplug power cord before opening).
If you can not power up the PC after all of the above than if possible, swap out the power supply.
Replacing the power supply is the last step.
If you have more questions, feel free to ask.
Good Luck!
Mike
Apr 09, 2008 | E-Machines eMachines Desktop PC
Dell A940 All-In-One InkJet Printer Logo
104 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
