Question about Microwave Ovens
Russell hobbs combination microwave oven (HOB CJ/AL28).The plate inside my microwave no longer rotates and also the light has stopped working to, it is only a year old!Also when it gets to hot its turns itself of which is usually afeter about 2 or 3 minutes. can u give me any advice many thanks
  • Anonymous Mar 31, 2014
    blows trip very intermittently
  • Microwave Ovens Master
  • 9,098 Answers
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
It sounds like the switch is not activating properly, and the inside light, turntable and magnetron cooling fan are not coming on.
If the magnetron runs without the cooling fan, it will overheat and its thermostat will interrupt the power to the oven until it cools back down.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Posted on Dec 02, 2008
Microwave over the stove made a pop sound and stopped heating. Also, when door was opened it had a bad smell.
Posted on Oct 06, 2009
I have a russel hobbs CJ/AL28 microwave,the fan has stopped working .I have removed it from appliance and it works independantely .what can be wrong withit?
With a basic microwave there is a minimum of electronics and the fan starts when the oven is switched on and continues working until cooking has finished. In that case the fan is supplied from the timer and the circuit will be simple to check using a multimeter.
The more upmarket microwaves contain a great deal more electronics and the fan will continue to run after cooking has finished until the circuitry has cooled to a predetermined temperature.
In that case the the checking, fault location and rectification is probably completely beyond even most service engineers - who typically would simply replace circuit boards until the fault is cured...
Feb 04, 2018 | Microwave Ovens
Russell hobbs hob sjs21
Usually you have to remove the jacket from the microwave to reach the release mechanism.
Nov 03, 2017 | Russell Hobbs Microwave Ovens
Need operating manual for russell hobbs microwave hob gts23
Is there a number on any tags on the oven?
If not, I would contact the dealer from whom you purchased the oven.
They should have contact information for the manufacturer.
Dec 02, 2011 | Russell Hobbs Microwave Ovens
Hi i have a Russell Hobbs HOB CJ/AL28 Microwave.the microwave has stopped heating things up.Oven part works ok.Any suggestions would be most help.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARRAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 04, 2011 | Microwave Ovens
Russell Hobbs HOB CJ/AL28 Microwave not worring
it is easy to fix if you know what to do but it is best sent to a local repair shop
May 01, 2010 | Microwave Ovens
Bulb blown. How do I change it?
Hello there :
first you will need to remove all of the screws off the back edges and the sides next turn over the microwave over and there will be 6 or 8 screws that are on the bottom edges remove them now turn over the microwave and using a flat tip screwdriver look at the seam and you can use the screwdriver to get the cover to start moving towards the back andd then once it is loose it will lift off
Now you will see the bulb towards the fromnt of the microwave simply replace the bulb and test it the microwave if it works reassemble the microwave and you are done ok ?
I hope this is very helpful for you
Best regards Michael
Dec 03, 2009 | Zanussi ZMC30STQX Convection Microwave...
Bulb blown on Russell Hobbs CJ/AL28 microwave
Just open the top cover and find the location of the bulb , it may be in the right side near the control panel. Remove the bulb and get a similar bulb with the same rating from any electrical shop and fix it
May 25, 2009 | Microwave Ovens
Russell Hobbs HOB CTS34 - Faulty glass plate
Door glass broken on russel hobbs 28lt micro wave. Any idea where I can have this replaced. thank you
Mar 15, 2008 | Microwave Ovens
Microwave Ovens Logo
465 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
