Sony STR-DE525 Left Rear channel not working
I can't get any sound through the left rear channel of my STR-DE525. I get sound through all other channels, front, center and right rear. The internal fuses are all OK. All other functions work. Do you think replacing the small logic board for the rear and center speakers will solve the problem? Thanks for your help
  • 4,234 Answers
Most likely the amp for that channel is defective. If memory serves me correctly, there is a small amp chip mounted on the heatsink that is for both the left and right rear. I would change that first. It should have about 5-7 pins.
Dan
Posted on Dec 02, 2008
How do i connect my sony str-de525 to my pioneer cx-770
If you want to connect output of Sony STR-DE525 to input of Pioneer CX-770. Then connect Video/Audio out (or Tape Rec Out) of Sony to CD/LD-VCR input of Pioneer.
May 04, 2012 | Sony Audio Players & Recorders
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
When on 5.1 dvd ther is no sound from rear speakers,but i can run the test tone ok
check to see that the dvd player sound setting is set to BITSTREAM and not pcm. pcm is only 2 channel. Then check to see that the volume setting for the rear speakers in dvd is up, most sony receivers hold different settings for different applications, (vid 1, sat/tv, dvd) and remember when you switch between them. Rear surround should be up all the way , I believe for your receiver that is +10 also make sure you enable the rear speakers in the setup menu for surround sound.
Nov 28, 2009 | Sony STR-DE525
Optical digital cable connection ?
It only works through DVD setting
Jun 20, 2009 | Sony STR-DE545 Receiver
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
May 18, 2009 | Sony STR-DE635 Receiver
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
Sony STR-DE525 Protector mode
Download service manual of STR-DE525 here and fix your receiver.
Must download all 4 files at web site.
Need further help, let me know.
Sep 24, 2008 | Sony STR-DE525
Is it worth it
the reciever you have is a dolby prolodgic system. the rear channel is monoral, that is that both rear speackers have the same infomation to it (and not much of it). the new suround sound systems are dolby digital/DTS suround sound. there is a major differance to the sound and the information presented. all channels are discreat and information provided by you digital outputs of your equipment provide the channel info (tv via optical digital out, DVD also optial or coaxal digital out, cable box also optical.)
May 11, 2008 | Sony STR-DE525
Left channel not working
Probably Broken solder connections in unit. I have seen these units have many poor broken connections throughout amp espcially around poweramp ic .IC701
I have a service manual if you are interested in it kstahl65@att.net
Jan 14, 2008 | Sony STR-DE545 Receiver
196 people viewed this question
 Grubhead
Grubhead
