Question about ViewSonic VG175 17.4" LCD Monitor
Blurry (bleeding?) display
The text/images/etc. on my viewsonic seem to bleed color to the right. I've been looking for someone else who mentions this particular problem, but have found no one so far. what might cause this and is there a simple solution? thank you.
  • 4 Answers
Try plugging the monitor into a system that is known to be good. If the problem stays the problem is most likely some thing with the monitor (unless it?s the cable, try a new cable also). If the problem goes away the real problem is in your video card or the settings. If you tweak the settings do exceed the refresh rate max (75Hz for this monitor) or you may damage the monitor. The recommended resolution for this monitor is 1280 X 1024. You can also get the latest drivers from ViewSonic. http://www.viewsonic.com/support/desktopdisplays/lcddisplays/graphicseries/vg175/ If the mother board has built in video and your using a plug in card remove the card and try the on board video. If you?re using the on board video do the opposite, plug in a card (PCI or AGP) and try that. You may have to flip a switch in the CMOS to get one or the other to work Hope this helps
Posted on Feb 06, 2007
My toshiba 65 rear projection is blurry and has dual image
The fluid that is used to cool the face of the 3 tubes has become clouded and discolored. This fluid is serviceable. I wouldn't try it myself if you've never done it before. A TV shop can do the job.
Oct 09, 2014 | Toshiba 65H82 65" Rear Projection...
Blurry text
LCD monitors do best at their native resolution. There might be 2x2 pixels per spot at that resolution. Once you change the resolution, you might have 2.7 x 2.7 pixels per spot (merely an example). Although a resolution might fit well, at 3x3 or 4x4 pixels, all the other resolutions might look out of focus as each character bleeds over into an adjacent pixel.
The 16:9 aspect ratios are the only ones that will work correctly with this monitor; others will show black at the top and bottom or left and right, or images will be too tall or too wide.
The resolutions you should try are 1920 x 1080, 1280 x 720 or 800 x 600. When I look at resolutions available for my 16:9 ratio monitor, those are the three that are bold.. others are available, but would not show the high quality display.
There are also buttons on the front of the monitor to adjust the display left/right, up/down, re-size, focus, brightness, etc.. A change there could make a difference too.
Oct 30, 2013 | Westinghouse Electric L2220HW 21 inch LCD...
Asus VH196 text bleed
Go into settings a restore to defaults.
Then right click on desktop and then display go to display driver and restore to default or uninstall reboot computer and it will reinstall the drivers.
Sep 09, 2017 | ASUS VH192D 19 inch LCD Monitor
Reddish light bleed on image
It is problem of bad ccd imager sensor and this part will be replaced.
Canon will repair A95 camera free of cost for bad ccd imager sensor problem.
Click Canon CCD Imager Advisory for details.
Mar 21, 2009 | Canon PowerShot A95 Digital Camera
Colour spots
turn your color all the way down and observe the black and white, contrast and grays . should be crisp. if sorted looks still like blurry grays with little contrast...... your problem lies in the video processing circuit.
Oct 23, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Printing bleeds
This machine, like almost every other laser based device on the market does not print bleeds.
The spec for the image masking at the edge is probably in the 3 to 4 mm range. When the sales person tells you that you can do "full bleed" what they are saying (even if they do not realize it) is that you can print an image larger than 11x17 onto a 12x18 sheet of paper and then trim the page back to 11x17 so that the final product bleeds over the edge.
Mar 03, 2008 | Canon imageRUNNER C3200 Color Printer
Intermittent Power Down and Backup
THE TV ONLY HEAR THE RELAY BUT NO PUSH IN ON NEVER
Jan 10, 2008 | Sony KV-27V10 27" TV
ViewSonic VG175 17.4" LCD Monitor Logo
153 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
