Washing machine won't fill with water
Autoload sensing triple spray technology - I think the sensor is not working correctly - no water will enter - the spinning occurs -
the previous load got too much water in it - kept adding more when lid was opened then was too full and also the load was unbalanced.
  • 1 more comment
  • jksullie Nov 30, 2008
    this is a whirlpool
  • abohana Mar 22, 2009
    i have the same problem and the washing machine is about three months old it is whirlpool mode WTW57ESVWD this machine  is equiped with load size sensor. the problem happened after my wife moved it few inches to clean underneath it the machine does not fill water how ever it spines and the drain pump seems working fine just doesn't fill to start the cycle i have checked the screens in the supply valves the are clean the water supply in both hot and cold hoses is fine
  • JEFF SIEGEL May 11, 2010
    what brand and model?
I am returning the washer.
Posted on Dec 01, 2008
Does not sense clothes
most top loaders fill to the setting you enter into the program l( medium low high etc ) as the clothes absorb the water it will keep filling until a level is reached at which point that is the amount of water for the clothes and the machine will start you just have to think about how many clothes you are washing and how big they are ie blanket will be a big load and nickers will be small load
Jun 09, 2013 | Washing Machines
Whirlpool W10140920 agitates with no water in the tub
I've had the same problem..3 times in 2 years.
EVERY time I needed to relpace the switch sensor (behind the water temp knob.) It fixes the problem, but continues to happen. I am going to get a new NON Whirlpool washer today.
Feb 12, 2013 | Kenmore Washing Machines
Won't stop filling with water Model # WDSR2080G3WW
Does it stop filling if you stop it at the dial or unplug it?
Nov 06, 2012 | Washing Machines
Hot water fills with hot and cold not strictly hot what is the fix
see the causes: and proceed with common sense. God bless you
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine is not working the way it used to--or should--check the following. Is the cold water turned on? If not, turn it on. Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct. Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the
Sep 22, 2012 | Roper Washing Machines
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
I have a similar problem
Possible Hall sensor problem on the motor.It senses the rotor position as with most modern electronic machines.Replace Same. Hope this helps. Kind Regards. Stefan.
Jul 08, 2009 | LG WFT1071TP Top Load Washer
Ariston Margherita ald 1 40 Error code H2O
H2O is the symbol for WATER and probably indicates a WATER related fault on your machine. A pressure switch is the normal way the machines 'sense' when the level is sufficient. Overfilling suggests a faulty switch, which will need to be replaced by a technician. Also, ensure that the machine drains as it should, if not, the pump filter may be blocked.
Jan 03, 2018 | Ariston Technologies Washing Machines
Washing Machines Logo
647 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
